Damaged tyre
NO!! A cut like you illustrate will have taken all the strength out of the tyre sidewall, and I doubt it is either legal or safe to use ever again.
jars' 2005 Fabia vRS
That I can tell you in my case, but I doubt it will be the same issue for you. During haemodialysis we occasionally attempt to remove too much water from a patient, and that will cause a BP crash (it has for me, about twice). The last time I called that it was happening, and the next thing I remember I was flat on my back, there was a sick bowl on my table, and 2 nurses were rolling back my dialysis saline to get my BP back up.
What did you do to your bike today?
It's a green meanie; do you need any more reasons?
Been there, done that. Feels nasty, but at least you're in the right place to get a BP crash handled promptly.
2022 F1
Tell the Snowbirds that you'll repair the road before P1.
Brand new Skoda Kamiq Signature - Few queries
These show for seconds; If you start the engine then put your seatbelt on they should be out before you get second gear (or reverse out your parking space).
Today, I Purchased a 2011 Fabia 1.4 VRS Estate. Could you please advise one a couple of things?
@DutyPaid - I'll 3rd the "avoid Avons" with a similar story about cracking. Seatbelt I think any garage should be able to do; no idea about belt price though.
Replace the condenser on the fabia mk3 to fix the aircon, or leave it be?
I don't do Daily Excess guff. The point about working a/c doing other things besides "cooling air" is entirely true, even if it has appeared in the Excess (don't know or care).
Hitting the big seven-oh---
That's a fair and valid question.
As long as they don't tell you that having an issue is "a million to one shot", because we all know those happen seven times out of ten!
Is there a way to undelete long term driving data?
No. HTH.
Wish I'd thought of that when my fistula was being superficialised!
The 'A' Button on the centre console
To a little wooden cross beneath the town, Where a broken hearted woman tends the grave of Mad Karoo, Whilst the little yellow God looks sadly down.
195x55R15 vs. 195x50R15
That didn't come through from the earlier posts. Since it was the actual case, I agree the point.
Mk2 Octavia vrs max tune?
You want power. Power costs. How fast can you afford to go? @devonutopia can tell you all about making a 1.9D 300.
Oil pressure - what to check next?
Oil filter? It's fairly cheap, and a clogged filter could give these symptoms.
Help- 2010 Skoda problem.
It doesn't. It says "M1", which is a type approval number meaning that it's a car, with a limited production run.
Best place to buy spray paint
A local to you bodybuilder may be able to supply paint fully matched to your car.
You'll be left with an old school heater and fan, but even then the functionality will be somewhat downgraded. My old Octy has an early Climatronic, and I normally leave it in full automatic set to 18C unless I want the demist or defrost mode.
When answering, bear in mind that aircon does air heating and air drying as well as air cooling functions.
locking wheel nut "nut"
And how many wheel braces?
Changing battery in Fabia 6Y 1.4MPI (50KW) - could someone double check whether I am about to make a mistake?
Well, you could use a magnet on a stick...
2011Fabia TDI 5 speed manual - Damage to diff housing - What caused this?
Probably a bad casting (manufacturing issue) or impact damage. Look for any signs of corrosion on the broken surfaces.
Rear springs...replace?
I think that is correct under French law.
1) I don't think you're that far from AwesomeGTi (find then in Site Sponsors). 2) You've not actually said what the present fitment is.
