daveo138
Everything posted by daveo138
  1. Hopefully I dodged a bullet. My Octavia was registered in about week 9 of 2015, so would have been manufactured a bit earlier.
  2. I did similar on a B5 Passat (2003). The VAG kit was readily available on eBay at the time. I also had a main dealer retrofit it to a B6 Passat. It was a company car, purchased at 12 months old. The first month that I had it, it spent 2 weeks at the dealer with DSG problems. They offered me a free service as compensation, but I asked for cruise control instead, as I wouldn’t have benefited from a free service 😀. When negotiating on my next company car, a B7 Passat, I got the dealer (a different one) to fit cruise control as part of the deal. None of the above were adaptive cruise.
  3. Cross Climate 3s fitted to the rims yesterday morning and I put them on the car in the afternoon. Early impressions are good. Looking forward to winter 😀
  4. Me too, but don’t tell anyone 🤫
  5. Thanks all. I have acquired a set of 6.5 x 16” Octavia wheels, which I am now renovating. I think I will be going with a set of 205/55x16” (91V) Michelin Cross Climates.
  6. How did you get on? I'm currently considering doing the same. Wheels and Tyres - Skoda Octavia Mk3 (2013 - 2020) - BRISKODA
  7. I have thought that the suspension on my Octavia seems a bit harsh and, having searched the forum, it seems that I’m not alone. My car is an ‘Elegance’ with 17” rims and 225/45x17 tyres and the beam axle rear suspension. Looking at the driver’s handbook, it says that the load rating for both 205/55x16 and 225/45x17 tyres is 91. However, it looks like the majority of 17” tyres that are available have a load rating of 94, as are the ones on my car. I think this could be contributing to the problem, along with the 45 profile on our potholed roads. I’ve decided to go down a wheel size to 16”, as 16” tyres are much more available in 91 load rating, together with the 55 profile, I’m hoping for a more comfortable ride. Has anyone else tried this? Out of interest, what size wheels and tyres does the VRS have?
  8. I’ve bought a set of B4s for the rear, but I haven’t got around to fitting them - I’ve had them for more than six months 🙄 I really must fit them. It’s not a VRS, just a ‘normal’ Octavia with a beam axle, but I find the ride a bit harsh.
  9. All the 5s on the Octavia. Unfortunately, I missed it with the Vauxhall Omega.
  10. What’s the coolant level in the header tank? What sort of garage was it? Main dealer, Indy, general garage?
  11. Are these engines known for getting blocked pick-up pipes/strainers? I know my neighbour had an Audi TT 1.8T which had a badly blocked pick-up. If it is likely to be an issue, I’ll drop my sump and sort it before it’s too late.
  12. The OP hasn't visited since October '24, so you may not get a response. As has been said, worth a search to see how successful others have been. I believe this is quite a common fault.
  13. I'm in North Derbyshire, otherwise I could have helped. I have OBDeleven. I doubt that you could use a generic scanner/code reader unless it's very high-end.
  14. Whereabouts are you?
  15. I think you can also rule out the weather. My fuel consumption reduced noticeably in the spring, when the temperature started to increase.
  16. I'm no expert on multi-link suspension - I don't have it on mine - but it looks to me like you would adjust the camber first, using the bolt on the inner end of your new transverse arm, then the toe afterwards, using the other bolt on the track control arm.
  17. I do have a bit of a strange smell in my car, after using the air con. I have used a ‘bomb’ in the past, but it didn’t really work. I have a foam spray cleaner, but I’ve read that it shouldn’t be sprayed through the vents, only up through the drain hole. I have yet to locate the drain hole (Octavia).
  18. I'm using my father's 1970s Halfords ramps. I made some wooden adaptors which I use together with some other blocks of wood. The photo shows my other half's Rover 25, but they work equally well with the Octavia.
  19. You can reset the service indicator without a code reader - search YouTube - although it’s always worth having something that will tell you if there’s a problem with your car. I have OBDeleven, which is particularly useful.
  20. I doubt it’s the bulb, as you would still get the telltale light on the dash. I would start with the fuse.
  21. It seems you are not alone. This thread is from a couple of weeks ago.
  22. I'd be inclined to wire brush it, treat it with a rust converter and paint it, or Waxoyl it.
