langers2k
  1. I don't believe it's possible on this generation of car... Maybe add a link to the guide you're trying to use and a vcds autoscan from your car 👍
  2. The fl vRS gets the single c style Otkaav posted a picture of earlier in this thread.
  3. I tend to use https://erwin.skoda-auto.cz/ but it's a per time period charge. Fine if you just want an hour to grab workshop manuals, could get expensive if you want access over a few days/weeks to check multiple vins. I think others have used various 'free' online VIN decoders, I don't have any suggestions I'm afraid. If it's a Skoda dealer, they should be able to provide a list of PR codes if you ask nicely and they aren't an arse
  4. Manual cars get the VAQ too. My '68 plate manual vRS 245 has one 👍
  5. It's a different rear cluster. You can fit pre-fl clusters but you'll need a wiring adapter and coding changes. Most people do the opposite and fit fl clusters to pre-fl cars 😉
  6. If you want to increase the bulb lifetime, use something like osram ultra life. The actual lumen output will be pretty much identical to the performance halogen. The plus X percentage brighter/range claims are pretty bogus. It's measuring a single part of the headlight beam in a headlight from a one car model which yielded the best result. Although some EU countries are starting to accept retrofit led kits, from what I've seen it needs to be certified for each individual lamp type so it's far from universal. When I last checked, some VW models were listed but no Skoda's. I doubt the retrofit LEDs will be any brighter than a halogen. Anything above 2000lm will need headlight washers and leveling systems so it'll just be a whiter, longer lasting lamp rather than a true performance upgrade.
  7. The front diff settings appears on cars without a VAQ so scrap that. Scan tool or PR codes is the easiest way... Thread regarding it:
  8. Checking the pr-codes for the vin or using a scan tool to check the module is fitted are the obvious options. I think there might be an extra option in the individual driving mode setup too. I can't remember the wording though...
  9. ECE1 has Spain, France and the UK which fits on a 16gb card 👍
  10. Pretty sure that's normal. There are a few varients depending if it's pre-fl or fl and if you have low or high functionally versions fitted 👍
  11. That style of hba controller had been known to fail due to a 0 ohm resistor overheating and failing. Take a look at
  12. Installation list is normally pretty easy to figure out on that generation of car. Add things that aren't registered and remove things that are missing will get you pretty close. Can you add an autoscan from VCDS 👍
  13. Pretty sure the ECU provides the max power figure... I think you need to go back to your tuner and see if they can sort it. At least when I retrofitted a VC it was correct immediately.
  14. No - I wouldn't expect parts to work between generations. The cars are based on completely different platforms, the MK2 Octavia is PQ35 and a MK3 is MQB... You might find parts from other MQB cars work, such as a MK7 Golf or MK3 Leon This doesn't seem too bad a price for a TDi vRS radiator pack assuming it has everything you need: https://www.ebay.co.uk/itm/144821766382
  15. A quick google suggests that 91° C is a perfectly plausible temperature between the turbo and intercooler. For example, Valeo state: "The intercooler lowers the temperature of the inlet gas from 130° C to 60° C, removes the negative effects of the turbo and increases the power by around 20%." Given there are no fault codes, I would have no concerns about it 👍 Might be worth looking at some more measuring blocks to see if there are a few more temps from other parts of the intake system?
  16. Have you changed anything recently or updated the maps?
  17. My worry would be the droplets will cause corrosion and damage the LED module or other internal electronics. It's hard to tell from your images but it looks pretty excessive and causing droplets inside. Compare it to these images I posted from a Skoda TPI: I'd use a hairdryer to get the worst out. Then inspect the headlights to make sure all the caps are in place and there are no obvious cracks etc.
  18. There are loads on eBay in various styles and price points. If you want genuine versions, I think the RHD choices are: - All-weather interior foot mats (4-piece set) (5E2 061 550) - Textile foot mats Standard (4-piece set) (5E2 061 404C) - Textile foot mats Prestige (4-piece set) (5E2 061 404B) I can't remember if there is a vRS specific version 😕
  19. It's impossible to know. All the Euro6 standard revisions have the same limits by fuel type, it's the testing that changed. I would hope that Euro6 will be enough for most emission zones for a while. Euro7 is due to be introduced in 2025 I think...
  20. Grabbing a list of PR codes for the VIN would be the easiest way to check, if you have PR-7CS listed, then it'll have a GPF. Timeline for the reg changes from VW: As the vRS was an existing model, the changes would have applied to cars built after the 1st September 2018. That means it'll be MY19 (Model Year 19) or '68 plate onwards. Some very early '68 plates built before September probably avoided the GPF Had a quick look on eBay at downpipes, Both shown below were listed as Golf MK7 GTI's which has the same (or very similar) 245ps engine as the vRS. I believe the left is a pre-GPF and the right is with a GPF, it's probably that massive cylinder at the bottom
  21. You might want to add a little more information... What diagnostic tool are you using and maybe share some screenshots to show what you've tried
  22. That's completely normal after a firmware update and is trivial to fix. You need to grab a value from the "Confirmation of installation change" channel, XOR it with C9D2 then enter the new value OBDeleven example below and you can use http://mib-helper.com/im-so-xory/ for the XOR calculation...
  23. It's certainly been done, just for example: - https://forums.ross-tech.com/index.php?threads/30114/ - https://www.drive2.ru/l/630579815207933947/ - https://www.drive2.ru/l/594185980328569269/ The biggest issue is the frame. There is no OEM part so instead you'll need to modify one or have one 3D printed then painted to match your interior. Pretty sure there was someone on drive2 making them but I can't remember who.
  24. From the workshop manual: Please note the 'remove the headlight' step so you'll need to remove the front bumper... No idea if it's possible without removing the headlight
  25. I would suggest address 09, adaptions and CSV, it should end up in the logs folder
