VCDS options on Superb III.FL
9 hours ago, Nautilus said:
when compared to old -19 VW Passat)
the same when compare to my previous ŠS Mk3 2016, click on links in my signature
Electornics should be in order as the Travel assist works...
are you sure TA is activated?
manually on steering wheel or coded to switching on automatically when 60kmh reached
Yes, and it works fine with ACC. But lane assist stays ”dumb” sailing from side to side, strange 🤔
@Waylon
    Control unit: 09 Central Electrics
    System description: BCM MQBAB H
    Software number: 5Q0937084EC
    Software version: 0511
    Hardware number: 5Q0937084EC
    Hardware version: H44
    Serial number: 0410223540xxxx
    ODX name: EV_BCMMQB
    ODX version: 022001
    Long coding:
        000000000000000000000000000000000000000000000000000000000000
    Subsystems:
        Subsystem: 48x LL 221122
        Long coding: 1E4DFD
        Subsystem: RLHS
        Long coding: 0088DF
Finally in front of a computer so was able to see the links on your signature. So, based on this:
Do I understand correct you were never able to resolve it to a satisfactory level (i.e. lane assistant working like in pre-FL ŠS / VW Passat)? Or is there a way to sort of "force" travel assistant to work with lane assistant when ACC not active?
19 hours ago, MartiniB said:
@Waylon
    ODX name: EV_BCMMQB
    ODX version: 022001
    Long coding:
    Subsystems:
        Long coding: 1E4DFD
        Subsystem: RLHS
        Long coding: 0088DF
@MartiniB
In comparison, the hardware and software are the same.
Did you use obdeleven to make the coding modifications? I used odis engineers to make the coding modifications.
yes, i titled this coding that way, minimise ping-pong effect, but it still here 😞
also time without touch steering wheel can't be extended as on preFL ŠS
@Waylon
i coded by OBDEleven first gen
Yeah, got it 👍
In my case I did not notice any change even, maybe it is little bit better, not sure. On a road with curves and some speed it will just go over the lane and maybe try to turn a little…😅
it can b done by updating the Gateway software version to version which has the parameter modified.
in my case, it is now set to 60 secs.
default was 12 secs.
my gateway SW version was updated when i had the DCC Mod done to my Superb MY17.
Edited by JR RS
@JR RS
FL got another hardware version, H44 vs H24,
it doesn't show even Long coding, scroll up few posts above for details
True, but I was referring to the 19-Gateway module, where the parameters r modified.
The Parameter file can't b modified by VCDS or OBDEleven.
Needs ODIS or VCP.
My 09-Central Electrics module is the same - no Long Coding either.
Software number: 5Q0937084CG
Software version: 0236
Hardware number: 5Q0937084CG
Hardware version: H34
Serial number: 02001706702006
ODX name: EV_BCMMQB
ODX version: 017001
Long coding: 000000000000000000000000000000000000000000000000000000000000
my previous H24(2016.02) had
    Software number: 5Q0937084CL
    Software version: 0175
    Hardware number: 5Q0937084AN
    Hardware version: H24
    Serial number: 0106160360xxxx
    ODX name: EV_BCMMQB
    ODX version: 015001
    Long coding:
        0C019E66C2C72AFB17A44086B11817280C00000000000000000000000000
    Subsystems:
        Subsystem: 48x LL 160122
        Long coding: 165DFD
        Subsystem: RLHS
        Long coding: 0088D0
have You stored which?
long coding partly looks same
Mk3 2016.02
    Control unit: 19 Gateway
    System description: GW MQB High
    Software number: 5Q0907530AJ
    Software version: 2246
    Hardware number: 5Q0907530M
    Hardware version: 212
    Serial number: 0702161080xxxx
    ODX name: EV_GatewConti
    ODX version: 013020
    Backup name: Gateway
    Long coding:
        0B0100047F085900EB00025E9C0F00010001070000000000000000000000
Mk3.FL 2023.01
    Software number: 3Q0907530AR
    Software version: 5504
    Hardware number: 3Q0907530G
    Hardware version: 527
    Serial number: 1001231052xxxx
    ODX name: EV_GatewNF
    ODX version: 013026
    Long coding:
        0B0900047F285900AB0042DE980F00010001070000000000000000000000
  • ColinD pinned this topic
i tried to code eyelashes for my superb.
