pab567
FREEDOMTech
Everything posted by pab567
  1. Ad. 1 /2 Remove the relay. It gives additional delays and might be an issue. Connect power to +12V available when ignition is on, e.g. from the back wiper engine module. This will also solve the nest issue with camer black when going from reverse to front driving. Ad. 3 - yes, but it requires infotainment unit to be upgraded to 04xx Ad. 4
  2. Unfortunatrlt I have bo firmware for this unit.
  3. This is Bolero MIB2 - I have already sent you in PM link to download MST2_EU_SK_ZR_P0369T
  4. It means your disk drive is faulty and must be replaced
  5. @xlot thank you very much for your information
  6. @Jopega : Ad. 1 - how is the power connected to the camera? Ad. 2 - this normal, the camera goes off either after several seconds or if you exceed some speed driving forward. Ad. 3 - this requires either reworking instruments cluster or upgrading your infotainment unit to 04xx firmware. However, as such firmware is not available of SKODA, it's a bit complicated. Ad. 4 - it's in coding of 5F unit
  7. @SiJoyce15 you can swap display unit to 5E0919605M or 5E0919605N or 5E0919606, however in case of 5E0919605M and 5E0919605N APP button will not work unless you upgrade firmware to 3xx or 4xx. Replacing display unit to 5E0919606D requires exchange of glove box unit too.
  8. The one and only: Motorola MA1
  9. @tvand pls post a screenshot here, I believe application on your smartphone might be outdated rather than your infotainment unit.
  10. CANTON is the supplier of Sound System. Is there anything you were missing in your glove box unit?
  11. No fuse in MIB series
  12. You have Bolero MY16, with DAB. You can NOT replace it with 5E) units s these are MIB1 so have 4 times lower display resolution and less features. Is the display completely black? Do you hear anything, e.g. radio stations?
  13. Thx, @kalamath, I hop eyou enjoy it all the time
  14. This means you have problem with NAND. It will be hard to have it fixed just with the firmware upgrade but I have sen you link to download RNS510-5238A-josi-VIM-Testmode-60-35-5
  15. be done by a proffesional - contact your Skoda dealer or someone having ODIS online account for Skoda.
  16. Before you start with UART I highly recommend to get in touch with someone having VCDS, OBD Eleven, VC Tool, Vag Can Pro or ODIS and check coding of your 5F unit.
  17. It could be two issues: Your unit has skin number coded that is not supported in the new firmware - do you have any diagnostics tool? Something went wrong - you have to enter emergency mode with MST2_EU_SK_P02xxT on SD inserted into one of teh slots (keep second slot empty), fo this you will need UART connected directly to QuadLock.
  18. Ad. 1 I don't have any update for your unit. Ad. 2 - yes, it is, fortunately in SWING units Bluetooth is NOT covered with FEC/SWaP codes so just removal of Component Protection and adding a microphone is enough.
  19. You car was manufactured in 2016 but it's MY17. Your trunk handle part number is 6V0827566. OEM part number of trunk handle with reverse camera is 6V0827566G so from the link you sent you need model F:
  20. I sent you PM with VIN request so I can check part number of your current traunk handle and let you know which camera to order.
  21. Of course it can be done differently, you don't have to use MIB STD2 Toolbox (I don't use it at all) - but it MUST be patched to go from 02xx or 03xx to 04xx, and for most of people, who are not familiar with QNX and software reverse engineering, MIB STD2 Toolbox is a great solution.
