  2. Good effort getting them both from the top! Coolant use has slowed a bit since doing the bypass, but still having to top it up, might just be air purging out. I did run the coolant bleed though so should have got most of it out, but didn’t vacuum fill it or anything
  3. Is yours a hatch? Does the hatch not have a heated rear screen?!
  4. I’ll send you a message with link to the manuals which may help.
  5. Today
  6. Did you find out what was up with yours ? I managed doing the bypass from top of engine but deffo needed a 21 or 22mm connector because the coolant hoses where a bit slack on the 19mm but I fastened them on with jubilee clips really tight so hopefully will hold .
  7. I just finished work and the windscreen was frozen…. 1st time using the heated windscreen… wish the rear screen had the same system
  8. A few recent photos....................
  9. Made an error when I removed old top mount. I didn't notice which way it was located in regards to the tab where the bearing locates
  10. You bolt a piece of 4x2 wood to the anti roll bar drop link connection and jack it up to compress the spring. If you have spring compressors then I assume you can just compress the spring in situ to the same effect. The secret seems to be the positioning of the expansion tool and how you wiggle the brake disc.
  11. Thankfully have use of another vehicle. I undone pinch bolt , compressed spring and man handled the shock out. Whats the 4x2 method? As will be doing the other side.
  12. I hope you have alternative transport! This is always my fear when doing a job such as this; not having sufficient parts to get back on the road and no way of getting them! Did you split the hub to take the strut out or use the 4x2 method to compress the spring?
  13. Oil got expensive recently thanks to Trump.
  14. thsts tomorws job £51 FOR A OIL AND FILTER OUCH
  15. When you say high mileage, how high?
  16. ŠKODA now want to keep my car for 48rs and reapply the grease then keep it in the workshop overnight to see if the noise returns. I have told them that I can guarantee it won’t return after 24rs as the grease resolves the issue until it wears off. Again I’m keen to know if anyone who has this issue has any paint treatments applied. I’m going to have to let them keep my car for 2 days which is a total waste of time.
  17. Filter will do that for you, it doesn't mean there's no debris anywhere. See how it is after oil and filter change.
  18. Ben23 started following Skoda Karoq
  19. So finally got around to tackling the top mount. Total ball ache. Then noticed what you guys have mentioned. A jagged end to the spring. Was at the very top. Just out of site. I did hit a big pot hole a couple of weeks ago . But was on the near side.
  20. mvasev joined the community
  21. kzolee joined the community
  22. Hi everyone, I'd like to share my experience with the same door creaking issue on my Skoda Kodiaq Mk2, manufactured in July 2025 and purchased new in January 2026. I've been investigating this problem for some time, and my observations are very similar to those reported by @Marcinek and @minimumcharacters. Here is what I've found: The creaking noise disappears when the windows are slightly lowered, even without opening them significantly. Cleaning the upper flocked/felt door seals noticeably reduces the noise, although this does not appear to be a permanent solution. I also experimented with masking tape at the contact area between the upper seal and the bodywork, which helped me investigate the source of the noise. My Skoda dealer adjusted the door strikers, but this did not conclusively eliminate the creaking. Based on these observations, I strongly suspect that the noise is caused by friction between the upper flocked door seals and the painted bodywork, particularly when the body and door frames flex slightly during driving. My impression is that the pressure exerted by the fully closed windows may also play a role, since lowering them immediately changes the noise. I believe this is primarily a seal-to-body contact issue rather than a loose component inside the door. I haven't yet found a confirmed permanent solution. In my opinion, the most promising approach would be to investigate the seal material, the contact surface and the door alignment rather than relying exclusively on lubricants. I would be interested to know whether anyone has achieved a lasting solution through seal replacement, anti-friction tape or a specific adjustment recommended by Skoda. Thanks to everyone who has shared their findings. This thread has been very helpful in understanding the problem.
  23. skoda_kodiaq joined the community
  24. Ben23 joined the community
  25. Might be debris in sump pick-up strainer.
  26. changed the oil pressure switch; however, when the car is running, the level on the dipstick shows low but stopped its normal oil and filter change tomorrow
  27. Interesting.. thankyou
  28. Thanks, I’ll try that.
  29. Thanks @Carlston . I have a Greenline model which I think may be lower than standard models for efficiency, perhaps adding to my problems?