i did everything that is written in the first post, but then i have error message showing up sdaying that the foglights are not functional (although they are).
and this occurs when only the DRL light is on. if the low beam is on, this error message does not shjow up.
wanted to revert back to the original setting for thr eyelashes, but dopn't know what these are...
can someone help me?
thanks
@dimushor
have you asked your self,  for what reason this coding got comment
On 07/09/2023 at 10:05, MartiniB said:
NOK, + Foglight ERR
revert changes to original values
           -> Change (8)Leuchte17TFL R BLK ......... C17 to Daytime running lights - > Not Activated
           -> Change (10)Leuchte17TFL R BLK ......... CD17 to 100 - > 0
           -> Change (8)Leuchte16BLK SLB ......... C16 to Daytime running lights - > Not Activated
           -> Change (10)Leuchte16BLK SLB......... CD16 to 100 - > 0
Hey everyone and thanks this topic.
 Is it possible to code or adapt the auxiliary heater to work when the car is running Superb III Style iV 05/2020 (plugin hybrid)
best regasds. Sepe
4 hours ago, dimushor said:
Of course I asked myself about this. But I have no idea what NOK stands for...
Thank you for the original settings
NOK means Not OKay :)
  • Like 2
sorry, English isn't tongue language also for me,
but 25+ years long friendship with computers made it obvious for me
я не айтишник.. сорри
  • Haha 1
Hi, I have an Superb iv MY20.
I try to change Comfort Blink Cycle from 3 to 4 or 5 but not result.
If I restore to default value the infotainment It blink as I want, but when I register me as user, again blink 3 times.
In Carista say reset lights options, but this not appear in MIB3 or I can't find It.
Merry Christmas and Happy new year
On 7/9/2023 at 9:05, MartiniB said:
Pido disculpas por iniciar este nuevo hilo, algunas razones para mantenerlo separado:
1. El hilo de codificación Mk3 ha crecido enormemente y no es fácil buscar algo en él.
2. Las codificaciones FL tienen varias diferencias.
3. El procedimiento de codificación también se ha modificado:
 antes de realizar la codificación, se debe abrir el capó y activar el freno de mano.
Lo que se ha probado en Mk3.FL MY23 280ps L&K
23.02.21           OK
** Luces de circulación diurna escandinavas
09 Electricidad Central
            Código de acceso 31347
            Adaptaciones
            -> Leuchte23SL HLC10:
            --> Función de luz C 23:
                        no activo        ->          Tagfahrlicht
            --> Dimmwert CD 23:
                        0           ->          100
            --> Función de luz C 24:
            --> Dimmwert CD 24:
                        0           ->          100
23.03.20           OK
*- - Luces de circulación diurna solo con el interruptor en 'Auto'
*** Luces de circulación diurna apagadas con freno de mano
*** Configuración de luces de circulación diurna disponible a través del menú
            Adaptación
            -> Aussenlicht_Front
            ---> Tagfahrlicht nur en Schalterstellung AUTO:
                        no activo         ->          activo
            ---> Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
                        no activo         ->          activo
            ---> Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
                        no activo         ->          activo
23.03.20           ok, se agregaron nieblas, los faros no se apagaron
*** Configure las luces antiniebla como luces de entrada/salida de casa
            Adaptación
            -> Aussenlicht_uebergreifend
            ---> Volviendo a casa Leuchten:
                        Luz de cruce        ->          Luz antiniebla
            ---> Regreso a casa Einschaltereignis:
                        puerta del conductor       ->          encendido
23.03.20           OK
** Memoria de luces altas activada
            Adaptación
            -> Fernlicht_assistent
            ---> Reinicio de Fernlichtassistent:
                        activo    ->          no activo
23.03.20 NOK , + ERR de luz antiniebla
- - Codificación de pestañas siempre encendidas en los faros.
