Everything posted by StevesTruck
1.0 MPi difficult gear selection for first and reverse
Does it still do it if you rapidly pump the clutch a few times first?
Fabia VRS LE Register Part Trois
228 In WB & Sons Auction https://www.bidspotter.co.uk/en-gb/auction-catalogues/fine-car-auctions/catalogue-id-fine-c10040/lot-e2d4cc13-da37-422c-ad7a-b3a000f98a48
vRS Drag Race
When you consider that everything else had about 100hp over the Mk1's and 2's, they didn't do badly. The mk1 fabia took a hell of a lot of speed off quickly under braking, I'm guessing it was on the standard brakes and got heat fade.
Buying my company Skoda Superb
If you like it and you know it's had a good life, then why not? It's definitely not expensive. It takes the doubt out of wondering what sort of a life it's had before you got it. When I went back self-employed, I bought a van off the fleet of the company I'd been working for because I knew it'd been looked after and it's been great
In trade insurance
It was about a trader keeping cars on the road, insurance, and being a problem neighbour. From my standpoint as someone who trades vehicles, I'm explaining why they may not show as insured, and suggesting a different line he could go down to if he wants to raise his neighbour with the authorities.
In trade insurance
If he's a trader with the appropriate policy, they can be insured but not shown on MID, depends a bit on the policy. Ours only shows if we've specifically "fleeted" a vehicle onto the policy, but, subject to a few conditions, we're insured on anything in our custody. Road tax is more likely to be the issue because you can't use trade plates to store vehicles on the road.
VCDS (VAGCOM)
If you fancy VCDS, the main UK supplier is on this page. https://www.gendan.co.uk/vcds_chooser.php The USB versions to use with a Windows laptop are a lot cheaper (£200-odd) than the ones for a phone/tablet (£400-odd). You will find cheaper copy cables that work with older versions of VCDS, they're a bit of a lottery and a taboo subject on here. To be fair, what you need doing isn't particularly specialist any more, and most half-decent diagnostic should do the job, so if it's for a one-off, it might be cheaper to pay someone else to do it.
£20 for VCDS scan
Splitting hairs, you can scan as many cars as you want on a VIN-limited cable. You only need to use a VIN if you're going into detail. I normally say £20 cash in hand for a scan and report on my driveway, so if it's a garage doing that for the same money, I'd say that's excellent value.
Outrageous Skoda Prices
Looks about right for a retail price for a genuine item. Here's another supplier for comparison. https://skodapartsdirect.co.uk/product/skoda-2012-2024-sump-plug-washer/ At the end of the day, you're buying 2 small items as a retail customer, so, in the nicest possible way, they've got no reason to want to do you a favour on pricing. If it takes 15 minutes to take your order, process it, go fetch it and charge your card, that's probably £4 worth of wages and NI they've paid the parts lad before anything else. The only way to really save money on small stuff like this is buy a few online or with something else and have them on the shelf for when you want them. Even then, I'd question how much of a saving you really make. I've got a rack full of sump plugs, washers, nuts, trim clips, bleed nipples, bulbs, standard fuses, micro fuses, maxifuses..... Yeah, it's a lifesaver when I need one, but I bet I've got a few hundred quid of outlay sat there waiting for the day I might need it.
Rear brake pad change disaster
Did you pre-fill the caliper with fluid? I've found it helps a lot on VW rear calipers.
VRS Diesel Oil Change
No reason not to, I'm of the belief that keeping the oil fresh in a diesel makes it live longer. Just make sure you're using the right spec oil for your engine, and check you've got the right tools for removing the filter before you start.
My 2023 MINI Cooper S Level 3 Electric leased from Motability which will be with me for 3 years & now a 2021 MG5 as a dog wagon.
Interested to see see how you get on with the MG. I've heard they're utilitarian, but in a good way.
