Everything posted by Kenny R
Dies on hard acceleration
What are the front tyre condition/ pressure like. Was it wet/ damp, could have been the TC cutting in and cutting power if the front wheels were spinning.
MY21 - Columbus MIB3 - HOME Screen setup
Press on the widget you don’t require, a red trash can appears in the top corner, you can then delete, and then add the widgets you want.
- 11 replies
- add tile
- add widget
- columbus
- home screen
Tagged with:
Upper Passenger Storage Compartment and Towbar issue
Best case scenario, the tow bar only needs freeing off with some lubricant. The upper glove box could be really simple fix also. Have you tried tapping the cover whilst pushing the button in may just be stuck. Both jobs should be an easy fix for any competent vehicle tech.
MY2020 Kodiaq Sportline specification sheet
The mirror switch on the drivers door, needs to be set to L
Pricing/ spec sheet from 2019. What do you think is missing from yours? SKODA_KODIAQ_Pricing_and_Spec_MAY19.2cfe4916ffbf98c7ade4954d0caf448c.pdf
Brochure from 12/2020 SKODA_KODIAQ_Brochure_20201203.pdf
Looks like aggressive cleaning agents have been used, probably by a local roadside hand wash gritty sponge crew.
Uncomfortable driver's seat again
Try this… https://www.physiomed.co.uk/uploads/guide/file/21/Physiomed_Sitting_Guide_-_Driving_Digital.pdf
Rear bumber protector for 21 onwards
I would be very surprised if the previous style bumper protector didn’t fit as there doesn’t seem to have been any changes to the facelift rear end apart from the lights, bigger spoiler.
Vehicle Health Report message.
If you go into the vehicle status menu on the head unit you will get a pictogram showing if there are any faults. Similar to this..
Number Plate Surrounds
Anyone else ordered a new Kodiaq?
I ordered my first Kodiaq on 31/1/18 and collected it on 19/4/18.
Sounds like things are improving. My Kodiaq was built in August 2021 (ordered June 2021) and was shipped out to storage at Kralove airfield whilst awaiting chips to complete build. I eventually took delivery in February 2022.
MySkoda app locking status usually wrong - trying to see how many affected?
On iOS you need to go into above screen and you get a screen showing what door, window, boot, bonnet open, and the remote lock/ unlock buttons. That page has the refresh button.
Gearbox in emergency mode - no reverse gear
I believe all 1.5 Tsi Kodiaq’s have the DQ381 0GC 7 speed wet clutch DSG fitted, not the dreaded DQ200.
Expensive heated windscreen
I believe, as per previous Karoq and Yet, there is a socket in the floor and when the seat is tipped forward it un- plugs. Strange just having a winter pack plus , and not just a winter pack option with just heated front seats as per Kodiaq.
Plastic on wheels !?
Dash Cam/ front assist not working
You need to move the piggyback fuse in your first picture to the other slot with the flying lead, and the fuse you are removing to plug the piggyback into , rear wiper for example, needs to go in the slot on your piggyback that currently has the fuse in.
Problems with Skoda Lite data plug connection. It says PIN incorrect.
Double check your inputting the correct pin and be careful not to mix up an O for a 0.
Space saver wheel
The 145x85 tyre on an 18” rim is the standard Skoda approved spare wheel for the Kodiaq regardless of original wheel/ tyre size.
Potential purchase of 2.0 Tsi Sportline
@Routemaster1461 There seems to be some mix up in terminology. DCC = direct chassis control , think you are referring to cruise control which is irrelevant.
Noise belong BOLERO when runing bad roadway
If you have voice enhancement, turn it off.
My order number started with 31, I’m on PCP.
Retro fits
The only problem with these type of boot protectors, is that if you do require the use of the extra seats, you need to find somewhere to leave the mat. Skoda do a mat/ protector that can fold with the 3 rd row seats
Lights sensor