            Adaptación
            -> Cambie (8)Leuchte17TFL R BLK ......... C17 a Luces de circulación diurna
            -> Cambiar (10)Leuchte17TFL R BLK ......... CD17 a 100
            -> Cambiar (8)Leuchte16BLK SLB ......... C16 a Luces de circulación diurna
            -> Cambiar (10)Leuchte16BLK SLB......... CD16 a 100
23.03.20           OK
** Ciclo de parpadeo cómodo
            Adaptación
            -> Aussenlicht_Blinker
            ---> Blinkzyklen cómodos:
                        3           ->          2
23.04.03           OK
*** Toallita en forma de lágrima para limpiaparabrisas delanteros
            Subsistema: 48x LL 221122
            Codificación larga
                        164DDD
            -> 1E 4D FD
            -> Byte 0
                        Bit 3 "Borrado adaptativo de postes/desgarros activo"
            -> Byte 2
                        Bit 5 "Limpiado de post/desgarro activo"
o          Adaptación
            -> Limpiaparabrisas delantero
            ---> Estado del frente Traenenwischen:
                        no activo         ->          activo
23.03.20           OK
** Luz interna con atenuación suave y brillo
            Adaptación
            -> Suchbeleuchtung_allgemein
            ---> KL58 Einschalten con rampa:
                        no activo         ->          activo
23.05.09           OK
* Botón intermitente de emergencia tenue en el tablero
            Adaptación
            -> Leuchte 35 LED Warnblinktaster C48
            --> Regulador AB 15:
                        100       ->          55
23.03.28           OK
*** Cambiar umbral de luz
            Adaptación
            -> Sensor de luz
            ---> Helligkeitsgrenze_Licht_ausschalten:
                        orig.      2200 litros
                        ->          1200 litros
            ---> Daemmerungsgrenze_Hysterese_untergrenze:
                        orig.      2200 litros
                        ->          1200 litros
            ---> Helligkeitsgrenze_Licht__einschalten:
                        orig.      1200 litros
                        -> 800 litros
            ---> Daemmerungsgrenze, Hysterese_obergrenze:
                        orig.      1200 litros
                        -> 800 litros
23.05.09           OK
*** Habilite la opción Autolock (según la velocidad) en Configuración del automóvil
09 Electrónica Central
            Adaptación
            -> Menuesteuerung ZV Autolock-Unlock:
                        no activo         ->          Ajustable
23.04.20           OK
*** Habilitar mando con auto en marcha
            Adaptación
            -> ZV allgemein(Control de acceso)
            ---> Funk bei Klemm 15 ein:
                        no activo         ->          Activo
23.05.09           OK
*** Habilite el bloqueo/desbloqueo pasivo mediante sensores de manija de puerta (KESSY) con el encendido encendido
B7 - Acceder a la interfaz del sistema de inicio
            Codificación larga
                        0F20000723
            -> 1F 20000723
o          -> Características del terminal 15 de la función de entrada y salida pasiva
                        orig. valor:       Función sólo permitida para terminal 15 apagado
                        nuevo valor:        Función sólo permitida para terminal 15 encendido o apagado
23.03.20           OK
** Habilitar visualización del nivel del ventilador en Climatronic Auto
08 Aire Acondicionado
            Codificación larga
                        11010004004411011005100D00109136
            ->          1101000400441101100510 4D 00109136
o          -> Visualización del ventilador en funcionamiento automático:
                        No activado   ->          activado
23.03.20           OK
** Conservar la configuración del asiento con calefacción
            Codificación larga
                        11010004004411011005104D00109136
            -->          11010004 10 4411011005104D00109136
            Adaptación
o          -> Mantenimiento del nivel de calefacción del asiento del conductor
                        activo durante 10 minutos   ->          activo
            -> Retención de frt.pass. nivel de calefacción del asiento
