Everything posted by Kenny R
Disappointed in off road performance
Even having the Haldex oil changed and pump filter cleaned at the correct intervals is sadly no guarantee that all is ok. My Kodiaqs Haldex pump failed shortly after being serviced at my local dealer. Coincidence ? or not, at least it was replaced under the extended warranty.
You don’t have to engage off-road mode for the drive to go to 4 wheels, it does this automatically in normal everyday driving. I would check that the Haldex services have been done as here in the UK it is an addition to normal services and even then Skoda dealers in the UK just change the oil and do not remove the pump and clean the filter unless you specifically ask them, and the garage you deal with has a clue. One thing to note if you haven’t driven a Haldex equipped car before if the front wheels do slip you need to keep the power on to allow drive to transfer to the rear, assuming your Haldex IS working.
Interested in how you selected 4wd mode. I suspect you mean off-road mode. How long have you had the car, has the Haldex oil been changed and the pump filter cleaned if due.
Anyone else ordered a new Kodiaq?
My Kodiaq could be in amongst that lot 😞
Well my Kodiaq went into production week beginning 16/8 and has definitely stalled. Only info Skoda are giving out is that the system is showing production is delayed.
Replacement Battery
Whilst the prices quoted by the OP are extortionate, the first battery appears to be a normal 12 v battery and the second appears to be an EFB suitable for stop/ start. Does the OP’s yeti actually have stop/ start? If it does it will require the correct EFB or AGM battery and most likely coded to the vehicle.
New used Yeti owner, haldex spin on launch?
1. Not normal. Car should have had at least 2 Haldex oil and filter changes by now, any proof this has been done. 2. Agree with above. 3. Fans running on after stopping are usually caused by interrupted dpf regens . Do you do lots of short journeys?
Hyundai Ioniq 5
- Sportline Vega 19” rims ship to Asia?
Have you tried here… http://www.kopacek.com/scripts/faq.php- Yeti warning bongs
I’m sure like other volume related items like sat nav announcements etc you turn them up or down, using the volume control, when they are occurring.- TPMS
Thanks, whilst it would be nice to have the direct system, I really want the indirect as it will make fitting my current winter wheels no problem.- TPMS
I know it’s sad, but I have been looking at the online owners manual to check on any differences on my awaited facelift Kodiaq. The manual make reference to direct tyre pressure monitoring, does anybody know if Skoda have now changed from the indirect system, or if the direct system is an option perhaps in other countries, the online manual is a bit vague.- Skoda connect Lite app
- DSG "reset"
Try it and see. Early 1.5 engines certainly had some hesitation/ kangaroo problems but the latest software updates seem to have solved this. Has your car had the fix applied? @e-Roottoot beat me to it.- Change to 18" Gemini from 19" extreme alloys.
- Oil consumption - 1.5 tsi
What was the oil level at the last time you checked, how long/ how many miles ago was that, and has it gone down considerably since then? Did you check the oil level when cold.- 12 / 24 hour
- Change kph to mph on yeti display
Once modded to the large MPH display it is only a matter of un ticking an option box in the maxidot display to display KPH again, which does comply with the regs.- Anyone else ordered a new Kodiaq?
Checked with Skoda live chat today, my Kodiaq that went into production week beginning 16/8, is still in production due to semiconductor shortages 😞- Build Times for new Karoq
Strange, as any time I’ve used the Skoda UK website live chat to check the build progress of my previous Yeti, current Kodiaq and my awaited new Kodiaq they have been able to give me the latest progress in less than a minute from me giving them my order number.- As the Dukes would say - Sell, sell, sell.
Motorway?- Disable headlight washers?
The same dirt/ road spray that requires you to wash the windscreen to see also obscures the headlights. The headlight washers on my previous yeti that had xenons and my current Kodiaq with LED’s keep the light clean with no problems. Perhaps if they are making a mess, it’s down to the screenwash used.- Returning car on finance
As said in my post above, the ballon payment is what you pay if you want to keep the car. I’m new to this PCP malarkey and I’ve just swapped in my Kodiaq with 10 months till the end of my 4 year PCP and got a decent deposit to put down on a new one when the remaining finance was cleared. As varaderoguy says above you should always come out with enough for a deposit on the next one.- Eco mode throttle blip
Deleted not relevant - Sportline Vega 19” rims ship to Asia?
