Radio stations Logos database updates
That's the same update @MartiniB posted in July, thanks for the repost, can't wait for the next one.
  • Replies 264
  • Views 142.1k
  • Hello, I wrote to <email address removed> waited a long time, but today I received a response from <email address removed> that: We have considered these new logos in our next update versi
  • MartiniB
    MartiniB
    links in head post have been updated MQB2_Europe_v1.10.66 MQB3_JND_Europe_v1.31.66 MQB3_LGe_Europe_v1.31.66 ICAS3_LGe_Europe_v1.31.66
  • Thanks MartiniB.   The MIB3 (Superb etc) file loaded successfully into my Karoq's MIB3 Amundsen, and seems to have created some of the missing radio logos. (Pity I still haven't got any for
2026. Q3
...because database has been updated to v70.
1.31.70 installed and working on my VW ID7 (part number 10C035816)
Just updated the Golf in the UK, new logos for the BBC, Kiss stations, they're missing the Xmas stations (seasonal anyway) and Track Radio on London 2, Capital Xtra and LBC on FM but not DAB which is weird.
Probably like painting the Forth Bridge. I see there is an outbreak of Magic stations which my mib2 hasn't got but back home those are out of bounds. Magic may be in there but being away I havent tried and I've never done a mib2 high logo bulk update. We have the ability to in fill logos which mib3 people were not trusted with... can't be having users hacking mib3... might put those 5,000 Caraid programmers out of a job. Heaven forbid.
I have downloaded the latest database. My Audi Harman MQB2 high wont accept it via SD update. I get a conflict error. So I and rename the stl.1vw file to VW_STL_DB.sqlite and update via More Incredible Bash tool
I might be doing something similar this afternoon but hopefully if will take it via the import. The dealership messed up my radio icons. I never asked them to do anything on that. Get the car back with the UK icons wiped. Irish ones OK. Theory they were trying to be helpful spotting my logos were old BBC ones, deleted them, we'll just pick them off like mib3... errr oh its not mib3 but mib2... what I reckon they did so I'll try for my very first mib2 high icon update 🥰. Fingers crossed.
Yes I did it on a mib2 high you just drag and drop those latest mib2 high files out from the unzip. There is an import menu under settings or something. I used swdl since I like to see what's happening.
Took a photo before since out of range stations won't be indexed in. Will do the top up method on that. I just found BFDS or whatever its called missing a logo. LBC was fine. Didn't try for Magic Xmas... it sounded ropy.
I did have a look via sql at that database as well 😀.
v1. I get an error on versions above 31.64
Software update stoppedPlease plug the data carrier back in. The system will probably reboot
I have the same problem.
The issue seems to be the InstallerVersion field in Data/fileCopy.ext-stationdb-sqlitedb-base/0/installer.txt. They have incorrectly changed it from 328.2.11 to 1.31.70 after computing the hashes for the files to match the old versioning scheme. As expected, this changes the hash and thus it no longer matches and the system refuses to accept the file. This seems to only affect "MIB3 OI" or "MOI3" units, others are fine.
I've attached the corrected file for 1.31.70 where I changed the version back to 328.2.11 and the hash now matches again if someone wants to test, just drop it Data/fileCopy.ext-stationdb-sqlitedb-base/0/ on the SD card and you should be good to go. I also send an email to Phonostar with the details.
Both, 1.31.66 and 1.31.70 are broken. 1.31.64 works fine.
installer.txt
Edited by janil
Hi everyone,
Does anyone happen to have a working Google Drive / MEGA mirror for MQB3_JND_Europe_v1.31.64.zip (or an earlier compatible 1.31.xx JND build)?
I have a 2022 Škoda Karoq with the Amundsen MIB3 unit (Device part number: 3V0035820K, Hardware: H22, Software: 0306, current Radio database: 1.30.24).
Since Phonostar pulled v1.31.64 from their direct download server, I tried installing v1.31.70 using a clean 16GB FAT32 USB-C stick formatted on Windows with only the extracted Data and Meta folders in the root. It recognises the update, starts checking it, and immediately throws "Software update interrupted" due to the older 0306 firmware signature block.
If anyone still has MQB3_JND_Europe_v1.31.64.zip archived and wouldn't mind sharing a link, it would be hugely appreciated!
Thanks in advance!
use solution posted one post above, v1.31.70 loads with it
Recently Browsing 1
