Denied joined the community
Are front doors the same on estate & saloon?
Dau has wiped the passenger side of my 2017 1.6tdi estate down another vehicle on the M1 (all safe thank god). I'm thinking just replacing the doors might be cheaper than getting them mended & there seems to be plenty on eBay. Clearly, the rear door is specific to the estate but what about the front? Are the saloon & estate the same? I can swap all the internals inc wing mirror so I'm assuming trim won't matter, just the race blue paint code. Simon
simonkbike started following Are front doors the same on estate & saloon?
Skoda Swing Firmware Update - MU 8755
- Yesterday
Shkodal joined the community- Skoda Swing Firmware Update - MU 8755
@pab567 hi pls you can sent me the link to the MEN2_EU_SKGPx_P0080L_8755 download. I have a massive problem with connecting ani android Phones and androidAuto. The USB connector is ok, cable is ok android & androidauto is uptodate. I don't know what else I can do.Miso3000 started following Skoda Swing Firmware Update - MU 8755- barn find felicia pickup.
ah, seems these HEROs have the vague guide I need! https://www.youtube.com/watch?v=pRWqAoYIfCI- Lowering Springs
The springs lowered the car 20 mm. The rims r Rotiform LAS-R 19x8.5" ET35. Tyres r 245/40R19.- Skoda octavia Rs Crtdi combi 2014
First check that the microswitch in the door is giving a signal to the system by checking that the door open icon is showing on the display when you open the door. Is the passenger door and rear doors the same?- How to lock keys inside?
App doesn't offer this functionality on older mk 4's, mine from 2020/21 isn't supportedscotthugh3s started following How to lock keys inside?- Skoda octavia Rs Crtdi combi 2014
Hello everyone. My question is: the interior lights don't come on when I open the doors. What should I check, and how? Could it be that the panel in the overhead trim needs replacing? Thanks to everyone for the help. @Isu1977 Kérjük, vedd figyelembe, hogy a Briskodán az angol az alapértelmezett nyelv. Hozzászólás írásakor kérjük, használj fordítóeszközt.- Sportline 85
Went for Graphite Grey metallic. Staying low key, although was tempted by the velvet red!- Show us your Kodiaq Mk11
Here is my UK 2026 2.0d 150 SE L. Love it so far. A few frustrations with some of the tech, but thats the nanny world we live in now I guess.- Hello there.
Hi there, thank you for accepting me. Its great to find an old school forum for the skoda. Just bought a mk2 Kodiaq Sel 2.0d 150 back in September so its a 2026. Loving it! Sold my 2014 mk7 golf in 2021, went to a focus estate, biggest mistake of my life! Glad im back in the VAG family. Looking forward to getting to know the community. Catch you soon.- Hello Sportline Estate
Appreciate that! Always handy to know someone with tools like thatDerk2d2 joined the community- Crazy Fuel Consumption 1.6TDi Elegance 13plate
Typically you don’t bring 6 year old threads back…. That said are you doing long or town journeys? If short journeys then the first few miles when cold use much more fuel. Otherwise check tyre pressures and try replacing the fuel filter and air filter. The number of diesel’s see thumping out plumes of smoke, because the filters clearly haven’t been maintained. One other thing to check would be that the oil/filter have been changed and you’re not driving around with treacle in the engine.- Hello Sportline Estate
Skoda dealer will definitely be able to print you off the build sheet from Erwin. I used to have access but my account got revoked as they don’t allow private people access anymore. I did manage to download all the workshop manuals for superb if you need any. Won’t have your engine and gearbox but all the rest will be relevant.- Hello Sportline Estate
That’s mad. I was speaking to Skoda HQ today. Trying to find out all the build specs for it. Not sure if the buckets are heated. Collect weds morning and can’t wait!- How to lock keys inside?
If the situation requires you not to take your electronic key, why would you take a tablet or smart phone with you?- Hello Sportline Estate
Also. Fun fact. Your reg starting with K makes it likely it was a car of VAG management as it’s first owner.- Lowering Springs
How low are the springs? What’s your wheel specs for aftermarket. Looks what I’m after!RogueFabia started following Lowering Springs- Crazy Fuel Consumption 1.6TDi Elegance 13plate
Hi I have the same problem here 40 mpg I’m expecting 60 mpg at leastkimo started following Crazy Fuel Consumption 1.6TDi Elegance 13plate- Every day’s a school day!!
I also see it makes sense, however it still came as a complete surprise. Bit like when I had a BMW 5 series and tried to reverse into a part of our drive, opened the door to lean out and look back and it slammed the brakes on. I’d been doing that trick for decades when it was needed, but not in the beemer! Will try that in Skippy when I get back from Morocco. 👍- Hello Sportline Estate
I also upgraded from a Fabia although I that was a downgrade from a previous superb. Eibach pro kit is the go to for lowering. Have a search on this forum and there’s a table to choose the correct kit. Not done it to mine yet but it’s on the cards potentially. Lots of things you can do on a relatively small budget. Mostly mine has been fixing up issues plus some styling mods including all LED bulbs. Made my SE L into a sportline lookalike.Binx1310 started following Hello Sportline Estatecaocongtien48 joined the community- Car Shudders Various Lights Come On Goes Into Limp Mode
UPDATE: 2 weeks on from the crankshaft sensor replacement and , touch wood, no sign of any issues. If things change, I will let you know. Thanks for all the advice and input, its much appreciated. Tony- I need Bolero Update :-)
@pab567 It looks like you’re the guy to help with possible CarPlay upgrades. here are photos of my hardware, software, and firmware packages. Is there an upgrade path for my 2016 Octavia Mk3? VIN <Removed>Tondi007 started following I need Bolero Update :-)- Rogue Fabia - MK2 Fabia Monte Carlo
So I’m trading in my 2014 MK2 Skoda Fabia 1.2 TSi For a 2018 MK3 Superb Estate Sportline 1.5TSi 150 Fancied a bigger car from the fabia, didn’t want Octavia’s like most upgrade to, and always fancied an estate! I absolutely love the interior on it (unsure if my buckets are heated) And there’s about 5000 toys I’m going to need to get used to! Do plan some mods Aftermarket wheels Remap And workout best way to lower it. Honestly I can’t wait now Show me your estates 👌
