  2. I have I idel in my Skoda fobia Monte Carlo 2016 1.2. I have changed the throttle body and spark plugs but, still ideling and the car goes to lump mood. I'm getting the sign for EPC traction sign. Sometimes engine sign. Can someone help me please
  3. qais started following Skoda fobia 1.2 2016
  4. Recently purchased a mk3 superb Upon a detail came across a kodiaq rubber boot mat This doesn’t fit the superb And also it’s something I don’t want Anyone local to south wales interested in it? Looks like this But can get a photo when I remember
  5. Correction 21 plate ( can’t find how to Edit post)
  6. qais joined the community
  7. Today
  8. pamparam joined the community
  9. You don’t state what engine and gearbox you have and if 4x4 as that will all impact what’s included. E.g petrol will need spark plugs, DSG and haldex for 4x4 have servicing requirements. I have a copy of the Skoda service manual that lists what’s included in each level. It’s more than 20MB so I can’t share it here but I will send you a link to download it from as a PM. As others have said, out of warranty I wouldn’t use main dealers. I find them very regimented in what they look at and I have had Indy garages pick up on things dealers haven’t. They’re also horrendously expensive. The best option is a VAG specialist Indy that uses parts from TPS (genuine parts).
  10. This may help To dim the infotainment display for night driving in a 2025 Škoda Superb, use the quick-access control center or display settings: • Swipe down from the top of the infotainment screen to open the control center, where you can adjust the brightness slider directly. • Switch to Dark Mode by going into the display or vehicle settings and selecting the dark/night theme so the interface colors invert and reduce glare. • Adjust map settings separately if you are using Apple CarPlay or Android Auto, as navigation apps often manage day/night themes independently under their own internal app or phone settings.
  11. Depending on where you live the prices are higher than I’d expect. You need to check what work and when it was carried out. If the Brake fluid is 3 years old or more then it’s needed. A “full” service by an Indy should include the rest including filters. Ask to see hte old filters to give you an idea of how long since the last change. Many dealers charge and don’t change (some indies as well of course). I always use the same Indy as repeat business (3 cars from the family) normally insures good service and reasonable prices. I’ve been using my indi for 9 years now since we last moved house. I can roll up and he will top up my oil if the lights comes on for free….. I haven’t needed to do that with my previous Passat or current Superb. His prices are at least 15% below the dealers
  12. Tbh those prices are mental... Over £70 for a pollen filter that probably costs a tenner and takes 5 mins to fit... Likewise an air filter??? At 7 years old is use an independent and just ask for this elements the dealer has advised if you want them. Otherwise just ask for a full service which at an independent would probably include more anyway for less cost.
  13. Yes it’s strange. I think it just needs to see a different number in the serial number field so it knows it’s a different battery. Interesting yours was set to all 1s as that’s what mine was when I changed it and it definitely wasn’t OEM battery. Perhaps it had never been coded properly at the last change 🤔
  14. I bought Bosch A864S wipers ( aero twin) from Amazon for the front of my 22 plate karoq sportline 1.5 tsi after inputting my reg it said they fitted, but after trying to fit them, the driver side was a little tight, but fitted, but the passenger side will not fit at all, has anyone had this issue & found the correct blades without having to go to Skoda & getting my eyes taken out
  15. Hi, New battery installed and recoded. Battery S/N is really bullsh*t. OEM coding was JCB (for a Varta one) and S/N did not match the BEM code stiker on the OEM battery, simply 11111111111. I then simply set VAO for my Varta and then 11111111112. Done.
  16. OK, with those 14 way connectors unmated use meter set on dc volts to work out which half of the connector has pin11 at 12V when ignition is on. I'd imagine it will be the side with female contacts rather than pins. Then put that connector aside and on the other half measure resistance from pin 11 to battery negative. See if it looks like a dead short. Then unplug MAF, PAS 4-way connector and oil level sensor if found and see if that short is gone. If it has gone, reconnect those items one by one to see which is causing trouble.
  17. Thanks, sorry for late reply! Yes does look like TRF since the fuel filter cap and the wheel nut caps were destroyed with something the attacked the plastics. AI suggests using a Magic Eraser to strip off the damaged layer and protect with Solution Finish - Black Trim Restorer.....perhaps when I am feeling brave!
  18. Don’t think I do haven’t checked if not what’s the way forward because I am also getting a code from the obd for the maf but unplugging that connector has stopped the fuse does that mean it’s on the other side of the connector (female) or closer to the battery
  19. List is what I have told you already: Power steering pump MAF Oil level/temperature sensor if fitted. There could also be wiring damage shorting the black/yellow wire to chassis (or even another wire possibly).
  20. Good start. No oil level sensor in sump?
  21. I guess you didn't answer the question about still having the original motor because you threw it away? Which country are you in?
  22. I u plugged that 11 pin connector and the fuse didn’t pop straight away maybe 1 step closer?😁
  23. ConnyG91 joined the community
  24. Cracking view at Fairlight this afternoon, looking East towards Little Cheyne Court Wind Farm on the left and Dungeness on the right: Gaz
  25. Hi everyone, I'm a bit confused about the service naming conventions used by Škoda dealerships and would appreciate some advice. My Škoda Superb is a 2019 (69 plate), so it's now around 7 years old. The dealer has recommended the following work, based on the relevant service intervals: - Oil change and inspection service – £278.54 - Extended scope inspection – £84.00 - Air filter – £45.91 - Fuel filter – £82.98 - Pollen filter – £72.90 - Brake fluid change – £100.49 My question is about how these services compare with the options advertised by independent garages on BookMyGarage. I normally use BookMyGarage to find better prices, but independent garages don't seem to use Škoda's terminology. More importantly the secret service garage which is the same dealer garage use the below. Instead, they advertise: - Interim Service - Full Service - Major Service - Oil & Filter Change Am I right in thinking that the work recommended by Škoda would essentially fall under a Major Service, as it includes the various filters listed above? A few specific questions: 1. Is Škoda's Oil Change and Inspection Service essentially the same as an independent garage's Oil & Filter Change? 2. Does combining the Oil Change and Inspection Service with the Extended Scope Inspection make it equivalent to a Full Service? 3. Would a Major Service normally include all the filters Škoda has recommended (air, fuel and pollen). 4. If I book a Major Service through BookMyGarage, is there anything specific I should check to make sure the garage carries out everything Škoda has quoted? I'd ideally like to use an secret service (skoda dealer) because BookMyGarage often has significantly cheaper prices, but I want to make sure I'm comparing like for like and not missing any important maintenance. Thanks in advance for any advice!
  26. Hi, I want to update my Skoda Kodiaq infotainment unit and unlock SmartLink. My current system details are: Part number: 5Q0035864B SW Train: MST2_EU_SK_ZR_P0361T Could you please send me a direct Google Drive or Mega link to the MST2_EU_SK_ZR_P0369T firmware update and the MIB STD2 Toolbox? Thank you very much for your help!
  27. mailo7303304 joined the community
  28. I own both devices myself and have updated them with the same firmware.
  29. Stupid question but is ATA Confirm ticked in the Maxidot display?
  30. suoerb2019 joined the community
  31. Could be a bad door switch or as said ignition switch. If its a door switch are there any door open lights on dash when all doors closed. Check also that puddle lights come on when unlocking car. Also switch on radio and remove key. The radio should go off. If it doesnt it points to ignition switch. Alasdair
