Everything posted by ords
Skoda Octavia mark 3 Sat nav update
Are you using a pc or Apple? Apple adds on files which have to be deleted. There is a thread somewhere on this forum explaining this.
MIB2 coding Cambridge
Care to share?
Coolant issue
As I read it, the OP did not fill it up to the top. The level rose from the minimum level to the top as he was unscrewing the cap.
Glow plug replacement
If you're replacing them yourself, there is no labour cost involved. If you get a garage to do it, then you're going to be hit with a labour charge every time, so it would be cheaper to replace all four at the same time.
2013 Octavia VRS 2.0 TDI COOLANT LOSS NIGHTMARE
It's a TDI
Was it ok before the cambelt change?
Škoda Rapid 999cc 2019 oil spec
Wrong forum
- Cycling speedo and fuel gauge light effects on 2016 Octavia vRS diesel
- Coolant warning light
Steering wheel clicking sound when returning to center (NOT clock spring)
- Leave selector in position P => will it pass the MOT?
If the engine management light is on, it will fail. A warning light only will probably be ok. Call the mot garage and ask them.- Wireless android auto adaptor
Which system in the car do you have?- Problem with new Navigations maps
- Coolant temperature
1.6 TDI here. Gets up to 90c on the gauge no matter what the outside temp is. What the actual temp is I've no idea as I don't have OBD11 monitoring it.- Coolant warning light
- Knocking Sound Under Bonnet – Need Advice!
That would seem to rule out anything related to the engine then. Can you post a video or audio file of the noise?- Knocking Sound Under Bonnet – Need Advice!
Does it do when coasting with the engine off?- 1.5TSI evap valve issues
It will probably fail the MOT with the light on.- Loose waterpump belt 2.0 tsi
Plenty of info on Youtube.- Test driving November 2018 1.5tsi Octavia
Manual or auto?- Waterpump belt cover...
Any help? It mentions part no 06K109121B eBayGENUINE 13-17 SKODA OCTAVIA VRS VW GOLF S3 2.0 WATER PUMP...PART NUMBER: 06K109121B. GENUINE 13-17 SKODA OCTAVIA VRS VW GOLF S3 2.0. WATER PUMP COVER CAP. CHANNEL ISLANDS, SCOTTISH ISLANDS, HIGHLANDS ETC. DOES HAVE SCRATCHES MARKS DENTS OR AND AGE RELATED W...- Squeaking noise taking off in 1.6 dsg
Yes, I should have said flick it down again instead of up.- DQ200 clutch disengage when pressing brake.
Finally got a chance to do what you asked. Drove down a steep hill, stopped with full pressure on the brake pedal, stop/start did not work. Into reverse, foot off the brake, after a couple of seconds car reverses on idling speed. I then accelerated a few yards and stopped with full brake pressure, s/s did not work. Did the same thing again, but this time as soon as I selected reverse I went from brake to accelerator and car moved backwards straight away. Again after stopping s/s did not work. On a level road, driving forwards and stopping s/s worked. Reversing and stopping s/s did not work. Hope this is some help to you.- Squeaking noise taking off in 1.6 dsg
With the selector in D, flicking the selector down will put it into sports mode, flicking it back up will put it back into whatever mode had been selected. For manual shifting, in the D position, move the selector to the left and then flick the selector down to downshift or up to upshift. The middle display on the instrument panel will tell you which gear you're in. Move the selector to the right to go back to auto mode.- Squeaking noise taking off in 1.6 dsg
