Everything posted by StevesTruck
What's the purpose of the Octavia 4x4?
Having done a couple of 80 mile round trip commutes in the ice and snow in my 2wd 1.9 DSG.... I can see very much the point in the 4wd version. Mine's terrible at winter driving
2014 vrs tdi engine squeak sound.
If I'm doing a stab in the dark, I'd say it's going to be a roller/pulley/tensioner. Did they say were replacing a full kit? Is it worse if you start the engine from cold and stick the headlights on (basically load up the alternator)?
Front wheel bearing
Yep, doing that with it on the car worked well. Thanks chaps
Is my Outer CV gone please, car in bits (not like crying) ? Really appreciate if you can help and look at quick video
Looks alright. Any radial (clockface) play innit?
Replacing front struts
Just bear in mind that if you over cook it with the chisel, it's really easy to split the collar that goes around the hub as it's all cast metal.
Front wheel bearing
Thanks folks, should be fairly straightforward then. If I can get into the spline head bolts with a half inch socket set, it should be alright. I've done the ones on the 2k Caddy, but like yours pdmc, that was on the bench because I was replacing all the suspension (250k will do that to a van). I've gone with SKF just because that's what the local factor supplies as their good one. Got to support small businesses and I like being able to take something out of the box and look at it before I spend money.
Rear brake hose replacement?
You should be able to do them with the car on a decent pair of ramps. Give the unions a bath in your favourite release spray the night before and use proper brake/flare nut spanners.
Front wheel bearing
I need to do a front wheel bearing, so I'm doing it the lazy way and changing the bolt on assembly. It's the 4 bolt fixing. Has anyone changed one of these with the hub carrier on the car, or does it need to be taken off the strut and done on the bench?
Front axle nut rusted solid, any ideas please
Before you jack the car up or take the wheel off. Get a mate to stand on the brakes while you slide a pipe over the breaker bar and use it to get the nut cracked off. I use the handle off a 3 tonne jack as an extension and it works every time.
Skoda fabia vrs mk1
Start by seeing what's not working as well as it should. Boost leaks, intercoolers with holes in, sticky turbo vanes, electronic issues, worn bushes. That might point you in the direction of what to uprate first. I found the rear ARB worked well on my old Ibiza, I'm not so convinced it's doing anything useful on my Fabia
TDI warm up
I've never found the Fabia to be too bad at warming up. The SDI Caddy I have is terrible though. Changing the glow plugs and the oil cooler (for other reasons) does seem to have helped it a little. Also don't be tempted to get in and turn the heat all the way up, all you're doing is putting a fan across the heater matrix, which is another radiator. You might as well set it to blow cold, outside air until the coolant has warmed up.
changing front spring
These are what I use. I've got other kinds as well, but I find these sit well and don't twist and slide about. Like wino, I've done a few sets with them. You can grease them or spray them with whatevers lying around the shed before use if you want, it makes things a bit easier.
06 TDI change DSG oil?
So, due to a dodgy shoulder, my Fabia vrs is sleeping and I'm using a MK2 Octavia 1.9 diesel DSG. Its poverty spec, hubcaps, balloon tyres, black door handles that you have to put the key in to lock. It is really comfortable for what it is though and it seems happy enough doing 120 miles a day on crap roads. I've done a basic service on it, it's on 180k. Should I change the gearbox oil, or is it best left alone if it's happy?
Brake calliper wind back tool
The fronts don't need winding, they just push straight back. If I'm using a g clamp, I leave an old pad in between it and the pot to protect the caliper pot. Rears wind in clockwise, the cheap tools are fine. I have used a pair of water pump pliers when I've been in a rush and had no choice. I don't recommend it, but it can be done. Just don't fight them if they're seized.