                        no activo         ->          activo
23.03.28           OK
** Efecto de luz de latido del corazón en el botón de arranque del motor sin llave
B7 Acceso a la interfaz del sistema de inicio
            Código de acceso 20103
            Adaptación
            -> DeveloperCoding: luces de búsqueda
            ---> ZAT_illumination_concept_mybeat_clamp58xt
                        No activado   ->          Activado
            ---> ZAT_illumination_modus_mybeat_clamp58xt
23.02.21           OK
*** agregar control de crucero simple
13 Control de crucero adaptativo
            Codificación larga
                                32057FD25DFFC728949C812481400680000000000000000066
            -> 32057FD25DFFC728949C8124814006800000000000000000 76
o          -> Modo de control de crucero:
                        --> Activado
23.03.27           OK
*** Start-Stop evita que el motor arranque cuando el vehículo de delante se mueve
            Adaptación
            --> Función de reinicio ampliada:
                        Activado        ->          Desactivado
23.03.27           OK
*** Adelantamiento de la prevención adecuada.
            Codificación larga
                        32057FD25DFFC728949C812481400680000000000000000076
            -->          3205 5F D25DFFC728949C8124814006800000000000000000076
o          -> Prevención_derecha_adelantamiento:
                        activado          ->          Desactivado
23.04.19           ok, opción agregada, pero funciona solo el primero de tres
*** agregar tolerancia para el control de crucero adaptativo predictivo
            Codificación larga
                        32055FD25DFFC728949C812481400680000000000000000076
            ->          32055FD25DFFC72894 9D 8124814006800000000000000000076
            -->          32055FD25DFFC728 97 9D8124814006800000000000000000076
            ->          32055FD25DFFC728979D8124814006800000000000 10 000076
o          -> Tempolimitassistent_CarMenu:
o          -> zul_Regelabweichung_CarMenu:
                        orig.      Apagado
                                    Pequeño (nada)
                                    Medio (nada)
                        ->          Grande ( apagado; bajo ; medio; alto )
o          -> pACC_Learning_drivers_offset:
                        Desactivado      ->          activado
23.03.31           OK
*** Minimiza el efecto ping-pong del asistente de carril
Asistencia al conductor A5
            Codificación larga
                        00020898116E4020089F100010300080014180000000000000000000000000000000000
            -->          00020898116E4020 88 9F 18 001030008001 43 800000000000000000000000000000
o          -> Punto_de_intervención:
                        temprano     ->          early_setting_over_menu
            -> HC_Warn_Intensidad:
                        No_Configuración       ->          Configuración_sobre_Menú
            -> Lane_assist_off_text:
                        deshabilitado            -> habilitado
23.04.11           OK
*** Lane Assist automático activado a partir de 60 kmh
            Codificación larga
                        00020898116E4020889F180010300080014380000000000000000000000000000000000
            -->          00020898116E4020889F18001030008001 23 80000000000000000000000000000
o          -> Hc_variante:
                                    Variante_0 (? ¿Desactivado?)
                        ->          Variante_1 (automática, cuando se alcanzan los 60 kmh)
                        orig.      Variante_2 (manualmente, mediante botón en el Volante)
                                    Variante_3 - 7 (?????)
23.04.11           ? DE ACUERDO
? Modo de asistencia de emergencia, ¿cuál es la diferencia?
            Codificación larga
                        00020898116E4020889F180010300080012380000000000000000000000000000000000
            -->          00020898116E4020889F 28 0010300080012380000000000000000000000000000
o          -> Asistencia_Emergencia:
                                    No_codificado
                        orig.      EA_Variante_1 (?????)
                        ->          EA_Variant_2 (?????)
