Everything posted by pab567
Amundsen MIB2 Firmware Update
All check your PMs
Component protection active
- Component protection active
@jonesi100 pls share VIN and put error details, e.g VCDS scan- 2015 VRS - Remap, Headunit and Foglamp Bulb Upgrade
You have Amundsen MIB2, with Bluetooth, with DAB, part number 5E0035874A, with USB 5Q0035726E (supports both Android Auto and CarPlay) and CANTON sound system. What are you missing in your system?- 2015 VRS - Remap, Headunit and Foglamp Bulb Upgrade
Pls share your VIN so I can check details and provide an answer.- What's this please? 2018 Fabia
- Columbus maps/radio update
You probably have the best firmware for you unit - to make sure pls remove it and send the picture of the label from upper case. If I remember correctly the most recent maps are alredy 7 years old and there will never be new release as this unit is not supported since several years.- New (to me) Superb - Bluetooth, but no phone?
Yes- SKODA SUPERB MK2 HEAD UNIT
I sent you firmware link on PM. Pls note it will re-partition your HDD so all music and maps will be lost and you will have to re-upload it again. If you woul dliek to have firmware that will not re-partition your HDD then let me know and I will send you the link earliest tomorrow evening when I am back home.- New (to me) Superb - Bluetooth, but no phone?
The question is what is your Telephone (Bluetooth) module part number...- SKODA SUPERB MK2 HEAD UNIT
Yes, when you remove the unit there will be a label on the upper case- New (to me) Superb - Bluetooth, but no phone?
@MisterSkoda it looks that your car was NOT equipped with Bluetooth module when manufactured so it must have been retrofitted and probably located in another place then factory designated. Try to get someone with any diagnostics tool (VCDS, VCP, OBD Eleven etc.) and run a scan to get Bluetooth module info.- Amundsen MIB2 Firmware Update
@skodanewby315 I sent you link for the latest firmware for your unit. These units support Android Auto - see the screen when you select SmartLink from touch screen menu.- SKODA SUPERB MK2 HEAD UNIT
It's just electronics - sometimes hardware, sometimes software... if it display swl message then just load CD with the right firmware - send a picture of upper case label and I will share link with you- Amundsen MIB2 Firmware Update
All check your PMs. @Ashot I really doubt it will help, if you don't manage to have it solved pls contact me on PM.- RNS510 Firmware Update
Pls share current SW version or picture of the label from upper cover of your unit first.- New (to me) Superb - Bluetooth, but no phone?
Pls share VIN so I can check BT module version you have.- I need Bolero Update :-)
Others pls check your PM- I need Bolero Update :-)
Pls post part number and current SW version- I need Bolero Update :-)
I don't... Unfortunately not, you need to replace infotainment reader, if you are interested pls contact me on PM.- Update
I sent link to th elatest SW on PM however IMHO this is HW, not SW issue.- 2013 Paint code
Share VIn so I can check in production database.- Skoda RNS510 sw update
Sent in PM- Emergency Download
Pls sahre VIN so I can send you link for the right SW version- Direct Firmware Download needed for Bolero in Octavia III