OBD scanners
That's anything with a canbus to be fair, so most cars made in this century
OBD scanners
It mostly goes down to the level of systems it can read and change, and the cars it can work on. I have a £20 Lidl's scanner in the glovebox. It'll tell me ECU and ABS fault codes so I can go Google them, turn a service light off on most older cars, and that's about it. When my van put an engine light on 100 miles from home, it gave me a code to google so I could make a decision whether to continue, and turned the light off. That's all I wanted. My brother's got a Snap on Solus. It'll give him the fault code, live data, test a systems operation (power it up, see if it works) and a guide as to what the fault means and some common fixes. I was chasing a fault on a Peugeot, it told me what the code meant, a few things to check with a meter and how to fix it. Then you've got stuff like VCDS, which will be able to look at all the car's systems, give fault codes, show the live data from the system, do output checks, let you recode modules.... but only on VAG. I've got it, when I bought it, it was the thing to have. The level of stuff it can do on VAG cars is pretty comprehensive (except security systems), but it's a bit clunky to use and you really need a laptop. Last time I used it, it identified a faulty injector on my Polo, told me which one it was, what was wrong with it, and then allowed me to code the replacement in. Then there's the Chinese stuff, Topdon and the like. Mine was £350, it can do pretty much anything VCDS can do, but on any car, and it's fairly easy to use for most things. But.... some of the interface is a can be written in Engrish, and there's no real guarantee that it's going to do the right thing to your car, and still be working a few years down the line. So really, it's down to what you want to work on, what you want to be able to do on it, and what sort of brand do you want to buy? Yeah, VCDS is amazing, if you want to spend a few hours geeking out changing settings or tracing an awkward fault on a Skoda, but it's a no real use when your mate's Fiesta throws an ABS light.
skoda fabia 2006 swinging arm bolt.
Guessing it's the bit closest to the camera giving you the trouble? As long as it's not the actual arm itself, only the sleeve inside the bush that's touching the subframe, that's fine, just knock it in unless it's obviously well over sized. If in doubt, wind the bolt in and out without the arm there to see what it feels like. If you're reusing the original bolt, it'll probably want a good wire-brushing to clean it up. At risk of stating the obvious, leave the outer ball joint (the one that goes in the bottom of the wheel hub carrier) until last.
- Best positions to mount roof rack on the roof rails of an Mk3 Estate
OBD
https://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Req. help with Felicia (Fun) 1.6MPI Clutch Cable
StevesTruck replied to Schloompa's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanWhen I did the gearbox on my old pickup, I had the car on stands. You'll need to get under to pull the driveshafts out and undo all the bell housing bolts, so how far you want to lift it depends on your physique. Bear in mind it's a Skoda box, not a VW one, so the driveshaft has a spline that goes into the box and makes the oil seal, rather than bolting onto an output shaft. By necessity, I did mine on axle stands, and lifted the box out the top (it wasn't particularly heavy).
StevesTruck replied to Schloompa's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI'm trying to work out why you would need a specialist tool. Is it just to lock the clutch arm? I did a gearbox on a 1.6 years ago and can't remember it being anything special at the gearbox end (never took the pedal box end of the cable off). My normal method of doing a clutch cable is press the pedal, get a volunteer to hold the clutch arm in place with a crowbar, release the pedal and the cable should be loose to move.
Tap, tap, tap when the a/c and recirculation buttons are both on!
Sounds like the recirculating flap motor is skipping teeth when it tries to open. Is the A/C actually a factor, or does it do it when just the fan's on?
"w"-shaped metal clip hanging loose from underbody
It's a support for the handbrake cable. There should be another one on the other side if you want a pattern to look at when you're refitting it
Home CCTV
You know you're arguing over an 8 year old post right?
- Coolant leak
skoda octavia estate scout vrs??? did it exist in 2007
The only obvious mod is the exhaust, I'm guessing at the very least, it's been mapped though
Just comes up as a Scout TDI 140 on my check, so I'd assume it's just been modified.
