Hi All,
Some help would be most appreciated. I'm out of ideas.
I've been battling with a door lock since Friday when I bought a new to me car. Before purchasing I ran a full scan and no fault was showing on door locks. I ran more than one before and after drive. No faults showed on doors.
When I got home and locked the car, I discovered the rear left door could be opened as if it was unlocked.
Pulled door card off and listened. Nice solid clunk when locking or unlocking but every time the door can be opened. Car interior lights came on and went off with this door, so I though ok, only thing it can be is the lock actuator module. So I find a genuine one reselling on ebay for cheap, dealer price eye watering £190+vat.
I install it today, and when locking this new module now did 2 locks, one to lock and 1 I presume that then unlocks it. VCDS then showed the implausible signal on this replacement door lock.
I cleared tried again but it kept coming back. In frustration I removed and plugged the original back locked it, locked it, fitted it, Unplugged the loom and closed the door. The door could not be opened at all (as I'd removed the loom). So physically the door lock mechanism can lock.
I then clipped the loom back in and now this old one is showing implausible signal! In addition there is a databus error.
But in measuring blocks, when locking the rear left door shows closed and locked but door handle open it first pull from outside.
Nb. This is on a golf mk7 but hoping my friends here on Briskoda have some ideas or experience to help me out. Full Scan below.
Tuesday,25,May,2021,13:57:19:03075
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZAUZGP570470 License Plate:
Mileage: 90662km-56334mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 22 42 44 52 55 5F A9
VIN: WVWZZZAUZGP Mileage: 90662km-56334miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466050B2000
Shop #: WSC 00028 028 00074
ASAM Dataset: EV_ECM20TFS0205G0906259J 001002
ROD: EV_ECM20TFS0205G0906259F.rod
VCID: 35372B5935C1B6936C5-8060
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4913
Revision: 06253104 Serial number: TFK01510131437
Coding: 0014
Shop #: WSC 00028 028 00066
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 53F375C19B7588A3621-8006
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 63065000000908
Coding: 04FA93A15427296C077B070741C36920C92A94E0E08296F718425078C208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7AADF8655C5F99EBC17-802E
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 02120004200100011005000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 698FB72929F9227338D-803C
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 86580711151990
Coding: 03001B42C24122F30BA44080B10C07281000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 035385812B95D823921-8056
Wiper motor control module:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150920 042 0551
Serial number: 151015075440
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S2Y15M11D09H02M27S29
Coding: 90A8DD
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY152802JH9
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000033854488
Humidity sensor: interior:
2 Faults Found:
535060 - Databus
U1123 00 [009] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 53
Mileage: 90662 km
Date: 2021.05.25
Time: 12:50:19
197128 - Lock Module for Central Locking; Rear Left
B12DB 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 93
Mileage: 90662 km
Date: 2021.05.25
Time: 12:53:04
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391529308797
Coding: 0071051011
Shop #: WSC 00028 028 00211
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 43D345816B151823D21-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 06101503211649
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 3A2D38651CDF59EB817-806E
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR176ZC5
Coding: 98CCC000000000005C0000CF00C800000065
Shop #: WSC 00028 028 00052
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 7F5B0971477DBCC3F69-802A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number: 34169677B04111550521
Coding: 333135
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number: 34169676B04111580412
Coding: 333135
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 002 210 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000F1DBC3715
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 002 210 15
Component: SideSensor_Pf 001 0887
Serial number: 3586700000040CBC371-
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 480 403 110 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502991D73C62329C
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 480 403 110 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502C31D3F97422BJ
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 403 010 15
Component: FrontSensor_D 001 6149
Serial number: 3556502BD1D73C63917Q
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151109500111
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FDB497107FD7CC3B69-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 958 A HW: 5G1 920 958 A
Component: KOMBI 302 6420
Coding: 27AD10082F80260001882A011400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2F3B1931D79D8C43269-807A
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 30101510802581
Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 79AFE769595992F3C8D-802C
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29150002051880045443
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7197308203
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02028864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B030D21E385F0630A1-807E
1 Fault Found:
4186894 - Internal Control Module Memory Check Sum Error
B2000 47 [009] - Watchdog/safety µC failure
[Steuergerät: defektECU: defect]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 68506 km
Date: 2019.09.18
Time: 16:27:03
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00025.09.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4ACD68A54C3FC96B117-801E
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000173308326
Coding: 003F0220D001028000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 47CB51915F2D34030E9-8012
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000002503944
Coding: 0D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 392F276919D952F388D-806C
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000173181851
Coding: 003F0020DE01028000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 46D55C9558272D0BF5F-8012
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000002473599
Coding: 050000
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 06AE01000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 40D94A8D7A03033BCF3-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
1 Fault Found:
5276435 - Stationary Cornering Lamp Left
C1083 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 90424 km
Date: 2021.05.22
Time: 17:19:11
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 842 A HW: 3Q0 035 842 A
Component: MU-S-D-ER H24 0245
Serial number: VWZAZ2R0552748
Coding: 02730200FF00000051111101008808001F0207C60120010003
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW26.rod
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 3G0 919 605 B HW: 3G0 919 605 B
Component: ABT_Std-2 H43 4060
Serial number: VWZ6Z9R3061508
3 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 90424 km
Date: 2021.05.22
Time: 16:48:42
Voltage terminal 30: 12.0 V
Status_Software_Version_Management-module_name:
0512 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 90424 km
Date: 2021.05.22
Time: 16:48:43
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 53
Mileage: 90662 km
Date: 2021.05.25
Time: 12:18:10
Voltage terminal 30: 12.1 V
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150909200963
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
End----------(Elapsed Time: 01:48, VBatt start/end: 12.0V/12.1V)-----------
Address 09: DTCs cleared
