Infotainment system switches itself on
Thanks, I'm not brave enough to remove the screen but will keep that it mind, maybe there is someone I can pay to do it, still waiting to get in touch with the dealer it's a nightmare.
  • Replies 97
  • Views 22.1k
  • DeelyStan
    DeelyStan
    I have just disconnected the touch bar/volume slider using the instructions from this forum. So far it has fixed the issue. If it helps the exact steps I followed were: Remove long trim piece under
  • MartinOctavia1969
    MartinOctavia1969
    I bought it from a dutch company called vd Ven is a dealer in parts for all cars.. I saw that RRR.lt sold them to. Ebay.co.uk has them. But watch the H49 hardware versions there should be a picture w
  • Well, I had another go at disconnecting the flat cable as suggested earlier in this post. I had both, the black and blue plugs connected and the radio was on (not sure if the ignition was also on). I
Did anyone find a solution to this problem? How are your cars infotainments doing now its warmer again? )
I drive 2020 Octavia and the infotainment switches on when the car is locked. Not cool when it turns on in the middle of night and drains the battery.
Edited by jenny12
I take it you've read through many posts on here detailing these issues. I'm not sure software updates alone can help fix your problem, from what I gather a new screen (head unit) is needed, which isn't a cheap fix unfortunately.
Hi everyone,
I just wanted to thank the user omeromeryigit.
Their solution of disconnecting the touch power button and the volume bar was the definitive one.
After searching all over the internet and insisting at the official dealership, the only apparent solution was to replace the screen with a new one. 1500 euros and several weeks with the vehicle out of commission waiting for the new screen to arrive.
Thanks to this thread and omeromeryigit's suggestion, I dared to remove the screen and disconnect the touch power button. Amazingly, despite my fears, it was all very easy and quick to do.
Now everything works correctly (except for the aforementioned power button - I wasn't using it - and the touch volume bar - I control it from the steering wheel).
I saved 1500 euros and everything was solved in just 30 minutes.
Go for it!
2 minutes ago, josecarlossala said:
Hi everyone,
Go for it!
Was your problem only switching on when car was locked or did you also expirience "ghost touches" (random cliks on display when in car)?
600€ for a new display
Edited by jenny12
3 minutes ago, josecarlossala said:
Hi everyone,
Go for it!
I'm not brave enough to do so myself, so I'm having a car audio specialist disconnect it on Friday.
Once it's disconnected, with the unit on presumably, is it still possible to reboot/update the system?
Or, apart from the useless(!) volume bar & the power button not working, is there any other disadvantage?
Edited by alb78
Useful should have been useless
Hello
I was experiencing phantom touches both with the car turned off and locked, and with the vehicle running.
33 minutes ago, alb78 said:
Honestly, it's really easy following the instructions in this thread. There are no additional problems with the power button and volume rocker.
4 minutes ago, josecarlossala said:
Hello
I'm going to try this and hope it will fix the problem. Thank you! The only issue I see with this is that we wont be able to do a hard reset anymore. I usually control the volume on steering wheel too.
I didn't experience these issues myself fortunately, but have read through countless posts on here from those who did. And yes, it would seem ghost touches is quite a common symptom of the problems some people had or are still having.
Just depends on whether or not you think 600€ is worth it, to stop the hassle. That is actually cheaper than I'd thought it would be
  1. Remove long trim piece underneath screen. Start from the edge of the passenger side and pry the trim upwards. Each clip will then release with a bit of pressure.
  2. Remove the cover from the rear of the screen. This for me was the most difficult part. What worked was to gently pry one of the edges up and rock my pry tool up and down slightly until it unclipped.
  3. Unscrew the screen. 4x T20 screws holding it to the dash.
  4. Pull the screen forwards and tilt it down to gain access to the back. Unscrew the metal back cover of the screen.
  5. Without disconnecting anything, move the metal cover back and slide towards the dash along the cables. I.e. do not disconnect the two cables.
  6. Ensure the radio is currently playing (i.e. screen and media are ON)
  7. With the radio playing, identify the touch bar power ribbon using the images in this thread. Flip up the black catch holding the ribbon in and disconnect the ribbon.
  8. Ensure the radio is still playing and screen is still on.
  9. Reassemble
Hope that helps!
A helpful summary. Printed with a couple of the photos in my glovebox ready for the point I can't put up with the weirdness anymore.
Had the same problem with phantom touch and stuff. Thought dealer changes Display but I was told there is MIB Software 1999 which will be updated. I thought 1989 was the latest Version? Tomorrow I will get the car back.
You'll have to let us know if there is a 1999 update
So the displayed software version didn’t change. What I can see is, in the Update Menu they tried installing a „MO13_RECOV_R9900L“ but in the log it says only Post script was done and no other components updated. So I don’t know what they did.
Does anybody know, if there is a TPI for this problem with the Display?
Edited by blackh0le
I have the same issue with my Octavia. Two days ago, the car was parked in the sun and locked, and a neighbor told me there was a loud noise coming from my car. Also, the radio sometimes gets louder on its own while I'm driving. I think that is a software glitch.
Is v1941 the latest OTA release?
1989 is the newest version.
As far as we know this is hardware related.
Yep that is correct. The hardware Version h44 is the problem.
The H49 hardware Version is build in end 2023 and newer. You can replace them without any problems. I have mine for 10 months now. Untill now no problems
I have a paid subscription, but I didn't receive the OTA update to 1989.
Thank you very much for the information. My car is out of warranty. I will see what I will do.
The ota is not that accurate. It is possible to do the update yourself. I don't have the software anymore. It is written here on the forum how to.
Change of the screen is really simple but a good screen will cost around 400 to 600 euro.
New around 1000 to 1200
Hope you will found a solution.
Otherwise the volume slider disconnect. Then the problem is also solved.
This is also to find here on the forum
