Everything posted by Kenny R
Tyre pressure.
- Lowering the SE L suspension similar to Sportline
Have you checked the tyres are at the correct pressure. I believe the Sportline versions don’t have lowered suspension and actually sit slightly higher than other versions due to the larger wheels.- Reset DSG ‘learning’
On my current and previous Kodiaqs pulling back on gear selector only puts gearbox in sports, drive mode remains on normal.- Reset DSG ‘learning’
Using the sport function on the gear selector only puts the gearbox into sport mode, selecting sport mode using the drive mode button changes other parameters.- New timing belt at 5 years
Considering the water pump on 1.4 , 1.5 TSI engines is not driven by the cam belt and is on the other end of the engine there is absolutely no reason to change it unnecessarily when replacing cam belt.- Reset DSG ‘learning’
When you say you’re using sports mode is this DSG sport mode by pulling back on gear selector, or are you changing driving mode to sport?- Oil temperature
Perfectly normal in the circumstances you discribed.- Kodiaq Owners Register
I’ve used a set of 17” wheels with 215x65 winter tyres on my previous Kodiaq and will be fitting to my new Kodiaq in a few weeks.- Side Signal/Indicator and Clicking Noice
A click when turning wheel with indicator on sounds normal for any car I’ve had with self cancelling indicators.- Winter wheels
The speedo won’t” be out” fitting 17” wheels with the correct tyres. As you can see the overall diameter/ circumference difference is negligible.- Driving DSG -
As above switch the autohold on and leave on , then at traffic lights etc you can leave in D and no need to faff about with ehb etc. Using the B setting using regenerative braking when lifting off or leaving in D mode and coasting when lifting off is something to get used to and choosing what suits you’re driving.- What is this light ?
Interior lights coming on when doors open turned off?- Winter wheels
- Winter wheels
Just wondered as my Kodiaq has the direct TPMS , thought latest Octavia might have as well.- Winter wheels
Does the latest Octavia have direct TPMS? You might need to factor in, 4 tyre pressure sensors as well.- Front Isofix retro fit parts order and fitting
- A/C vs AUTO - What's the difference?
As above set ac on, select auto and select a temp you like , mine is 20° and leave it to do it’s thing 24/7 365.- Suddenly wing mirrors cannot be adjusted
+1 My 2010 and 2013 Yetis both had the simultaneous mirror adjustment option that could be turned off.- Superchip / Tuning TDi ?
I would drive and enjoy your new purchase when you get it and wait and see if you really need a tuning box/ remap. Ive recently changed from a 2.0 Tsi 180 4x4 Kodiaq to a 1.5 tsi 150 and can honestly say I’m not missing the extra 30hp but in current circumstances I am enjoying the extra mpg.- Non UK Kodiaq
- Sat nav screen
- Sat nav screen
Haven’t tried having the sat nav as default start up screen, but I have the Home Screen with 2/3 of the screen maps and radio and Apple car play as the other 2 widgets. Similar to image below ( sorry only one I could find)- Electric tailgate - beeping at the top
Should have asked for them to demonstrate a showroom/ forecourt Kodiaq tailgate that beeps when fully open if it’s normal.- VCDS adaptation for auto folding mirrors ?
I don’t recall it being possible using VCDS. You can fold in the mirrors using a long press of the lock button on the remote.- Android Auto WiFi (new Kodiaq)
