Trouble at early test stage
Is it a genuine interface and have you tried the rosstech forums?
Location of engine oil temp sender
I have no idea how similar the BMW engine will be to a Skoda one. I believe your Yeti has a EA288 engine so the G266 sensor is in the sump and the oil circuit looks a bit like this: The oil level/temperature sensor works a bit like this: You should probably try and find something similar to the VAG/Skoda SSP documents for the BMW engine if you want to compare...
dash lights started flickering
I replied to your other identical question here:
Intermittently flickering dash lights
Assuming you have a MK2 Octavia, this guide might help:
It's possible, but as I say it's not something I'm aware of, nor can I see any obvious mentions online from other Skoda owners. I think there is a coolant temperature warning though
What are you actually trying to achieve or understand? As others have said, I'm also not aware of any oil temperature warning alarm. The sender will give the current temperature and it'll probably be the engine ECU or the instrument cluster that decide if it's 'too hot'...
FL MFSW retrofit for non-FL Octavia Mk. 2
Based on the post linked below, the pre-FL maxidot is not compatible with a FL MFSW.
Invisible gearknob legend
Not in a car I'm familiar with but given there are a few options for number of gears and reverse placement, it maybe helpful if others drive it. That and it looks much neater if the legend is clearly visible
Nothing so fancy in a MK2 Superb I'm afraid, the legend has simply worn away but you can probably replace the insert You need something similar to this https://www.ebay.co.uk/itm/183853012062 but check it's compatible with your Superb before buying. edit: Not sure what style you have, it may need a replacement gearknob rather than just an insert...
fault code 02403
You might want to add more information as there are plenty of different Octavia's through out the years. At a guess, I'm assuming a MK2 Octavia and I'd start by checking the battery voltage, fuses, engine bay fuse holder contacts, relays and the ignition switch
Predictive Cruise Control on 16MY
Might be worth talking to these guys: https://www.need4street.de/ACC-option-predictive-control-MQB
Octavia estate 1.6TDI 2019 Engine Noise Maker?
Pretty sure only the vRS models get the sound generator
PCC uses satnav data to choose an appropriate speed for upcoming corners, roundabouts etc. It's on some of the VW Arteons I've not heard of anyone retrofitting it yet. To start with, you need to compare modules HW/SW versions and coding with a car that does support PCC. The next problem will be SWaP/FeC codes as I expect you'll need some extra ones installing. This may not be possible via VW/Skoda...
What can I replace my Columbus with?
@Martyf - standard fakra colour codes apply. double white is AM/FM blue is GPS black is DAB
Rear View Mirror Reattachment
I'd be tempted to remove the rest of the mount as it'll be easier to do it on a workbench than upwards against a window. I've not removed this style but this video makes it look very easy: On the plus, this style should be pretty cheap if you can't get it back together
Rear Suspension Information
You should try and keep your posts in one place. In your other thread you've added a picture with paint codes that appear to tally with 1K0 511 115 BS. @Carlston - you suggested BS in his other thread, which I'd agree with assuming the springs/paint codes are original
AFS Not Working 02629
On the MK2 Superb, it's not uncommon for water ingress to cause corrosion on the AFS slave pins. They are stuck on the underside of each headlight so not the easiest to get at.
Airbag light on after removing and replacing front passenger seat.
Should be assuming it was fine before you unplugged the seat and you've plugged it back in
It'll need the fault code clearing with VCDS or similar. Although I'm also in England, I may not be close! You might find someone more local on the VCDS map in the VCDS section
Amundsen MIB STD2 infotainment system with Android in Superb II
The two wires from the white section on the 40 pin side to the blue block on the 52 pin side should be the mic. However, looking at a RNS-510 wiring diagram, it seems they are in the wrong place? On the 40 pin side, it should be pins 1 and 7 on connector C: On the 52 pin side, it should be pins 1 and 7 on connector B: It's probably worth checking the adaptor actually does that... As for coding, I can't check with VCDS for individual bits/bytes but I used lcode 03130601FF00000051110201008800002F0100D60120010046 on my unit looking at old scans
Basically it depends what the car was originally equipt with. If you had the Columbus/RNS-510 with voice control, the mic should already be wired to the quadlock so assuming the 40-52 pin quadlock adaptor has the two wires, it'll just work. If you had a Columbus/RNS-510 without voice control or any other headunit and a bluetooth module, the mic is directly wired to the BT module. You'll need to tweak the wiring to move the mic to the new headunit.
Disconnect the old Bluetooth module, it's no longer needed. Neither 37 or 56 exist as the new unit is at 5f 😉
Skoda Yeti 2010 mod, 2.0.TDI, 103kw 4X4 - problem ABS?
Just remember that when you unlock the car or open a door/bonnet, it will cause various systems to turn on and the current consumption to increase. This is why the correct method includes fooling the door/bonnet switches and waiting for all system to shutdown or enter 'sleep' mode. That's the only way to get a true idea of whats happening when the car is still locked and shutdown or 'sleeping'.
Follow the "current draw diag.pdf" I posted earlier in this thread... In short, fool the door/bonnet open sensors, lock the car and wait two hours, check the mV over each fuse to confirm the current draw
- Columbus Head Unit Boot Up Screen Display Corrupt
