Everything posted by pab567
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
- Columbus/RNS 510 issues
Android Auto.. any particular point for me?
@hubrad if you are fine with using phone in the craddle and you don't intend to use oem sat nav (for MIB2 maps were updated this month, for MIB1 unfortunatly new maps are not available since coupdl of years) and you are OK with featores of your MIB1 Amundsen then it does not make any sense to spend money on upgrading. Although for myslef Android AUto is must in a car... but it's my personal requiremnt.
ŠKODA Superb 2014 Laurin & Klement headunit replacement
Sure, I will send you PM. All you listed are compatible with Sound System, it's the question of coding only.
Fu..ing expensive.. I can prepare one for youfor less than half a price... or, if you already bought another, can send you two cables and blue connector...
You can either take the wires out of the old quad lock and put them into connectors and then into the holes in the new quad lock or add two cables bewtween old quadlock socket and new quadlock plug as I indicated above.
CarPlay Update
Sent in PM
Yes, that's exactly what was needed! And I have good news - the microphone first goes to the unit and then from the unit to BT module underneath driver's seat so all you have to add are two wires from green 12-pin plug (multi-pin connector 3) to blue 12-pin plug (plug B) in new Quadlock plug (old pin 1- new pin 7, old pin 7 - new pin 1). You don't need to re-wire old AUX as you have new USB/AUX harness for MIB STD2 PQ.
Yes, it will, but you may also need to put some extra wires - post the picture I asked above so I can give you more details.
The microphone is NOT underneath the drivers seat. It is located in the light panel between driver and passneger, just the cable goes either directly to BT module that is located underneath driver's seat or to the Columbus unit and then from the Columbus unit to the BT module. Post the picture of QuadLock plug that goes to Columbus, from the cables side, focus on green plug so I can see the version you have.
- Recommended Android music/SatNav unit to replace Columbus
Columbus RNS510 Language stuck in German.
SKDOA dealer will not be able to help, you have to find someone locally who has the tools and can have it slved. If you don't find anyone you can send it to me to Poland and I will handle it..
NAND in your unit is it overloaded and requires re-formatting. Unfortunately this must be done with service software like CarProg, SetConfig or Martech.
- radio replacement
Yes, sir
Yes, that's what you need
Get USB/AUX port with harness and wire it from the new unit to armrest. There is no need to removing the centre console, just pul apart the front part from the passenger side and wire the harness along the console to the back. Remove the rear clock assembly - this will give you the access to the current AUX port so you can remove it and replace with AUX/USB (after extending the hol;e - a sharp knife is good enought to make it).
Yes, the plastic pieceis inside the cavity after you remove the unit. Exactly, and you have to remove 37 when new unit is installed as it does NOT have built-in OEM sat nav.
Take the unit that is unlocked as the other unit requires SMD soldering skills and extra tools to unlock it. Tell the seller to code new unit for Sound System . Remember tyo cut out the plastic supportive trim in the radio unit bay (in the middle, at the bottom back) as in this place there is USB socket in the new unit. Remove address 37 from gateway installation list. I recommend to install new USB/AUX port in the armrest (replace AUX with USB/AUX combintaion).
Columbus / RNS 510 unit trouble
Use CD-R. This must be IDE (PATA) drive, not SATA.
- Columbus / RNS 510 unit trouble
- 170bhp 4x4 2013
Infotainment retrofitting
So now you have Blues or Swing MIB1 unit, with Bluetooth, without DAB, with USB 5Q0035726 and fortunately you don't have CANTON sound system. You can install one of four different OEM glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D You also have to replace USB port, glove box (or at least glove box insert) and add harness to connecy it all. The question is what is your budget and which of listed below features are "must have": - Video playback from DVD, USB, SD - CD playback - OEM navigation - displaying OEM maps in Virtual Cluster (Active Info Display). All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them: - MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB - MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
- Firmware update request for Skoda Kamiq 2020 (MIB3)
New USB connection
I sent you PM
