Everything posted by AGFalco
Octavia I Movement from Tie Rod Ends
Or track rod ends? From 13 to 19 seconds in the video it looks like you have movement in both inner tie rod and outer track rod end joints. Thanks, AG Falco
What material are waterpumps made from on the Fabia 3?
When yours was replaced, what did your mechanic say it was made of? Thanks, AG Falco
Part Number Please!
If it is an electronic release type then power is getting to it. Find the metal manual emergency release button inside the boot. Then disconnect the power to the boot release and try to shut the boot. Make sure you can get to the metal manual emergency release button inside the boot before shutting it. See if it now works manually. This might tell you if it is an electrical or mechanical problem. Thanks, AG Falco
Alternator appears not to be charging, but no warning light
An unlocked car uses more electricity than a locked car. A bit like the difference between a mobile phone being on stand by and being completely turned off. Thanks, AG Falco
Wheel question
Only with Negative offset not the more normal positive offset wheels. See below. https://www.performancealloys.com/alloy-wheels-offset#:~:text=The ET of a wheel,3SDM 0.05 White alloy wheel. Thanks, AG Falco
Part Number Please!
Is it still under warranty? Is the lock just jammed? Thanks, AG Falco
Wheel question
Depends if it is a positive or negative offset. Positive will be marked ETXX. Negative will be marked ET-XX. Note the '-'. This will help you get your head around it. https://www.performancealloys.com/alloy-wheels-offset#:~:text=The ET of a wheel,3SDM 0.05 White alloy wheel. Thanks, AG Falco
All Season Tyres....
Yes, not all of them are like that but some have come out with Pirelli P7 All Season. The Peugeots tend to run Goodyear Vector 4season. LR like Pirelli Scorpion Verde All Season. Pirelli only make just over 3400 different types of passenger vehicle tyres at the minute. Down south here I run All season just through the winter. Thanks, AG Falco
Brembo Xtra Brake Parts
Tried this Company:- https://bremsentechnikgroup.com/ +44 (0) 1748 831200 [email protected] Bremsen Technik Group, Bremsen Technik House, Station Road, Brompton on Swale, North Yorkshire, DL10 7SN Thanks, AG Falco
There are several cars where All Season tyres are standard fit from new. Peugeot 2008, Fiat Panda 4x4, Skoda Yeti & some LR's come to mind. The problems happen when the front two wear out and pair of summers are fitted. Thanks, AG Falco
Wheel question
Especially when the wheel is 1.5 '' narrower. Look here:- https://www.willtheyfit.com/index.php?width=225&aspect=40&diameter=19&wheelwidth=8&offset=44&width2=215&aspect2=55&wheel_size=17&wheel_width=6-5&offset2=41 Thanks, AG Falco
- Knocking noise when accelerating and turning
Scala, Android Auto music volume is affected by background noise
Use the infotainment system and look for this:- Sound Settings The scope of the following menu is dependent on the vehicle equipment with the sound system. › Press the key → . or › Press the key (Bolero). ■ Volume - Volume settings ■ Traffic reports - Adjustment of traffic announcements volume (TP) ■ Navigation announcements - sets the volume for the navigation announcements ■ Voice control - volume setting for voice output ■ Maximum switch-on volume - Sets the maximum volume after switching on the device ■ Volume adjustment - Speed-dependent volume increase ■ AUX volume: - Sets the volume for the device connected through AUX Thanks, AG Falco
Axle stand positions
Front or rear, and what are you going to do? Thanks, AG Falco
As Above, from 3.05 onwards. Thanks, AG Falco
- Space Saver Rim and Tyre + Tools
vibrations above 50mph
It can, by regularly rotation, help to stop the sawtooth pattern on the inside edge of the tyres developing. This is normally noticed by a wheel bearing type noise. Thanks, AG Falco
Headlight on light
The Fabia III is the same. No warning light for side/parking or dipped beam. With the lights off the dash lights are on, and the centre console switch lights are OFF. With the side/parking lights on the dash lights are OFF, and the centre console switch lights are on. With the headlights on the dash lights are on, and the centre console switch lights are on. With the lights off or on side/parking, the dash lights also get darker the darker it is, and brighter the lighter it is. Thanks, AG Falco
Did you swap them from side to side as well? Thanks, AG Falco
Rear tyres? Avon ZZ5 are asymmetrical so get the rear wheels/tyre balanced and refit them on the opposite side to which they were fitted. Thanks, AG Falco
- Octavia MkIII windscreen washer jet partially blocked
My TPMS is playing up.
'and I have a slight rumble from a wheel bearing' as reported by the OP on 22 April 21. Thanks, AG Falco
Check / correct all tyre pressures and then set the TPMS. Check all pressures in a week or if the TPMS light comes back on. Repeat every week and assume you have a problem if one tyre has gone down in pressure. Please note, the car TPMS system does NOT measure your tyre pressures. Thanks, AG Falco
Unexpected problems on my Fabia 3 combi.
This I think is easier to replace as it is on the front of the engine just above the oil filter. It is not connected to the cam belt at all. Thanks, AG Falco
- 20 replies
- fabia 3
- problems
- totally
- unexpected
Tagged with:
- Unexpected problems on my Fabia 3 combi.
