AGFalco
Everything posted by AGFalco
  1. It's a Petrol TSI engine. Please note there are TWO water pumps on this engine. Which one is leaking? The mechanical one is on the opposite side from the timing belt so is not touched when the timing belt is changed. It is integrated in with the thermostat housing and is on the gearbox side of the engine. The other is electrically driven and is at the front of the engine. Is the noise the tyres? Thanks, AG Falco
  2. If you set a maximum speed when you are towing you might find you get a dash warning when you exceed the set speed. This can also be set if you have winter tyres fitted as well. Had a customer in yesterday that had unintentionally set the winter speed warning for 20 MPH. The warning noise worked every time they exceeded 20MPH. Thanks, AG Falco
  3. The limiting stopping power on a car is the tyres as they give up grip before the brakes stop working. So get grippier tyres if you want to stop quicker. Thanks, AG Falco
  4. The only difference between the 1.0 TSI 95PS and 110PS engines are the engine map and the 110PS has the 6 speed gearbox. So if the remap from the 110PS engine was used ( by Celtic Tuning? ) then this should be as good as 110Ps engine is. Thanks, AG Falco
  5. It fits in the spare wheel well without needing to be deflated! Skoda Fabia III 1.2 TSI 2016 is also a £30.00 road tax car. Rates did go up from April 2017 though. Thanks, AG Falco
  6. The overall diameter of a 15'' wheel with a 185 60 15 tyre is 603mm The overall diameter of a 16'' wheel with a 215 45 16 tyre is less at 600mm The extra width might be a problem though. Where do you put a normal wheel/tyre if you have had to put the spare steel wheel/tyre on? Thanks, AG Falco
  7. I have 15'' Alloys on my Skoda Fabia III 2016 and I have a full sized Alloy in the boot as well. I ordered it with a full sized spare but this came with a steel wheel rim. This I swapped for an alloy the same as the rest of my wheel rims. You could try and see if one of your wheels/tyres fit in the wheel well first. I have always found a spare wheel/tyre that is the same size as the rest more useful than a space saver. Cambelt? Thanks, AG Falco
  8. Is this compared to last years fuel consumption figures? Thanks, AG Falco
  9. How does your infotainment manual suggest you change the date and time then? Thanks, AG Falco
  10. Infotainment system. Car Settings Time, Date and Unit settings. Page 68. Thanks, AG Falco
  11. The belt manufacture is Continental and they suggest to check it at 160,000 and then every 20,000 The car maker, Skoda, suggest ( In the UK ) you change it at 60,000 or 5 years which ever is the soonest. Thanks, AG Falco
  12. Try this post. Thanks, AG Falco
  13. Also:- 4 Leafed clover = blessed with good luck. Thanks, AG Falco
  14. Only one owner. Thanks AG Falco
  15. You weren't looking hard enough. They were behind the blessing of unicorns at the bottom of the rainbow. Thanks, AG Falco
  16. Spring - four leafed clover Summer - Sun Autumn - Rain / Cloud Winter - Frost Thanks AG Falco
  17. Also note that if you unlock the doors but don't open one, the car will relock them after a short while. So this is how you can then come back to a locked car but with all the electric windows down. Thanks AG Falco
  18. Here:- http://www.kopacek.com/Skoda/FABIA-III/Genuine-Skoda-Autoas-rear-emblem-´FABIA´-MONTE-CARLO-black-version Thanks AG Falco
  19. Mine is not a lease car and I am the first owner but it:- Came from a Dealer in Nottinghamshire. Was collected from Warrington. Has only been serviced in Hampshire. Lived all it's life in North Dorset. Thanks AG Falco
  20. It's one of the four seasons. Thanks AG Falco
  21. Push it and find out. Dare you. Thanks AG Falco
  22. Number of previous keepers is Zero. So you would be the second owner. Thanks AG Falco
  23. They probably only have barrels of oil. My last place had a 1500 litre container for the common stuff and barrels for the rest. A barrel is almost 160 litres. TPS depot. Thanks AG Falco
  24. Negative first, positive second on disconnect and the other way when reconnecting, please. Thanks AG Falco
  25. I want one. Thanks AG Falco
