Disable alarm for ferry
There may be a physical switch for the internal alarm sensors at the base of the B-pillar. Otherwise, locking the vehicle by pressing the 'lock' button on the fob twice in quick succession leaves the vehicle locked but with deadlocks and alarm deactivated.
Fabia MKII - 7500km/180 days Service Interval On Reset?
Bit of an odd one - only aware of two oil service schedules, fixed (annual) and variable (up to 2 years/or xx km) Have you tried the reset procedure a second time? There are two service schedules though - Inspection Oil service These require separate resets and can sometimes be a bit fiddly to get the correct schedule reset.
Garage clears all ABS fault lights but then they come back on. Am I really looking at £1k repair?? Now with CODES
I'd suggest that you have your new battery tested - then have the flagged ABS wheel sensors checked.
Map Updates for Octavia 2015
Hello, from your device number, I believe you actually have a Amundsen MIB2.
Coolant over pressurising
Great, thanks for that - good news that the overpressure issue was due only to poor coolant circulation.
Still a bad idea to leave an engine idling for a full hour while stationary in traffic. One of my cousins got trapped once in heavy drifting snow on Desert Road - was stuck for more than 12 hours! Resorted to firing-up engine every 10-15 mins to provide a little heat.
Personally I'd have shut it down way before then - but it was the au pair driving it at the time. Symptoms appear to indicate something happened after initial overheat, but have not seen any report of suggested combustion products test yet
Hello@Jimbo78aus have you solved your problem yet?
Octavia Mk3 Fuse Holder Help
Hello, welcome to the forum. Check the underside, it's possible that it's similar to the Mk3 engine air filter box - with securing screws from the bottom!
Photography Thread
And there was me thinking that all the bu**ars were biters!
If you could just post any DTCs listed for the ABS system, it would be a start.
Hyundai i40 Rocker Cover Injector Replacement
From the image, I doubt If that odd injector would even fit! Something more than a bit odd going on there, it doesn't even look the correct length to reach into the cylinder! If the cover is plastic, I'd try something like a plastic welding stick - or possibly an epoxy filler if the area is not required to be flexible.
I'd suggest trying to repair the hole if it's the one I see near the edge of the opening. That 4th injector doesn't look right - are you certain it came from your engine?
Oct MK II Rear Fog RHD to LHD
I think the lamp monitoring system is looking for a change in current in each circuit - I suspect a significant increase or decrease in any monitored circuit will trigger the warning.
Spare kessy out of sync
The remote fobs use a rolling code which is different each time it is used, what is most likely to have happened is that your unused fob is generating codes outside the range the vehicle is expecting to see. A search of the forum should give you the correct procedure to resynch your fobs.
Battery change
Under normal driving conditions the alternator will only charge the battery to around 75-80% - leaving headspace for regenerative charging during braking/overrun. Strongly recommend adaptation (coding) of the new battery to the BMS.
What material is the rocker cover made of? how big is the hole in it?
...But wouldn't there need to be a coding adaptation to inform the light monitoring system?
Octavia MKIII VRS Mobile Phone Cradle Location
Do you actually need physical access to the phone screen while driving? Does your car not have MFSW - and navigation on the infotainment screen?
Bolero radio code
But OP was asking if code required for infotainment when disconnecting battery to change it - not about replacing radio.
Bolero radio code
My understanding is that there is no code for the user to input - the MIB infotainment system is protection coded to the vehicle using non-volatile memory. The only thing that may be lost when disconnecting the battery is radio station pre-sets.
- Alternator problems
Hi everyone!
Quite interesting that the cam sprocket appears to have failed at the drilled hole - does that hole correspond to any locking device?
