Light Assist Retrofit
Recommended Posts
Just taken a call from my dealer - they have retro-fitted the Light Assist and confirmed all works as expected, though it took them all afternoon to do it! :eek:
I shall of course be confirming that myself when I collect tomorrow evening. The dash had better not be rattling now!!
Link to comment
Share on other sites
Can Coming/Leaving Home lights be activated via VAG-COM?
I haven't got the tunnel lighting icon on my lightswitch but the door mirrors do have the door lighting area lens fitted, not sure about the electrics inside though.
Car is a 56 Octavia 1.9 TDI DSG Hatchback.
If I turn off the ignition with the lights on dip beam they switch to sidelights only and do not go out after 80 seconds.
Thanks.
Link to comment
Thanks.
09 central conv
long coding
byte 0
tick bit 5 and 7
Link to comment
As mentioned earlier in this thread...
In addition to what Stu says above, you can make them stay on if you had your lights on when you came home too. In fact you don't need to turn the light switch off at all during the winter. No flat batteries and no annoying screetch when you open the door!
Mark
(If you don't have VAG-COM and are ever nearby I can set this up and more for you. Shiraz preferred :drunk:)
Link to comment
Got myself confused by the manual re coming home lights feature.. Can anyone explain please?
At night, I unlock the car, the headlights come on - as expected, great stuff. But when I get out and lock the car at the end of a journey, the lights do not illuminate. I thought "coming home" meant it would light up - ie effectively lighting my way to my front door - that makes more sense.
Or do I have to play with the lights dial? Seems kinda crazy... Is it possible to do this with the mighty VAG-COM?
Otherwise I shall have to rename this feature, "show me the way to my car lights" :D
Link to comment
Checked Maxidot - "Leaving home" is set to 30s. So I unlock the car, lights come on, everything's dandy. When I lock the car, the lights do not come on :( Am I doing something wrong or is my Maxidot playing up? All this with the Tunnel icon selected via the light dial.
Link to comment
Theres a setting for leaving home and arriving (not sure if thats exactly what its called, have a look again).
Link to comment
Should work as follows:
With switch set to tunnel setting
Arrive home in dark with lights on
Turn ignition off - lights stay on for 30 seconds
Get out of car, lock car.
Lights should stay on assuming you are still within the 30 seconds.
Setting is as follows:
Get in car and shut door
Turn light switch off
Turn ignition on
Maxi dot will show MSD then 'Please fasten seat belt'
Hold bottom switch on stalk in for about 4 secs.
Display should change to 'Settings'
Scroll down using switch on right of stalk to Lights & Vision
Select Coming Home - display should show 10, 20 or 30 secs. If there are dashes instead then the coming home function is turned off
Change to 30 secs.
Check the Leaving Home settings in the same way.
Turn light switch back to Tunnel setting.
If Arriving Home is missing from display then there's something wrong - back to dealer?
Link to comment
Turn ignition on
Change to 30 secs.
I haven't tried driving someplace first, just unlocking and then relocking but...
Followed this through, I only have Leaving Home option in Maxidot, which is set to 30s. I don't have Coming/Arrivng Home option. Looks like a trip to dealer for me. I'm assuming this coding was missed off when the Light Assist was retro-fitted and a VAG-COM hook up will sort me out? Slightly anxious its because it was a retro fit and not factory fitted... :confused:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
