Kenny R
Everything posted by Kenny R
  1. If you’ve got an order in already, don’t pin your hopes on a free 20” wheel upgrade. My son has been informed today his order due end of July has build confirmed and is too late to change order for free upgrade and will definitely come with the standard 19” wheels.
  2. Strange message to get as 2.0 tsi are back to 280 ps and the 2.0 diesel is 200 ps and have been for a while.
  3. Kenny R replied to b1ackb1rd's topic in Skoda Yeti
    All I can say is, it is not usual to have any additional wiring installed for options that aren’t fitted on Skoda and indeed any of the VAG range.
  4. 4x4 doesn’t make any car better off road or on snow and ice, it’s all down to tyres. You may find a 2WD car with the proper tyres will meet all your requirements.
  5. Not sure on MIB3 but menu-car - parking and manoeuvring - gives you options for parking volume, tone settings and manoeuvre braking activation/ deactivation.
  6. If you are going to be parking in tight spots regularly and the manoeuvre braking is going to be a problem, it is a tick box option, on or off just switch it off.
  7. Manoeuvre braking is different from the front assist and uses the parking sensors, and can be easily turned off in the menu’s
  8. I think I too would hate my Kodiaq if I had the same experience. The water pump/ overheating problem is unfortunate but does seem to be a weak point on the Diesel engines, was it replaced under warranty? You don’t say what mileage you have covered and service history. All the other faults could all be attributed to a weak or faulty battery.
  9. As above, you get the option of a 4 years 80k miles, 4 years 100k, or 5 years 100k extended warranty. Looks like you’ve chosen 4 years 80k.
  10. £650 for 19’s vs £800 for 20’s hardly double the price.
  11. In that case does it not mean ECO mode is still selected meaning that stop/start is activated, LED headlights are in eco mode, air con is in eco mode, but drive mode is normal.
  12. You do realise you can achieve similar or better economy leaving it in drive and it’s a much better driving experience.
  13. Do you have a display between the speedo and Rev counter like this that shows doors/bonnet/ boot open? The display in photo is showing bonnet and boot open.
  14. Do you have maxidot. Does the bonnet show open when the wipers won’t work. Does sound like the bonnet open switch could be faulty.
  15. If it is a MY21 then you could face problems.
  16. You don’t say where you are located or whether your car is petrol or diesel, or 4x4 and has it been serviced at all. Are you carrying a full load all the time that your tyres are inflated to 2.7 bar, I run my 2.0 tsi at the recommended 2.4 bar. Certainly doesn’t sound normal,
  17. It is normal for the rear camera to remain active in drive till around 10 mph is achieved.
  18. Does sound like your battery is low after sitting in body shop. Charging the battery should remedy.
  19. Anti roll bar drop links, cheap as chips to replace.
  20. Why would the next buyer have privy to your invoice. As above what mileage is on the first service receipt is more relevant if it too is wrong.
  21. When unlocking/ opening grab the handle but do not touch the small indent used for locking. Same when locking only touch the small indent and no other part of the handle.
  22. Kenny R replied to Perchede's topic in Skoda Enyaq
    Don’t be surprised if it turns up on 20” wheels, as due to a shortage of 19’s they are offering 20’s as a free upgrade.
  23. I’m not sure on coding, but have you tried turning the brightness down, or you could put it on the maps screen and select night mode.
  24. When turning the temp dial, the digital display should read from lo, 18, 19 etc up to hi. If the car has climate turn on auto, ac on and set required temp ie 20° and leave 24/7 365. You also have the option of having each side having individual control or can be set that both are linked together and controlled from the drivers side dial.
  25. Your not painting the discs It’s easy enough to paint the hub without moving anything.
