ords
Everything posted by ords
  1. We don't know which system you have. Post an image of the large screen in the centre of the dash. Normally there are two round buttons, one on each side at the bottom of the screen. You just press the left hand one to turn the system on and again to turn it off Show the post about the button being next to the passenger a/c button. The button for the a/c is on the drivers side. When you turn the system on, radio, satnav, media player are all activated as well as the display between the speedo and tacho. If you don't want the radio, just turn the volume down (using the same on and off button) This also controls the satnav volume.
  2. I've been lucky with mine. Pretty bulletproof. The water pump driven by the cambelt can cause problems, that's all I can think of.
  3. I remember it was a few eastern Europe countries. I don't know what you mean by files on the card or just the map part
  4. Sorry, I can't help you, I'm not an expert by any means. I just followed the instructions and it worked.
  5. If you want to update to 2023 read this post. I've done it.
  6. Personally, I didn't see any difference and was underwhelmed by the whole experience🙂
  7. Did you save the old files before you did the format? If so, do another format, copy the old files onto the card and see if it recognises them.
  8. There is a work around to get a more recent map update as per the attached thread. The second to last post is mine, which if you expand show instructions for getting the map update. . You can see my screen shots showing the latest map date available and also my version number, which is later than yours. This is the thread to help you get the latest firmware version.
  9. Others have the same complaint. Seems to be a standard but meaningless feature.
  10. Being pedantic 😡, the early one's like mine did have them. I've never used it tho, as an SD card is far more convenient.
  11. In the set up menu, have you got it on the strongest setting?
  12. We need to know which system you have.
  13. It's all part of the stop/start system. The a/c is also connected to it.
  14. Exactly. As long as the temp is comfortable for you, leave it alone.
  15. If it's working leave it alone. Mines never been topped up from new.
  16. Floodgates are open now😀
  17. My car in cold weather always starts better than in warmer weather. In cold weather there is quite a long delay whilst the glow plugs do their job and then instant starting. In warmer weather most of the time the starter kicks in before the glow plugs have had time to work resulting in some lengthy cranking time.
  18. No need for oil changes then, you're continually putting fresh oil in it. My tdi has has hardly used a drop of oil in 5000 miles.
  19. Is that correct, 1 litre for every one thousand miles?
