Everything posted by gumdrop
Cleaning the inside of the windscreen, what to use.
Thank you all very much for your suggestions, I have some isopropyl alcohol, I will give that a try first.
I cleaned off ice and snow from the outside of my car windows but the inside of the windscreen has smears that won't come off. My screen wipe cloth is new never used before, older clothes are hand washed and rinsed in hot water (twice) any tips?
Replacing discs with brake pads
There is a measurable thickness for both pads and rotors before replacement. I'm sure someone on here will be able to supply figures.
Weird Error Message (Only Leave vehicle in Position P)
I watched a you- tube video recently where super glue and cigarette ash were used to form a replacement hinge or latch.
Climbing Performance
I had a pinky blue Clubman 2cv and later a white one I fitteda front air dam to both which helped the flat out speed to 75mph I was greatly influenced later when the Citroen Palas (?) 1300 motor was found to be a good fit. They both had the inboard disc brakes
I drove a 600cc 2CV 30hp if I was in the way of a more powerful truck (provided it was safe to do so) I would move out and let him by then quickly get behind and slipstream him (this is an unsafe maneuver)
Headlight condinsation - anyone else getting it?
As you get older you point the boot to the prevailing wind and the engine to the sunshine, automatically, can be applied to people as well! 😀
Park facing the sunshine (on a day with sunshine forecast) 😀
Lights fault
When you say Headlights do you mean Mainbeam or Dipped Beam? When it is dark(ish) my lights come on, usually with a message "Turn Your Lights On" referring to the light switch.
Lower back pain
Many men carry their wallet in the back pocket, then blame the seat! The seat squab nose is another nasty area as it reduces bloodflow to your legs and feet and may even affect the return flow to heart and brain. Just an aside, Target shooters used to put their wallet under their shooting armpit to slow the pulse and help keep the weapon steady. Look at really expensive car seat front edges they are well designed.
Lower back pain
I had a lot of back pain and was being treated by a chiropracter, there was no relief so he finally X-rayed my back, my lower back was shot I had three discs worn to a wedge and ended up with an eight hour operation. If you have back pain see your GP and ask for an x-ray, I spent years with back pain and doing nothing just made it worse! One thing I learned was not to drive with a Wallet in your back pocket, this can affect your sciatic nerve.
Mini USB ports - Karoq 21 registration
I use USB 'C' to usb 3 adapter Right angle cables around 6" (150 mm) long, Amazon
Memory stick issues
I use usb-3 memory sticks 32k or 64k formatted fat-3 and these run fine. I download music videos from you-tube using this app. https://ytmp3free.cc/en/
Kamiq Monte Carlo Cornering Light
Thank you both, I rather liked the swivelling cornering lights, but the fixed extra corner lights might be useful for carpark manouvers.
Wading depth
A rule of thumb for wading a vehicle used to be, No Deeper than your wheel hub centre but some say sill height. https://drivingfast.net/driving-in-deep-water/
Wading depth
I think it actually accepted the whole long wheelbase Land Rover in one swallow 🤣
Wading depth
My brother in law drove through water across a road known well to him. What he didn't know was erosion had dropped the road surface a few feet.
Dampness in the Passenger Footwell
As above, leaves in the wiper trough I park near a hazel shrub and have to clear leaves out before every run. PS I even had a squirrel stocking up nuts in the trough once.
Heated Steering Wheel
Only ever had heated seats on Yetii but they always heated up quickly. I was alwaysdoing a bigger milage then so the battery was always well up.
My Monte is a little older so could you explain cornering light, please My Yetis (or the first one anyway had moving lamps for cornering.
End of the Fiesta
I had and enjoyed Fiestas for years my top car was a 1.6 diesel Ghia beautiful car!
Wheel nut cover tool
I could not find my tool so I phoned the dealer who said it is there in with the jack etc. in the polystyrene block . Sure enough it was there just difficult to see. I bought a couple more from E-Bay. DO NOT let tyre fitters have them, they always "Forget" to give them back.
Sudden braking for no reason
I had the bang and sudden stop when exiting a suprmarket car park to turn right onto the main road. As I pulled forward a car pulled up to a postbox almost directly opposite and stopped, detected as a threat the brakes came on. There was no moving traffic, the road area was about four cars wide.
WiFi speed checker recommendations
Is the WHICH speed checker still operational.
- Seat covers for Monte Carlo
