langers2k
  1. Current MOT says: Therefore, the OP can permanently disable the DRL given it's a 2013 car. My car was made after March 2018 but has an option in the headunit to disable the DRL. If it were to fail an MOT, I would then point out to the tester how to enable them and expect a free retest... I never knew they might re-enable themselves, I'll test it when I remember! As for the OP, maybe start by adding a VCDS autoscan and adaption map for your BCM.
  2. Seems you have a cloned VCDS cable: https://forums.ross-tech.com/index.php?threads/36535/
  3. Replacing the CAN-gateway will definately require some component protection work. Can you post a full autoscan from before and after the door module swap and ideally adaption maps for both sides?
  4. The "no basic settings" error probably needs the basic settings running as per the instruction I posted previously so the car can relearn the normal/level position. No idea how you'd do this with OBDeleven as I've never used it, it might be worth asking on the OBDeleven forums for advice on that specific tool... A full scan might give some clues about the "additional installations" error - at a guess you've changed the coding of 4B. Is there a coding log or anything useful from OBDeleven that might help?
  5. I don't think door modules are part of the component protection constellation: What car did the modules come from? They might need an Octavia dataset uploading before they will work properly.
  6. There are two different variants from what I can see but it's not FWD vs 4x4, instead, it seems to be split between the Scout and everything else. At a guess, it's likely to be ride hight related? From the brochure: Assuming you have a 4x4 which isn't a Scout, I think you want 5E0092155: Whereas the Scout would need 5E9092155 which does look to have different rails:
  7. @YENDYS - What are you actually trying to do or enable. For a reference, plenty of folk call the Amundsen fitted from around MY18 with software 04xx a MIB2.5.
  8. @TadyTheFish - it appears Skoda changed their guidance at some point based on the snippet from the 10.2013 manual posted by @T07 above and the same section from a 04.2020 edition. Personally, I'd go with the latest version but even this is now 3 years old: Might be worth an hour on erwin to get the latest version. It's only €7 + tax normally
  9. Interesting, I wonder why they dropped the front sensor. Still that would explain why front suspension work has made the OP's headlights so out of spec You're probably looking in the wrong place... I don't have the exact module/wording as I've lent my VCDS to a mate so I can't double check. Still, at a guess you need to look at the measuring blocks under either 09 or 4B. I'd hope there is something similar to "Sensor Signal - Rear (G76/G77)" which gives a percentage, you might also have a "Sensor Signal - Front (G78/G289)". If you're only getting data from the rear sensor, that suggests you only have one sensor fitted and you just need to perform basic settings and a headlight alignment, please see the details below. It's a bit more complex than that post makes out to do it correctly, longer instructions below:
  10. I did all four on my MK2 TDi. If one failed, the other 3 might not be far behind plus it wasn't much more effort to do all of them... They shouldn't be needed for regens and even during start, they aren't used much on modern diesels. I think it's just personal choice really
  11. It's not impossible, model years (MY) start around July/August so a car produced from about July/August 2017 to July/August 2018 would be a 2018 MY Anywho, relevant section of the wiring diagram is below. I would expect your car to be covered under 'For models with no electric damping control' which implies both sensors should be present. If the OP is feeling handy, they could always check the BCM connector to see if those pins are populated. I was somewhat surprised to discover the level sensors now connect to the BCM rather than the headlight range module though...
  12. Well that's confusing, I'm pretty sure there should be both front and rear level sensors, I found what appears to be the rear level sensor in @automass's previous images: @automass - it might be worth adding your VIN too,mostly as I think @varooom can decode them which might explain what's going on. @ApertureS and @varooom have either of you come across a MK3 Octavia only having a rear level sensor?? If it is a valid config, it could certainly explain why the OP's lights are point skywards assuming the front end is now higher without a level sensor to correct it. Just to make sure that I'm not going mad, I've just stuck my arm under my car and as expected, found this on the front passenger suspension:
  13. Pretty much. About the only thing to be aware of is the latest full Europe ECE AS(A1) maps won't fit on a 16GB card so you may need to select an alternative such as ECE 1, ECE 5 or ECE 6 depending which non-UK countries you care about. There is a guide here too:
  14. It needs to be a Skoda/VW SD card for the Amundsen fitted to a 2018 Octavia
  15. Loads of 5E0959565C on eBay.... - https://www.ebay.co.uk/itm/255447467077 - https://www.ebay.co.uk/itm/225444205549 - https://www.ebay.co.uk/itm/304661864810 Top one is in the UK too
  16. If the link rod between the suspension and sensor is missing or broken, the startup sequence would work normally and no errors would show... Assuming OBD11 can show measuring blocks then you should be able to find the front/rear level sensors and headlight aim - all of which should be changing during a normal drive. Until you know what's causing the issue, it's impossible to know if it's a simple job. I'd probably take a look at the sensors first to check for obvious damage/misalignment then try logging the measuring blocks... If everything looks fine and the data is changing as expected, then I'd get a garage to do the headlight alignment.
  17. They would have likely dropped the front wishbones to replace the shocks. As you can see above, the level sender is attached to the wishbone so it may have been disconnected (mechanically, not electrically) or damaged during the shock replacement.
  18. I thought they were always on the left hand side regardless of LHD/RHD. Front should look like this: Rear depends on the suspension, a 1.4 TSI is probably a torsion beam: Check the sender arm orientation matches the above. It's certainly not uncommon on multi-link systems to have the arm facing the wrong way which messes up the levelling.
  19. After suspension work I'd expect the normal suspension position would need relearning (basic settings) and the headlights adjusted with appropriate equipment. It's also worth checking both level sensors are still correctly attached and undamaged
  20. A clockspring/squib issue would effect all buttons as it's a shared connection. It's much more likely to be a roller-wheel issue, probably some dust or lint that's got into the mechanism (it's an optical sensor). I'd be tempted to remove the buttons, open them and give them a clean first
  21. It doesn't translate well without the engine sounds in the background. There are some extracted samples from various firmware here: https://github.com/jilleb/mqb-soundaktor/blob/main/Sound_samples.md
  22. It certainly would. On my 2018 vRS it's PR-GM3 - Electronic engine sound (type 2).
  23. I think you'll find it uses a crossover for the extra 2 speakers... As the 2015 Superb brochure states it's still a 10 channel amp:
  24. It'll use a MOST (optical) to transfer the audio etc to the Canton amp. Based on the above diagrams, it has: - Power and ground - MOST in and out - 8 channels for the door tweeters/woofers - 1 channel for the front speaker - 2 channels for the dual coil subwoofer - One extra connection between the amp and headunit, not sure what it's used for...
