Activating SmartLink on Swing 3
Thanks!!!
  • Replies 179
  • Views 37.5k
  • You Guys are amazing! Thank You for all. Everything Works perfect! Keep up the good work
  • Worked perfectly but it was to hard to get it readed the clap is tricky i Have unsoldred and soldred back
  • I think more for a connection by enet cable and telnet unit but need to deep more to know how to access and have only 1 unit so I won’t take adventure to brick it 😂😂😂
Is this wiring good?
I don't want to brick it :D
On 06/08/2026 at 13:51, pocem said:
Nvm, I got it. Thanks for sharing :)
Hi
Is it possible that I've disabled the USB read function?
At first, I thought I was using the wrong USB cable after the activation process, and I tried about 10 of them and two phones - neither the radio recognized the phones nor the phone recognized the radio.
I dug into the USB port and checked its number: 5Q0 035 726 M (black port) - it should support Android Auto.
Then I decided to connect a USB flash drive - the radio doesn't recognize it :/
It worked before - I changed the station logos to color ones.
Skoda Rapid 2017
Radio number: 5JA 035 871 C
MIB: MEN2_EU_SKGPX_P7130L
24 minutes ago, yolewap said:
Hi
Skoda Rapid 2017
It is not common problem, try hard reset of multimedia with long press power button until logo show up. If still not working, try reset to factory settings whole unit.
And last step would be to check with diagnostic tool for faults or posssible wrong coding/adaptations.
Recently Browsing 1
