Everything posted by ords
Leaking rear washer - how to remove trim?
- 5E5061109 Boot Storage Tray Fitting Confusion
https://www.theskodashop.co.uk/products/skoda-boot-parcel-shelf-storage-box-octavia-3-hatch-5e5061109- 30 Min for driving = No Android Auto
Are these instructions different from the one's you have? 5E5-061-109-MN-0142-1.pdf- DSG modes and gears-kickdown etc. ?gaslighting
Any chance of driving one of the garages Scout's to see "if they all do it"?- Ignition key stuck in barrel- DSG
Mine allows me to remove the key regardless of whether my foot is on the brake or not or whether the handbrake is on or off.- Glow plug flashes
Your intial posting could be also be seen as abrupt. No please or thank you's.- Battery keeps going flat
Were the lights on, on both sides or just one side?- Battery keeps going flat
Have you tried to get it looked at under warranty?- Battery keeps going flat
I'll 2nd that. My Varta AGM is 10 yrs old.- DSG modes and gears-kickdown etc. ?gaslighting
I'm exactly the same.- Mk3 Climate control Issues
Try re-calibration first- Cam belt change, the truth
i know it's not local to you, but the price is much better. https://www.pscautocentre.co.uk/products/audi-timing-belt-water-pump-replacement-petrol-engines-mqb-platform?variant=40099133587502- Battery issues and Auto Stop/Start not working
I just thought that if you have 2 smart devices connected there's potential conflict. If the battery is fully charged with one terminal disconnected, then the BMS should also read as fully charged when connected as you say. However, some have said that in normal circumstances the battery is never 100% fully charged to allow for a small amount of regenerative current to be put into the battery- Battery issues and Auto Stop/Start not working
Seems then it's best to take off one of the terminals if charging in situ, so there's no conflict with the BMS?- Battery issues and Auto Stop/Start not working
I'll 2nd that as my Varta is 10 yrs old.- New Battery
Start/stop can stop working for many reasons even with a healthy battery. You could contact a member nearest you with VCD's who could code a new battery you bought and fitted yourself. A shortish drive without coding will not do any long term damage or fit the new battery at the members location.. A link to VCD owners. https://www.google.com/maps/d/viewer?mid=1Td73_uUUqscV3nRm5br_o89PmBU&msa=0&ll=21.259901462991593%2C83.39240985000004&z=2- Battery issues and Auto Stop/Start not working
But how would that affect the chargers system into thinking the battery is not fully charged when OP said it had turned itself off because it was full?- Battery issues and Auto Stop/Start not working
I've no other suggestions.- Dodgy Electrics
My Varta battery has a manufacturing code which from the internet tells me it's 10 yrs old this month.- Battery issues and Auto Stop/Start not working
Was everything switched off so no demands on the battery? Have you had the car from new? A previous owner could have permanently disabled it.- Dodgy Electrics
I read in another forum, Banner batteries have the mfg date stamped on top of the negative terminal as per screenshot In this case it was mfg week 42, yr 15- Octavia 2019 SE Technology SD card slots?
Can't you contact the seller and ask them to check?- Battery issues and Auto Stop/Start not working
Have you been on a good run since changing the serial no? Can you put the battery on charge to see if it will take a full charge? If it does, stop/start should kick in depending on what consumables are on.- Another Stop/Start Fiasco
At least you know which "specialists" to avoid in the future. - 5E5061109 Boot Storage Tray Fitting Confusion
