Warrior193
  1. Rather like the old joke when it was rumoured that NZ was going to convert to driving on the right - to ease the transition, vehicles with registrations ending with odd numbers would transition on Monday - even numbers on Tuesday.
  2. Hi, welcome to the forum. Is there any sign of oil leaks higher up on the engine? Do you think that you may have overfilled with oil recently? If no to first question, it could mean that the crankshaft seal is leaking - this would mean removal of the gearbox to check, is there any sign of the clutch slipping?
  3. It clearly seems as if this is speed related - is the GPS in use (navigating) when this 'beep' sounds - is it possible that there is some sort of 'speed nanny' operating when you exceed the NSL by 6 MPH? I've never had it come up on my Octavia though 😇.
  4. I really hope that 17,000 rpm is a typo 🤔
  5. @MorayDavid Opie Oil website specifies fully synthetic engine oil to VW504 00 - 507 00 standard, 5W-30.
  6. Is that test throwing up a 'replace battery' message? I have found testing my Octavia (Moll, EFB) battery against two standards (DIN & SAE) gives slightly different readings - but appears to give a reasonable idea of condition.
  7. Or the very real risk that some pedestrians will 'take the gap' between vehicles because they're going so slowly.
  8. They will probably start to blame an increase in ozone.
  9. As to why they say take to stealer for full change - that's just to drum up business for their network.
  10. I have seen the 'engine must be running' message a few times on my TSI (obviously not for regens) - I usually connected it to cabin or engine coolant temperature. Try a recharge and get the battery condition tested.
  11. Try looking up on Opie Oil website for correct spec. What TSI engine do do you have?
  12. Hello David, use the oil specification that Skoda or VW state for your engine.
  13. Hello Micky, it is likely to be something like the requested cabin temperature (on AC) is not down/up to setpoint, there are quite a few parameters that will inhibit auto stop/start - one I see now and then is 'windscreen may fog' - I wouldn't rule out a battery problem though, are you able to test it?
  14. Good idea to avoid oil-burners if now doing lower miles. From issues aired by members on this forum, it would seem that there have been a lot of 'teething' problems with the electronics in the Mk4 - I'm sure some owners will be on soon to give better informed advice.
  15. Hello, welcome to the forum. 1 - I've never had an issue with pads squealing. Are you sure your pads are ok? 2 - I suggest copper ease grease (or similar) applied sparingly to the metal backplate of the pad. 3 - Yes, not an issue to remove then replace pads, make sure to refit everything correctly (retaining pins, shims etc.)
  16. Hello Pete, welcome to the forum. I'm not an EV owner, but I would suggest battery life/remaining capacity is more likely to be adversely affected by the way it's charged - I.e. always being charged to 100% Strongly recommend getting an independent check of battery condition on any 2nd hand EV.
  17. @Sunmoon Prezafab means that they believe that the timing chain should be changed as soon as possible (now)
  18. Hello, welcome to the forum. Yes, the 12 volt sockets are live at all times.
  19. If staying with metal caps once you've got the seized ones off, put a smear of copper ease grease on the valve stem threads before replacing.
  20. Hello YT, welcome to the forum. I remain impressed with the low-down torque of my 1.4TSI. Still happy to have missed out on the 'update' to the 1.5TSI COD version. Not totally convinced with SHIMBOs 1.0 TSI 110 either - although it would be the better one to chuck about on a gravel stage. 😁
  21. Enjoy your new car and holiday. If travelling in UK, avoid motorway rush hours if you can - I always try to get an early start.
  22. I always use nav as a guide, especially if I am not familiar with the route or destination, but do not rely on it for speed limits and ignore suggested routes that don't make sense. A feature I always find useful, even when not actually using map guidance, is the compass. SWMBO is not a good map reader, so it saves a whole lot of money on divorce lawyers when she is travelling with me. 😇
  23. Hi Wurze, I have seen more than a few halogen bulbs fail where the filament breaks, but temporarily 'welds' itself back together while flopping around. AFAIK, the glove compartment, trunk and similar lamps are not monitored by the system - as they are not safety related.
  24. ^^^ Plus avoid using full throttle, vary speed often rather than keeping to steady speed, don't allow DSG to shift up to top gear too early (perhaps switch to S).
  25. It makes no difference what system OP has - the changed speed limits will be invisible to all nav systems until (or if) the navigational data is updated.
