Everything posted by pab567
Skoda Swing Firmware Update - MU 8755
I do not recommend aftermarket units. To replace with Bolero or AMundsen you need display unit, glove box unit and harness to connect it all. Glove boxunit must be patched to disable component protection and enable new features.
Amundsen Bluetooth suddenly stopped working
Does it react on ignition switching on/off? If yes then probably the BT module itself, which is built into the glove box unit, is faulty.
Amundsen MIB2 Firmware Update
Dis you buy it as brand new car directly from SKODA? Pls share VIN so I can check original configuration.
Ad. 1 search for MIB STD2 TOOLBOX Ad. 2 was it brand new car when you bought it? Maybe someone made some retrofit..
RNS510 aftermarket query
Indeed, it's tied to a lot of other systems, that's why I do not recommend aftermarket units as I have not found any that is 100% compatible with all the features, if you need to replace then IMHO the best in class is original MIB STD2 PQ unit How can I tell if the TV module is installed? => Pls share VIN so I can check. Do you think the original unit is salvageable? I'm pretty sure it can be recovered, pls take it out and share the picture of a label from upper housing.
- Amundsen firmware update + bluetooth fix
Changing Radio on Skoda Superb II
Rather bad luck, pls share part number and SW version of your MIB2 unit.
I need Bolero Update :-)
Check your PMs for download link
Check your PMs
Retrofit camera for MIB STD2 PQ
Ad. 1 - OEM camera is connected to QuadLock blue connector pins 7 (signal) and 12 (gnd), you eitehr need an adapter from RCA to OEM pins like the one below or cut the yeloow plug and add original OEM pins instead. Ad. 2 - you will need to replace your PDC module, check if you are able to code camera in your current PDC. There can be three scenarios: it's not possible it's possible but you don't get a view of camera and PDC visualization on the same screen it's possible and you get a view of camera and PDC visualization on the same screen In case of first two you will need to replace your PDC. You can use either 1Z0919575G or 1K8919472C. 1Z0919575G is P&P while 1K8919472C requires re-pinning or special adapter. Big advantage of 1K8919472C is that it can turn on PDC automatically when you slowly drive towards wall / other car in front of you Of course in both cases coding might be required.
@gogiii @wim_rommens upgrading from 02xx to 03xx is possible but it requires unit to be patched first because, as Patch must be made to swdownload file, google for MIB STD2 TOOLBOX. Only after this is done you can upgrade to 0480. @prosist MIB STD2 TOOLBOX is also a solution for you to activate SmartLink. I sent you link to MST2_EU_SK_ZR_P0369T on PM. As I don't deal with aftermarket units I can't give any guidance. My personal opinion: if you can get OUE unit that matches your requirements then stick to it! @AlexScout you have download link on PM too!
- Add rear speakers to Skoda Fabia 3 2015
Head unit change
The qyestion is what new features are you looking for...
Another Android Auto question (sorry!)
Only infotainment reader (glove box unit), no need to replace display unit. You can use Bolero 5Q0035842x / 565035842 or Amundsen 5Q0035874x / 565035874. New unit must be patched - none SKoda dealer will be able to officially activate new features that are not supported by your original 5Q0035820 unit (Android Auto, Apple CarPlay, Voice Command, Sport Menu). Each of replacement units I mentioned also supports Rear View Camera. I can deliver replacement unit in Plug&Play version, if you are interested pls contact me on PM.
Skoda Fabia mk3 2015 - Android Auto Upgrade?
Bolero MY15 can't, must be retrofitted Bolero MY16 part numbers 5Q0035819A and 5Q0035820A can't, must be retrofitted, but 5Q0035840A and 5Q0035842A can have it simply activated General rule is none 5Q0035840, 5Q0035842, 5Q0035819x and 5Q0035820x can't have Android Auto activated (x - any letter, can be missing) and therefore must be retrofitted (only infotainment reader required retrofitting, display unit can remain).
Infotainment issues
What is the part number and firmware version of infotainment unit?
Skoda Octavia 5e Stereo Screen Upgrade
So now you have AMundsen MIB1, with Bluetooth, with DAB, part number 5E0035874A, with USB 5Q0035726B and fortunately you don't have CANTON sound system. You can install one of four different OEM glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D If you woulkd like to use Apple CarPlay then you also have to replace USB port. The question is what is your budget and which of listed below features are "must have": - Video playback from DVD, USB, SD - CD playback - OEM navigation - displaying OEM maps in Virtual Cluster (Active Info Display). All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them: - MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB - MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
Infotainment problem
Usuaully it's the front part with the ddisplay faulty, you can buysame unit and then replace just the front, keeping the mainboard part from the old unit.
Pls share VIN
MK3 Octavia - replacing MIB1 multimedia player - is it coded?
@SDL999 pls share VIN of your Octavia
- Install a new infotainment system in Skoda Superb II
It's not possible to upgarde to 03xx without patching the unit first, e.g. via MIB STD2 Toolbox. You may lose Android/Auto if you have a software patch installed now.
Bad news: There is no 04xx firmware for SKODA MIB STD2 PQ units. Solution is to flash it for VW firmware and then load SKODA HMI however it requires unit to be patched first (see MIB STD2 TOOLBOX). Your unit is Engineering version, there is a risk of bricking it with regular customer firmware.
General rule I recommend to follow is "If it works without any issues don't touch it" which means don't make a firmware upgrade if everything works ok. Bricking th eunit during firmware upgrade is not very common but still happens so why should anyone take a risk if there is no need? Check you PMs for download link
