gumdrop
Everything posted by gumdrop
  1. I liked my 1.6 turbo diesel Fiesta Ghia and the other very quick Fiestas, The Ford Focus 2L diesel, my two Deux Chevaux, Clubmen, fitted with front air dams, my two Yeti which I adored the Fabia 1L Monte Carlo estate, and my current Kamiq Monte Carlo
  2. The car must be level and not tilted on a camber. After the engine is hot (or warm) enough leave the engine to allow oil to run back off any surfaces and back to the sump. Wipe the dipstick, check the level. The top and bottom oil shown in the photo indicates oil thrown up the dipstick tube and the current oil level, the oil having not had time to drain .
  3. Members 1.6k Location: Bristol Model: Yeti Elegance Outdoor 2WD 110ps EU6, Fabia Combi 1.0L 110 Kamiq 1.5 DSG Monte Carlo Posted yesterday at 16:07 I am currently using 128gb usb sticks for my music, can the system handle 256gb? Quote
  4. I am currently using 128gb usb sticks for my music, can the system handle 256gb?
  5. What is a user profile? and why do you have to be reminded of it in your car? I could never see the point of giving away personal information to the next owner or the skoda techs.
  6. I had not used the Panoramic roof, so I gave it a try. It rained and rained, it was interesting to watch the underside of a storm 😄😄
  7. My first stop start Yeti (being unfamiliar with stop start) I used to stall because the revs stayed too low to pull away safely. Increasing the revs manually solved the initial problem.
  8. I had this sort of torque wobble on another make of diesel car. My trusted independent fitter suggested a look at the engine mounts; One mount with rubber coming away and the others soft all changed, what a difference! even the handling improved.
  9. What is the milage? and typical usage?
  10. This happened to me several times usually in the same area, a hill overlooking toward Bath. If I stopped and turned the ignition off it would go away, but I took it to my dealer in Bath. They ran diagnostics and told me there was nothing to worry about, bring it back next week. I did and they did a software update, no further troubling false alarms.
  11. gumdrop replied to Doofy's topic in Škoda Kamiq
    Where was it? which model Kamiq do you have, mine is a Monte Carlo.
  12. I refused it, it was added on without me being asked and any paint damage meant a complete re-application at my cost. .
  13. I forgot to mention, I acquired some "boot nets" that hold a lot of my boot junk. These lift out in minutes, should I need the boot space, and are just as quickly restored. *Problems? Leaves settle in the scuttle area (where the wipers hide) this needs to be kept clear. Green "moss" along the window seals. No matter what I do bearing in mind that any chemicals used wind up inside the doors and may cause corrosion.
  14. Mine has had no odd noises that I can think of. The Lioness loves the car and can trace most noises, squeaks especially, often only need a tiny squirt or wipe of silicone polish or similar in dashboard joints..
  15. I love the DSG gearbox, the big wheels, it handles well enough for me. The fuel economy is very satisfactory, The seats are amazingly comfortable (Monte Carlo) my only concern was the lack of boot space for tool kit , tyre inflator etc. BUT with the seats down I got 2x 290 litre bags of pruned shrubbery in the back plus a couple of rubble bags.
  16. I think it was around 1500rpm but it was back when the Yeti with Ad Blue first came out say 6-8years ago.
  17. The first regen I had, as I recall, I had arrived home and parked on the drive. The engine was revving and the heat and smell was tremendous, I thought the engine was on fire and ran the car back away from the house and shut down the engine! All was well but it finished off the regen at the local roundabout engine revving and fumes causing other cars to shun my vehicle.
  18. I had engine mounts that flexed more than they used to and in turn caused something else to rub and squeak. They were not damaged so I just sprayed some silicone plumbers spray on them and any other dubious areas . I also rubbed some on a cloth around the plastic edges of the dash and glovebox etc. where they meet the bodywork. Whatever it was I got it.
  19. gumdrop replied to Moggo's topic in Skoda Yeti
    The spot you indicate must be at the extreme end of your wiper blade, I fitted Bosch blades as the originals (on a new car) tore apart while on a trip to Norfolk and had no trouble since.
  20. The rear sill protector, almost a must have. A metal grill to protect the Air-Con radiator!!
  21. There is also the small matter of cost of living rises. Food, fuel, electrickery and gas, and in some cases the 3-4 holidays a year even these cost more😄
  22. Could you say which 2013 mk2 model you have and the make, model, of caravan you have, please this will possibly get you help quicker.
  23. Top two suggestions so far Shin-Etsu grease from Honda and Gummi Pflege
  24. Well this may be a useful start; https://www.lovetoknow.com/home/cleaning/how-keep-rubber-from-cracking-protect-preserve
  25. Thanks but this requires disassembly to slide the tubing on, I think it will end up being silicone taped. * I am now looking for a rubber preservative*