                                    EA_Variante_3 (?????)
                                    EA_Variante_4 (?????)
23.05.20           OK
*** Desactive la función de navegación por inercia DSG en el perfil Normal
19 módulo de puerta de enlace
            Codificación larga
                        0B0900047F285900AB1042DE980F0001000107000000000000000000000000
            ->          0B0900047F285900AB 00 42DE980F000100010700000000000000000000000
o          -> FPA_function_freilauf_defaultON
                        activo    ->          no activo
^^^     ? OK
            Codificación larga
                        32055FD25DFFC728979D812481400680000000000010000076
            ->          32055FD25DFFC728979D81 64 81400680000000000010000076
o          -> Función_navegación:
                        no activo         ->          no_predictive_sailing
23.03.27           OK
** Cambiar la velocidad de apagado del asistente de estacionamiento
76 Asistencia de estacionamiento
            Adaptación
            -> Velocidad de desconexión del asistente de aparcamiento
                        15 kilómetros por hora            ->          10 kilómetros por hora
23.03.01           OK
** Conductor de entrada fácil
36 Asiento del conductor
        Codificación larga
                        0010000000000500018280808080000000008181000000D440
            ->          001000 02 00000500018280808080000000008181000000D440
            -->          001000020000050001 C2 80808080000000008181000000D440
            -->          001000020000 15 0001C280808080000000008181000000D440
o          --> Easy_Entry_front:
                        no activo         ->          activo
            --> Easy_Entry_front_over_MMI:
                        no activo         ->          activo
            --> EasyEntry_Enable_Passenger_over_DriverMMI:
                        no activo         ->          activo
23.03.20           OK
** Pasajero de fácil entrada
06 Asiento del pasajero
            Codificación larga
                        0010000000000500018280808080000000008181000000D400
            ->          001000 02 00001500018280808080000000008181000000D400
            -->          001000020000150001 C2 80808080000000008181000000D400
            -->          001000020000 15 00018280808080000000008181000000D400
o          -> Easy_Entry_front:
                        no activo         ->          activo
            -> Fácil_entrada_frontal_sobre_MMI:
                        no activo         ->          activo
                        no activo         ->          activo
23.03.01           OK
* Opciones de entrada fácil en la configuración del automóvil
Multimedia 5F
            Acceso de seguridad 20103
            Adaptaciones
            Operación del menú del vehículo
                        menu_display_seat_configuration
                        menu_display_seat_configuration_over_threshold_high
            Lista de funciones del vehículo BAP
                        asiento_conductor_0x10
                        asiento_conductor_0x10_msg_bus
                                    No activado   ->          Bus de datos Comfort
23.03.20           OK
* Formato de fecha
17 Panel de control
            Codificación larga
                        05A5001AFF8C00080188634B1001000800600000
            -->          05A5001AFF8C00 0A 0188634B1001000800600000
o          -> Fecha:
                        dd_mm_aa       ->          aa_mm_dd
23.03.20           OK
* Cantidad de repostaje
17 Panel de control
            Codificación larga
                        05A5001AFF8C000A0188634B1001000800600000
            -->          05A5001AFF8C000A0188 73 4B1001000800600000
o          -> Byte 10
                        Habilitar bit 4
23.04.03           OK
** Umbral de advertencia de HIELO
17 Panel de control
            Adaptación
            -> temperatura_exterior
            ---> p_ice_warning_entry_temperature:
                        4 ºC      ->          2 ºC
            ---> p_ice_warning_exit_temperature:
                        6 ºC      ->          3 ºC
23.04.11 NOK , pero desactiva Start-Stop
- Asistencia de eficiencia.
