D402
Everything posted by D402
  1. Nothing out the ordinary if you're only cleaning up and greasing the pins, no need to retract the electric park brake unless you're replacing the pads. Check the condition of the discs, especially the inside; these love to go rusty and could well be the cause of your noises.
  2. It's OK to turn the ignition off, the car remembers that the park brake is open and needs to be reset. You'll get a warning when you switch back on. Don't reset the park brake until the brakes are fully reassembled.
  3. Very unlikely that hitting a pothole would damage the brakes on both sides but not the wheels, tyres or suspension. I think you've been lucky in a way to have the brake faults brought to your attention.
  4. Like my car, this thread has gone way further than I expected 🤣 Can anyone provide any concrete examples of injection system damage due to running out of diesel?
  5. Had to make an unplanned journey yesterday starting with a nearly empty tank. Result was driving about 6 miles with zero range and a 66.5 litre fill up. What's the furthest anyone's driven once the predicted range has dropped to zero?
  6. No need, the regen will automatically resume on your next journey.
  7. And drivers relying on auto lights on foggy but bright days!
  8. I'd hazard a guess that most of these accidents aren't really caused by dazzling modern headlights but by drivers who plough on regardless when they can't see where they're going, with perhaps a smattering of dirty or misted up windscreens, worn out wiperblades and poorly corrected vision thrown in.
  9. Retracting the EPB actuator with the diagnostic tool doesn't retract the piston, you still have to push it back. You must push the piston, not wind it, or you'll damage the actuator. All Superb Mk3s have TRW front brakes and ATE rears.
  10. Could be your adblue tank has frozen and should sort itself out when it warms up.
  11. No, I'm living with it, I do have DSG. The problem doesn't happen if I let the engine idle for a few moments before I pull away.
  12. I get something similar on a cold start; if I pull away then lift off the accelerator while still moving only slowly, for example to make a tight turn leaving a parking space, then the engine will occasionally stall. It only happens when I drive away immediately after starting the engine, nothing to do with the brakes.
  13. Check the discs for corrosion on the braking surfaces.
  14. @JR RS Thank you, it's helpful to see what's behind there. I can see that my undertray is intact, perhaps the wheel arch liner has hidden damage then. I think the foglight is partially detached from the bumper skin too.
  15. What gives the lower front of the bumper its strength? I've hit a pheasant at high speed near one foglight and, although there's no visible damage, that side is now very floppy compared to the other. I suspect there's some internal reinforcement broken but can't identify the part(s).
  16. I wonder which limit TSR would choose here A435 Gorcott Hill
  17. Try http://vehicleclips.co.uk, they seem to have everything
  18. Max power from a 13A socket is 3kW so it can't have used more than 3kW x 5 hours = 15kWh so I'd suspect a problem with the electricity meter or, more likely, the app.
  19. @JR RSThat's brilliant, thank you. I'm lucky the centre chrome strip survived, €107!
  20. Hit a pheasant at 70mph causing one of the small lower grilles to eject 🤬 Any suggestions for its replacement? I see aftermarket ones for around £30 but are they any good?
  21. Did you get round to cleaning up the blower? Corrosion in its connector could affect the LIN bus causing the Airconditioning DTC and the blower malfunctions.
  22. This is the new "C2" version that are getting good reviews. Most of the P7s on sale are still the old version.
  23. I do a journey regularly that, like your commute, is long and fast enough to trigger a regen but is too short for it to complete. When a regen is in progress the idle speed is raised, stop/start is disabled and DSG selects a lower gear. Watch out for this happening and extend your journey until things go back to normal, it probably won't take long. Otherwise the car will keep trying to regen on every suitable journey until it can complete. When it really needs to regen you will see the raised idle speed all the time, this is a sign that you need to do a long, fast drive.
