Software Update available for Bolero?
Hi guys and @andreiro221 @Rainesh
I am driving a Skoda Scala 2021 1.5 TSI.
I currently have MEN3_EU_SK370_P1043L, MU 1540.
Can I go directly to MEN3_EU_SK370_P3355L, MU 1800?
 Or do I need to go through MEN3_EU_SK370_P1185L, MU 1760, first?
  • Replies 771
  • Views 222k
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
Hi Guys,
I'm looking for the latest Firmware for my Fabia.
Can someone Help me, please?
On 29/05/2024 at 15:40, lavableukushaq said:
I am currently on 1790 version. But when I am trying to update to 1800 its stuck at confirmation screen. When I press confirm nothing happens. Do I need to update first to 1798 ?
Yes, you need to update to 1798 first and then to 1800. We tried to upgrade from 1790 to 1800 directly on a car and it didn't work.
You seem to be very knowledgeable in this matter. Do you perhaps know what I'd have to go through to get my coworkers infotainment from version 1310 to 1800. She has an s23 phone and she's very upset that she can't connect it to Android auto
Sorry, all our cars here came with 1790 and above, so I don't have an idea on the earlier versions.
My Kamiq from 2021 was updated every time by a dealer, as the car was (and is) still under warranty. Initially, I had the 1310 version, afterwards I got 1760, and finally 1800. I hope it will work out also for you.
Edited by FnLn
Hi guys, an update from me with the almost "unknown" 1540 software variant.
I updated the radio and went through MEN3_EU_SK370_P1185L, MU 1540 -> MEN3_EU_SK370_P3225L, MU 1798-> MEN3_EU_SK370_P3355L, MU 1800.
Everything worked just fine, even though I am not sure that I needed to do the 1798 update to get the 1800 up and running.
It was, however, a bit fiddly getting the error code out afterwards, but I managed by calculating and getting a 5 digit XOR code in the OBD; then it worked.
Thank you for all of your help in this thread!
Hello,
I just bought an android phone with Android 14 and its impossible to connect Android Auto with my scala.
I have try more than 7 cables and still nothing.
Will a update solve this problem? Here its the software update i got now. I think the 0469 it's old.
58 minutes ago, GiannisTs said:
Hello,
On 11/05/2024 at 11:49, andreiro221 said:
no, if you have 469, 742, there is no OFFICIAL update to 17xx/1800
only at your own risk
Hi Giannis, It looks like the only upgrade path is to the 0471+0472 (0471 is apparently only a partial software). Otherwise, search through this thread to find out where to get files and how to flash them.
Hey, this is my first post here.
Since switching phones I have constant issues with android Auto, no matter which cable I use.
So, perhaps updating will help?
The car is a 2017 fabia III Combi (CHZC),  the relevant PR-number I found were I8E and RAF (Bolero).
the info in the car says Part Number: 5Q0045842C; Hardware: H41; Software: 0478
See also screenshots.
Is there a way I can update this myself?  The local skoda partner will mnost liekly charge a fortune.
BTW: there is no way to get this radio work with wireless AA, right?
Typo in the Part, its 5Q0035842C.
And I found the SW Train Version: MST2_EU_SK_ZR_P0478T / H29.319.93_STD2Plus_EU
Looks like you can update to MST2_EU_SK_ZR_P0480T - it can be found here: https://mibsolution.one/#/1/9/MST2 - TechniSat Preh/Firmware/SKODA_ZR/EU
Please read back the other pages for a guide on how to flash the software.
On 18/06/2024 at 14:20, GiannisTs said:
Hello,
Hi Giannis, this guy says you can go from 0469 -> 0742 -> 1798 -> 1800.
I haven't tried it myself, so it will be at your own risk (as always) https://www.drive2.ru/l/650934799095051499/
Hello again,
I have download successfully all updates until 1798.
I tried to download 1800 but i got error 28: flashing
I read in this site https://www.drive2.ru/l/650934799095051499/ about a solution but i think, (from the translation) i need an obd reader, and i dont have one.
I just tap abort when i saw the error because i dont want to brick the unit. Should i press skip and wait for the update to complete?
Any ideas?
With the 1798 still i cannot have my s23 with android auto.
1 hour ago, GiannisTs said:
Hello again,
Any ideas?
Well, I am definitely not an expert, but I wouldn't complete it. You'd need an OBD reader anyway to remove the B201A error (if you wanted to), but to sum up, I wouldn't take the chance.
16 hours ago, GiannisTs said:
Hello again,
Any ideas?
By the way, a good OBD reader and the Car Scanner Pro app is not that expensive.
You'll need to consider if that expense is worth it in return of you maybe getting your S23 to work in your car.
Hello Gentlemens,
I am struggling with the following issue with Skoda Scala 2020:
When I start the engine the infotainment does not start properly -> only the initial screen with the skoda logo is displayed. While driving the infotainment tries to restart several times, but it freezes on the splash screen every time. Only way I am able to initiate the infosystem is when the engine is not running and I do a hard reset.
Do you guys advise me if updating SW can fix the issue? This is a FW I use:
If so, should I flash the same SW or a newer one? Can somebody share with me necessary file (binary) ?
Thank you very much for your help!
all the answers are on the previous pages.
nobody reads
Hi Guys,
I have version 463, where can I download updates 464 or 469?
Hi Guys,
I drive a skoda Scala 2019, i have some problems with my media center..freezing, glitchs...
MEN3_EU_SK370_P9305P
0463
can you please help me with the links to update this unit? Any chances to activate the Smartlink without paying them a lot of money?:) I just want to use the android auto, no other fancy stuffs.
Honestly, there are more cheaper cars with android auto activated...
nu poti activa Smartlink momentan pe MIB3 decat la dealer, 900 lei licenta + manopera (tester)
update-ul nu te ajuta cu nimic daca unitatea merge bine
multumesc, unitatea merge bine cand vrea ea..sunt momente in care se blocheaza..nu se mai aprinde si implicit nu mai merge partea de comunicare cu serviciul de urgenta...am fost la service, iar cei de acolo mi-au zis ca e boala lor, asta si cu amortizoarele fata, care troncane la fiecare denivelare/panta...dar care sunt in parametrii (cf testerului de amortizoare)
On 15.03.2023 at 16:32, varooom said:
Bu güncellemeler var, ancak daha yüksek sayının sisteminiz için geçerli olup olmayacağından emin değilim.
ERKEK3_AB_SK370_P0113P_0469
MEN3_AB_SK370_P2135P_0742
MEN3_AB_SK370_P1185L_1760
MEN3_AB_SK370_P2345L_1790
Denemek için önerebileceğim tek şey 0742 (uyumlu değilse yüklenmez)
Eğer yüklenmezse, o zaman 0469 sizin güncel sürümünüzdür ve satırın sonudur.
Hello, where can I get the file to switch from 0464 to 0469 in my current version? I think P0113P I need this upgrade file. The attached file is my current version.
poti face update la 469 >741+742
dar trebuie si tester capabil sa ruleze functia de Replace pt unitatea media.
trebuie vazut si erorile legate de OCU, cel mai adesea trebuie inlocuita antena din unitatea de OCU, daca ai eroarea B200049 in unitatea OCU
also 469 > 741+742
but you also need diagnosis to run Replace function for the media unit.
Edited by andreiro221
