Everything posted by D402
Replaced front discs and pads which has cured the brake judder I was suffering βΊοΈ
[Skoda Superb 2016 2.0 TDI L&K] β Jerking, Engine Shutoff While Driving, Start/Stop Issues, Glow Plug Light
Very similar problem here https://www.briskoda.net/forums/topic/533413-oil-temp-reaches-90c-vehicle-starts-jumping/ was solved by replacing the crank sensor.
Echo problem
- Skoda Connect registered main user nag dialog
Constant warnings
Good job on the diagnosis π Get some penetrating fluid onto the sensor now to give yourself the best chance of it coming out on Sunday!
Constant warnings
It's very strange, there should be codes logged to cause the faults displayed on the infotainment. I'd be tempted to unplug a sensor to see if that known fault gets logged and can be read by a scan tool. My suspicion is that either some wiring was damaged during the mechatronic change or the software updates have messed up communication to the scan tool and/or between modules causing the faults you're seeing. Did the faults start immediately you got the car back, and are they persistent or intermittent?
Constant warnings
But which one? With no fault codes, we don't really know what's going on. @Shanew Do your scan tools read faults from ABS etc, or just engine ECU?
Amundsen Mib2 Map Updates 2026
Based on using ECE 1 on a 16gb card, ECE 3 will fit, ECE 4, 5 and 7 might fit.
- 30 replies
- amundsden
- discover media
- maps
- mib2
Tagged with:
@Stonechip The old discs and pads were Brembo, the new ones are Delphi. The Brembo discs were fine but I wasn't impressed by the pads - braking wasn't as strong as the OE pads and they produced lots of dust, also that one pad wore much more than the others which makes me suspect the friction material broke up or detached from the backing plate. No complaints about the Delphi pads or discs so far. Unfortunately, I still have brake judder so will have to do the fronts as well, and I found a leaking shock absorber too π
Superb 2016 MK3 car key blade pin tool?
It's a roll pin so you can just press it back in with any suitable tool, I used a vice.
Rear Brake pad and Disc Change Superb Mk3
You've not done this have you?
Replaced the rear brake pads and discs again, they only seem to last about 36k miles. Nearside pads were ok but the inside of the disc was rusty: Offside disc was ok but inner pad was completely worn out, must keep a better eye on them.
I used Carista (phone app with bluetooth OBD adapter) which was the cheapest option at the time and worked fine.
Mileage check in - 2.0 TSI's
Better luck at 123,456, bonus points if you remember to reset the trip meter at 122,667!
You do not need to leave the ignition on after putting the EPB into service mode so no need for a battery charger. Make absolutely sure that the brake caliper, pads and discs are fully assembled before doing the 'end lining change'.
Observations from Using the VAGDPF App to Monitor DPF Regeneration β Skoda Superb Diesel
Very interesting, thank you for monitoring and analysing π Do you think the often quoted recommendation to drive on the motorway in a low gear to complete a regen might make things worse?! The problem I have is that I often do a journey where a stretch of dual carriageway close to home triggers a regen but isn't long enough for it to complete.
Daylight Running Light
Here you go, looks like it won't be easy https://www.briskoda.net/forums/topic/379864-se-and-se-business-drls/
Strange battery drain issue with my car
Have you by any chance changed the boot lights from normal bulbs to LED and left an interior light switched on? This situation causes my car to repeatedly switch off then wake up again. It's fine with all interior lights switched off.
Steering wheel noise
Check that the steering wheel isn't rubbing on the steering column cowl as it turns.
Steering wheel not centred, what next?
Then all that is needed is to shorten the left tie rod and lengthen the right one an equal amount. I am amazed that a garage can't sort this out.
The problem is that most garages only adjust one tie-rod end to get the wheels aligned and this leaves the steering wheel off-centre. They should then make equal adjustments on both tie-rods to centralise the steering wheel. It is difficult to judge the centre position of the steering wheel when you're not actually driving so a road test is needed to check it's right. @netman82 What happens when you drive along a straight, flat road with your hands off the wheel? Does the car go straight with the steering wheel off-centre, or pull to one side or the other?
Map updates
Then it must be Columbus and you can use any SD card to update it. Sorry to add to the confusion.
Map updates
We need to make sure, OP's SD card is for Amundsen. @Hamster59 Does your satnav only work with your Skoda SD card plugged into the car?
Map updates
I think that's an Amundsen unit which means you have to use a Skoda SD card.
2023 Superb vs 2016 Superb
Here's some bargain mats for you! https://www.kopacek.com/skoda/superb-iii/superb-iii-original-skoda-interior-floor-mats-prestige-grey-line-rhd/3v2061404a
