Everything posted by AGFalco
Mk 3 Octavia - alternator low output
No. I charge my EFB battery regularly with a smart charger, especially during the winter. At 7 years and 73 K miles from new my battery is still showing good when tested. Thanks. AG Falco
Because present batteries will not be at 100% ( by design ) and if the customer could see this they would get worried that the battery ( even when new ) is faulty. Thanks. AG Falco
Exhaust Heater Shield has dropped off!
It has the arrow to show the direction of exhaust flow. Heat shields are not normally flat, they have a small honeycomb type pattern. Thanks. AG Falco
Charge the battery first using a smart main charger. Thanks. AG Falco
Boot Electrics Problem
Yes. Or have you done that already as well. 😒 Thanks. AG Falco
Does it make any difference if you try it the other way? With mine I can change what opens when you push the key fob button via the infotainment system. Have you tried changing that? Or even a reset? Thanks. AG Falco
2015 Fabia - Digital Speed and Passenger Window
You can use the APP `GPS test' for the speed on your mobile, and there is an option for Heads up Display as well. Thanks. AG Falco
Fabia 2008 engine stall
A 2008 Fabia is not a MK III. MK II ? More details would be good. Car Engine Thanks. AG Falco
Fuses 2 & 6 ? Thanks. AG Falco
Do you use the centre button on your key to just open the boot or the bottom button to open everything? Would the fuse cover all the central locking not just the boot? Thanks. AG Falco
Segment display type found on S trim? So not maxidot / MFD type found on SE & SEL trim Don't think this can be changed. Thanks. AG Falco
Installing Satnav
I use Android Auto for navigation. Have you got a Smartlink icon in the Menu section? If so:- https://www.google.com/search?rlz=1C1CHBF_en-GBGB917GB917&sxsrf=AB5stBhDcXxGrFAR5oB2izJFhK-pjp-YqQ:1689618505609&q=smartlink+skoda&tbm=vid&sa=X&sqi=2&ved=2ahUKEwiRpNS2r5aAAxW1RfEDHd1kChAQ0pQJegQIDBAB&biw=1540&bih=738&dpr=1.25#fpstate=ive&vld=cid:32914240,vid:kftbdRQP4R0 Thanks. AG Falco
Brake pad anti rattle shims
This is used instead of using shims. I am up to 73K miles on original brake disks and pads from new but they are now more than half worn. I do remove, clean, regrease and refit them once a year though. Thanks. AG Falco
Left or Right?
Sensor warning lights and alarm issue.
Some garages might say no just because they won't want to do it, rather than because it is not posable. Look here noting that VCDS is being used :- Thanks. AG Falco
Direct TPMS replacement valve / service kit
The do sell spare valve stems as that is where my work get them from. It will be their own part numbers, not OE though. Glad you have it sorted though. Thanks. AG Falco
On some cars you ( A Garage ) can run a test sequence on the ABS Unit which will move all the parts to free up any stuck parts. Normally done at the same time as changing the brake fluid. Thanks. AG Falco
https://autogem.co.uk/tpms-zone/tpms-service-kits/ Thanks. AG Falco
New Fabia auto
You can download maps first at home via wifi, and then use them offline so you use no data at all. I also use this when I go abroad. This also works when you don't have a mobile data connection. Thanks. AG Falco
It is normally the sensor that gets broken, not the valve stem! Does the car tell you the individual tyre pressures? Thanks. AG Falco
Does the key fob battery last longer if you use it every day?
So the wife went to use the Fabia yesterday and got the spare car key out of the cupboard. But no red light on the fob when pushing the buttons. ( Flat battery? ) This key is hardly used. When I get home I try my key ( which is used every day ) and this still works. So I think that the battery in the spare key that is hardly used, is flat. So I swap the batteries over in the keys. But the battery from my key wont work in the spare key. So is there a fault with the spare key? And the battery from the spare key wont work in my key. So I swap the batteries back and then at least I have one working key. Today I go to Bath with my key and when I try to come back, guess what. My key stops working, no red light on the fob. So I get two new batteries, CR2032's are tight but will fit, and guess what, they both now work! This is the first time I have fitted new batteries in either key in 7 years since new. So does the battery last longer if you use it every day? Thanks. AG Falco
Strange "humming" noise when driving....
You are checking for a saw edge pattern on the inside edges. If they are NOT directional tyres then try swapping them from side to side. Thanks. AG Falco
Rear tyres? Inside Edge? Thanks. AG Falco
Issue with manual heating/A/C direction dial
Would agree. Thanks. AG Falco
MPG Remap
How much fuel in litres did you use? Thanks. AG Falco
