Nazel76 joined the community
Skoda Superb iV - Factory paint thickness specifications / tolerances?
The workshop manual does have information on paint - I’m not able to access it now, however, but maybe somewhere to look?
Final Drive Service?
Do make sure the above service items are adhered to - no dealer acknowledges that the DSG has a replaceable filter, for example. It would be interesting to see/hear about the condition of the fluid in the diff. While 50k without a service isn’t good, I wouldn’t be overly concerned just yet. You don’t know what sort of use the car has had, so it may be absolutely fine. I would go to a decent indie however, rather than a dealer. Whereabouts are you based?
Interesting. For paint thickness I’m not sure you’ll find anything that will hold them bang to rights. Although some of those figures sound horrendous - not sure my NexPTG would read paint that thick. As for recourse on damage, having always had a weird shape in my rear bumper since buying it at 6m old from a Carr’s Exeter in Sept ‘21 as the GM’s company car, and now having been hit up the rear last week, you can see evidence that the rear bumper has been damaged and filled before respray. They never mentioned a thing - I wouldn’t have cared. I’d never get anything from them but it was a **** move by them.
Photography Thread
Photography Thread
Best I could manage with a cheap Amazon cardboard and plastic solar filter And the sunset after the moon made way
AC coolant level/ system function indicator?
So, which of the very many live data parameters (or, is it not in live data) gave information about AC system pressure? thanks,
Ball joint to control arm joint torque spec - wildly different for pressed vs cast steel arms?
Ok then. Let's hope the studs are made of some pretty amazing steel to take that torque without snapping.
Kodiaq towing speed warnings
Hi I am a new Kodiaq owner and when towing on a dual carriageway and several motorways, I am getting a towing speed limit of 50 mph when the actual speed limit is 60 mph. Is this a known issue and is there a fix to this? The tow bar, electrics and towing display seem to work correctly in all other respects. The tow bar and electrics are Skoda supplied and fitted.
Erewash100 started following Kodiaq towing speed warnings
Thanks @Breezy_Pete , yeah, guessed that; now, is there any way to get out of the system when that happened? We know that the system had been low (I had it recharged, and the amount of gas extracted was almost 50% low; I took these recordings after the recharge); my OBD11 never reported any faults in this system 🙄
vRS Owners, cars with a VAQ front diff, a question on the servicing and what you are being told at Skoda Main Dealerships?
Bump for @CC300ZX
Garciasfinger joined the community
JD52 started following Third brake light removal estate mk3.5 VRS
hello from me
Hi from me as a new member. Looking forward to seeing what goes on.
Erewash100 started following hello from me
Hiya all My third brake light has decided to crack and I'd like to replace it, however I'm struggling to find any youtube videos that show how it all comes out. Has anyone done one before or does anyone know of any videos that they have links to? Might be worth mentioning ive got a Combi/Estate VRS so ive got the spoiler above it aswell. Many thanks Kyle
KyleHa started following Third brake light removal estate mk3.5 VRS
Erewash100 joined the community
Hi all: Is anyone able to do a VAG Service history report for me please (Skoda Superb 3)?
This is really brilliant help. Thank you so much 😄
Thank you so much. You Guys are the best. PM Sent. Many, Many thanks. 😊
The reported shutoff due to low pressure event would be a clue pointing you toward lack of refrigerant, I expect.
You will not find any data for 'AC clutch' as the Mk3 A/C system doesn't have one - the compressor is permanently driven via a sacrificial shear plate.
Warrior193 started following AC coolant level/ system function indicator?
AlistairR joined the community
OCTAVIA 3 PARTS
Maxton design Honeycomb grill for facelift VRS, never fitted, £65 posted. Racing line intake kit, Gen3 888, airfilter, grill rear blanking plate, Turbo inlet elbow, silicon hose, never fitted, £145 posted. kit to convert bonnet to strut opening, never fitted, £15 posted. Powerflex Dogbone mount and new bolt, rear anti roll bar bush, £20 posted. These were bought for 2019 VRS 245, never fitted as I changed car.
MikeTheThinker started following OCTAVIA 3 FL
OCTAVIA 3 FL
LED Lighting. puddle lights, dynamic indicators, boot light, interior lights, never fitted, from Kopacek. £30 posted. Footrest for RHD manual models, not sure if it fits DSG, Never fitted, £15 posted. OEM cargo nets red/black, these have been fitted, £25 posted. OEM mudflaps, never fitted, were bought for facelift VRS hatch, £30 posted. Team Heko wind deflectors for hatchback, £20 posted.
For factory options / build codes I got mine from ebay. A guy in Italy emails it to you in a couple of days or so. Then print iff. Cost about £3 or less (via ebay uk). Just search for “vin decoder VW/Skoda”. Seller has a name like “ glavaneski”. Edit: ( got the original info of the source from earlier posts on this forum)
Hi, thanks for the reply and very helpful. I'll get the final drive done asap then and keep on top of it now I'm the owner. Appreciate your help 👍🏻
I can get brief VAG service history. Just PM me the Reg number. Thanks. AG Falco
Battery Problem?
BCM replaced, all ok. I didn't tell them what the other garage diagnosed, wanted to see what their diagnosis was.
agarici20 joined the community
Pete's Rescue Roomster
The roof doesn't open, only the blinds do. So no drains.
Mence changed their profile photo
I’m on my phone so I will be brief. They are NOT the same thing. In VAG documentation, the VAQ LSD service is referred to as “final drive oil”. The recommended service interval is every 30,000 miles or 3 years, with some sources saying that the MQB Evo cars (2020 ono) want this done every 20,000 miles or 2 years. At this service, you need to replace the oil, and clean the pump screen/gauze. It’s the same principle as the Haldex AWD system (most VAQs are made of Haldex bits, although newer ones are… Borg Warner… @Cairus?) Perhaps @Evolution13 can find the thread from a few months ago where there was a big fight about updated intervals on the Mk4. The DQ381 service is advised to be done every 80,000 miles. This involves new fluid and a replacement filter. That said, every DSG box has an interval at 40k, aside from the 381 (80k) and 200 (sealed…). Most don’t trust this and, myself included, choose to get it done sooner. I have recently done mine at 40k, and will be doing it again when it hits 80k.
Stage 1 remap
Where are you looking to get it done? Is it a 230, 245 or TDI? I’m not sure what tips are £1100 - do you mean the backboxes? The modes will remain the same, albeit with more performance at each setting. You are able to tweak some stuff (like having full power in RS, stock power in Eco, etc), but I’m not sure how straightforward that is. Perhaps @Cairus might have some idea?
