ords
Everything posted by ords
  1. Is the fan running from a cold start?
  2. As the dash lights dim I suggest you get the battery and alternator checked out.
  3. Are you just looking for answers from 1.5 TSI owners?
  4. Thanks for letting us know the outcome, so many don't.
  5. That coil light can come on for many reasons. Start stop failing could be a failing battery. Suggest you get the battery and alternator checked out first.
  6. Where I park it's level ground, so i just leave it in P, handbrake off.
  7. What engine do you have? Manual or auto?
  8. Is the fuel guage fluctuating as well?
  9. Is the engine getting up to temperature going by the water temp guage?
  10. Ask an insurance company.
  11. Good question. You were right.
  12. Did you use the same keys on your wifes car?
  13. If I understand correctly, he's fitted a device which senses when the voltage in the battery is getting low and cuts power to the circuit he's running his cooler from.
  14. Low battery voltage can throw up all sorts of fault codes & warning lights. How does the car run? How old is the battery?
  15. I like them permanent, as I like to keep the dash cam running. So far I've managed to remember to unplug it when I know the car won't be used for awhile.
  16. Are you sure it has this function? @gregoirmentioned his cooler box flattened the battery and he now uses a 3rd party cut out system.
  17. Get the bodyshops opinion.
  18. Try putting some premium fuel in it.
  19. Don't know if it has a timing belt or chain. Chain could be flapping about a bit?
  20. I'll make a point of looking next time.
