pab567
FREEDOMTech
Everything posted by pab567
  1. Link to download MEN2_EU_SKGPx_P0080L_8755 sent in PM
  2. IMHO such firmware does not exist
  3. Yes, you can, as anyone having navigation unit (Amundsen), search for MIB STD2 Toolbox
  4. I have never heard about software MST2_EU_SK_ZR_P0270T,where did you find this information?
  5. Nope, you already have the latest version officially available for your unit.
  6. IN navigation units like yours you can do it by yourself with MIB STD2 Toolbox
  7. Has the component protection been removed? Have you adjusted coding and adaptations to the ones from you old unit?
  8. Unfortunately I don't have any change logs so I am not able to answer your question :(
  9. You have the most recent firmware so I'm afraid there is no solution - unless you want to retrofit the infotainment reader with another, capable of Android Auto and Apple CarPlay.
  10. VIN of your car or part number and software version of your infotainment unit?
  11. It's adjustable in adaptations, check channels (I used VCDS so with ODB Eleven look for similar wording): ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07 => activated ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus => Suspension data bus
  12. Nope, resoldering solves ONLY sound issues. For firmware upgrade: 1. format SD (best max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
  13. Probably your unit has a typical failure - dry joints in power amplifier section. It can be easily repaired by resoldering power amplifier chips. You can replace 5E0035020A with 5E0035020C but it's not plug&play - new unit must have component protection removed by Skoda dealer, must have FEC/SWaP codes assigned to your car reinstalled and finally must be parametrized (coding and adaptiaions) to match your car equipment options.
  14. Sure, it's your decision, I just don't understand your sarcasm. SmartLink at the beginning was an extra option that required additional payment and it simply seems that the buyer of your car when placing an order with Soda has simply skipped it.
  15. Nope, I don;t know any possibility to patch non-navigation unit from SD.
  16. Good news - you are able to make installation of MIB STD2 Toolbox from SD card, all you need is to tun developer mode on in adaptations, e.g. with VCDS, OBD Eleven, VCTool, VCP or ODIS. @zlatni71 I don't have such file but you should be able to achieve all with MIB STD2 Toolbox.
  17. Part number of your infotainment unit?
  18. I'm sorry but without full scan, where I can see modules part numbers and errors in each module, I cannot check if they are the same as installed in factory and make troubleshooting.
  19. Pls share full scan, not just the errors.