17 Panel de control
            Codificación larga
                        05A5001AFF8C000A0188734B0001000800600000
            -->          05A5001AFF8C000A0188734B0001 08 0800600000
o          -> Asistencia de eficiencia.:
                        No        ->
23.04.11           OK
23.05.20           revertido
* Desactivar advertencia de salida
17 Panel de control
            Codificación larga
                        05A5001AFF8C000A0188734B1001000800600000
            -->          05A5001AFF8C000A0188734B 00 01000800600000
revertir    ->          05A50019FF8C000A0189734B 10 01000800600001
o          -> Salir de advertencia:
                              ->          No
23.05.09           NOK
* Desactivar encendido en advertencia
17 Panel de control
            Adaptación
            -> Mensaje de encendido activo, actuador
                        Puerta del conductor (orig.)         ->          Sin pantalla
23.05.09           OK
* Pantalla de inicio del panel
17 Panel de control
            Codificación larga
            orig.      05A50019FF8C000A0188734B0001000800600001
                        05A50019FF8C000A01 89 734B0001000800600001
                        05A50019FF8C000A01 8A 734B1001000800600001
                        05A50019FF8C000A01 8B 734B1001000800600001
                        05A50019FF8C000A01 8C 734B1001000800600001
            -->          05A50019FF8C000A01 8D 734B1001000800600001
                        05A50019FF8C000A01 8E 734B1001000800600001
                        05A50019FF8C000A01 8F 734B1001000800600001
o          -> Pantalla de inicio:
                        orig.      Versión 1          L&K
                                    Versión 2          vRS Verde
                                    Versión 3          vRS Rojo
                                             Explorador versión 4
                                    Versión 5          Skoda
                        ->          Versión 6          Línea Deportiva
                                    Versión 7          Skoda
                                    Versión 8          Skoda
23.05.09           bien
17 Panel de control
            Adaptación
            -> Leaving_warning_delay
            - -> Leaving_warning_delay:
                        orig.      1,6 segundos
                        ->          3,0 s
23.06.08           bien
17 Panel de control
            Adaptación
            -> Ilustración de tubos
                        orig.      Versión 0
                        ->          Versión 1
23.06.08 NOK , mensaje de error en el tablero "El vehículo no está asegurado contra desplazamiento"
17 Panel de control
            Adaptación
            -> Advertencia de salida de turno
                        orig.      Aviso de salida del coche
                        ->          Aviso de salida, vehículos comerciales VW
23.06.14           bien
17 Panel de control
            Adaptación
            -> Visualización de aceleración:
                        orig.      No
                        ->          Si
23.04.15           OK
** Circunferencia de la rueda 1
17 Panel de control
            Codificación larga
            -->          05A500 19 FF8C000A0188734B0001000800600000
o          -> Circunferencia rueda:
                        Versión 3          ->          Versión 2
23.03.20           OK
** Circunferencia de la rueda 2
17 Panel de control
            Codificación larga
            -->          05A5001AFF8C000A0188634B10010008006000 01
o          -> Circunferencia de la rueda 2:
                        Versión 1          ->          Versión 2
Unidad 17 Panel de control
Valor del velocímetro compensado a 100 km/h
Circunferencia del neumático 235/45r18 +0%
Circunferencia del neumático 225/55r17 +1,5%
Primero
Segundo
1
1
-2
2
1
+2
orig.
3
1
+4
+3
3
2
+1
0
2
2
0
23.07.05           OK
Aplicación OBDEleven
            -> Sonido del portón trasero
                        orig.      EN
                        ->          APAGADO
23.07.05           ? ?
            -> Modo automático de calefacción del volante
                        orig.      Control manual mediante botón
                        ->          Temperatura de la rueda automática
Las codificaciones fueron realizadas por OBDEleven de primera generación.
https://forum.obdeleven.com/
Now I have Car Scanner I try with It but the same result.
@MartiniB
What do your following abbreviations represent?:
--- clearly means it doesn't work (on your vehicle, at least, probably on all?) I.E. NOK (Not OK)
@Gizmo
Stars - how useful for me
??? - i can't notice improvement or changes
NOK - doesn't work or adds err
Edited by MartiniB
