Everything posted by gm73
Oil Sensor - please visit workshop warning light.
What’s that then???😂
Changing Brake Pads
Fronts are really easy, piston can be pushed in with water pump pliers. Rears require a wind back tool.
Yes it’s amber thanks. Should be a sensor fault. I’m about to go under to check the wiring. If nothing looks amiss I’ll order a new sensor from TPS. Unfortunately I think you need to drop the oil to remove it. It’s close to oil change time though I suppose.
I’ve searched the forums and cannot find an exact answer to my question. I’m getting the OIL SENSOR! Please visit workshop warning message every 5 minutes or so. It pings and then goes off after about 3 seconds. Oil level is perfect and temperature is holding at about 95/96 so would anyone know what might be causing this? I’m thinking either faulty sensor, dirty sensor or a wiring issue? It’s a 1.5 TSI with 116k miles. The car is a taxi so I have to work whilst worrying about this.
Major Service Records
I’ve done the fronts on mine twice. It’s one of the easiest jobs on a car I’ve ever done. Used Brembo parts. Cost me about £70 in total. I’ve never done the rears. Did you just use a standard caliper rewind tool???
Long cranking time
Timing issue??
No. It was almost at the top of the cross hatching. I was told they like oil at the top so that’s why they advised 75%. I just let it go as he knew I wouldn’t buy any oil as there was half a gallon in the boot. PS can I PM you about something? I have a tool that measures water content in the brake fluid. So that gets checked once a week.
I’ve changed mine twice myself. As you say £15 per plug for the 1.5 TSI and it took half an hour. Never, ever changed the brake fluid, even on my of 250k mile 1.6 TDI. Or coolant.
Some of the things listed in a major service and extended scope service I always had done at every service.
Dealership “health check”
Excellent knowledge but how is the average owner supposed to know all that ? Anyway last time I checked before it went in it was up at the top. I’ve always been told it has to be somewhere on the cross hatch and it’s fine. Last time I topped it up from near bottom of the crosshatch when warm it only took about 200mls to hit the top. Now I’m beginning to think I’ve ruined this engine as it’s a bit noisy under load and at idle. Not terrible but noisier than it should be.
I’ve always checked at operating temp on the flat. Occasionally be topped up a small amount. I checked not long before it went in today. It took a small amount to bring it up to around 3/4 of the cross hatched area. I checked this 3 times. To be only holding 75% of oil would mean it needs at least a litre which is complete nonsense. Strangely enough a litre is what they’re asking me to pay at £15.99 for.
My car is currently in the dealers for work and they’ve sent me a health check email. It states the oil is 75% filled and needs filled urgently. I check the oil on my car nearly every day and have never let it go much under the top of the lattice on the dipstick. I keep oil in the boot in case it needs topped up on occasion. the low oil pressure light has never came on on any car I’ve owned. It’s too late to call them tonight so what are they on about???
High Mileage Club
Engine: 1.5 TSI ACT (2020) Type: SE Technology Mileage: 110k miles Cambelt getting done next week - £900!!!! 6 speed Manual Any other major work done? Turbo replaced at 68k, rear wiper motor repaired by me, wiper blades, 11x services, numerous tyres, brake pads changed 2x discs once Still on original clutch engine is a bit rattly despite 8k oil changes
1.0 TSI SE TECHNOLOGY Engine vibration on idle
I’ve got the 1.5 TSI and mines vibrates at idle. Its always had a bit of a noisy rough idle since I bought it at 9k miles. My mechanic says it’s due to emission control and the direct injection. I’d try another one to compare though.
Skoda servicing
Spark plugs are an additional item so I think they expect you to book it in yourself. As for servicing with Henry’s North I got my car from them but did all the services myself at a fraction of the cost.
Rear wiper 'pausing' mid sweep
I’ve ordered a puller tool from screwfix. I’ll collect it tomorrow.
I need to remove my rear wiper so I can operate on the motor but it just won’t come off. Any tips to remove it?
1.5 TSI booked in for timing belt replacement
Exactly. Hence why I have just bitten the bullet and went to the dealer. Peace of mind with the warranty. There was a couple of other places offering it for between £650 and £850 and I was tempted but at least with Skoda there will be comeback and capacity to repair any damage and they will use the correct OEM parts. I will also be making sure the complete kit is fitted including all tensioners.
That's my 2020 1.5 TSI booked in for the timing belt replacement. £920 at Henry's Skoda Glasgow if anyone is wondering about the cost. Car is on 109k but it's a taxi so I'm not waiting until 140k even though the service bloke said they've never heard of any snapping prematurely.
Any high mileage TSI engines out there ??
106k on 1.5 TSI Octavia. Engine is noisier than usual and feels slightly lumpy in 3rd and 4th gear (might just be coil pack). Car isn’t nice any longer for long hours of work - it’s a taxi. I think I’ll change it to a Toyota.
Oil temperature fluctuating
If they hadn’t fitted an oil temp readout you wouldn’t be bothering about this. It’s just something else for folk to worry about unnecessarily.
Boot Light/Open Issue?
One of the brown ones. There’s two. I can’t remember which one sorry.
Another strange noise from the front right of the car
Have you checked the brake backing plate?
Boot micro switch. Mine got water ingress. I just snipped the wire instead of spending £250 on a new lock assembly.
Timing Belt
140k or 5 years according to Skoda.
