Everything posted by Bap33
Camera POI.s
Hi, And how do you upload them onto your Amundsen or Columbus? I think, this is possible for non-FL versions, but I've always been told, this is not possible on a MY2022 (FL) Columbus for instance...
What have you done to your Kodiaq today?
Hi, Were fed up with the original seat covers? Or did you want to protect them against UVs, stains o whatever?
Facelift mirror caps on non facelift car
I suggest asking @JR RS. He has made this mod on his Gandalf Hulk 🤭...
Scout Bumpers & Arch Trims Wanted...
Just click on "Welcome" and follow my instructions above. 😉
Try again, click on the link, then Welcome > Free Services > CarProg2. Finally, use drop down menus on the top : Language / Brand / Car Model (SUP for Superb) > Model Year Body parts are in Part #8. Then look for your parts. ;) I doubt, you don't find anything...
New discs ands pads after only 29000 miles sounds a bit early to me. What kind of usage doo you have? Just curious to understand. 🙂
Hi, Lucky you, very rare model! I think ifinterface.com could help you finding the P/N, you're looking for. 😉 However, if you have the normal Estate front and rear fenders, I don't know if the plastic wheel arches trims will be easy to install on your car. I think (still need to be verified) the original wheel arches are bolted or at least clipped on the fenders. ifinterface should help you finding how the original Scout configuration is and what you really need anyway.
@JR RS I fear Gandalf doesn't still suit anymore. IMHO, Hulk would be more appropriate, now. 😁 ~400BHP. Wooo... I assume you don't need hair comb in the morning anymore. Just sit in the car, press right pedal: Hair dress fixed! 🤣
- Superb Estate Load Floor
Diesel fuel additives
Hi, I recommend reading the user's manual. As Far As I Remember, Fuel Additives are prohibited by VAG. Regarding oil additives, how many miles on the clock of your Superb? If it's already above 100000, I fear a pre-oil change additive may be worse than a plain oil change. Indeed, if it has too much detergent properties, it could loosen a whole bunch of residue that could stick where it shouldn't and thus clog some holes/hoses/pipes, and then preventing the normal oil flow with many damages as a consequence... If you really want to have an idea of how dirty it is. Maybe just remove the oil pan and clean it with white spirit. Then just pay attention to the oil pan seal. I don't now if it's a real seal with a P/N or if the oil pan is sealed using a gasket sealant.
Long coding 17 instruments cluster
Hi, Your long coding depends on how your Superb is specced. Considering yours sayings, I assume your garage is not an official dealer. Based on this, I would recommend to go to an official dealer to have everything reset and have the bill paid by your 'so-called' specialist. Crossing the fingers for you.
How to change Brake fluid on Kodiaq Mk1
Hi, I had envisioned to write a full 'How to' Guide, but everything is exactly the same as for my ex Superb Estate Mk3 : Same 11mm bleed screws, whose tightening torque is 10 N.m Same fluide quantities : 0.3l for rear calipers / 0.2l for front calipers (add 0.15l if manual gear box). Same bleed sequence : 1st Rear Right caliper, 2nd Rear Left one, 3rd Front right one and 4th Front left one. Removing the wheels takes some additional time, but make it a lot easier, especially on the rear calipers, whose access to the bleed screw is not that easy due to EPB motors. I took me 2:15 hours, but one of my neighbours (a Superb Mk2 onwer) wanted to see the operating process. This was an opportunity to chat with him during this maintenance operation, since he was formerly an AWACS and B-777 pilot. I think this operation requires 1:30 hour (without hurrying too much). @moderators : I know duplicating a topic is 'banned'. I hope referring to another post is fine nevertheless. Otherwise, feel free to delete. I hope this helps.
Hi, Change brake fluid today. Nothing difficult. All went fine. Test drive was OK. it costed me only €22,8 for 1.5l of brake fluid. Happy Kodiaq owner :)
Touch up paint
Be careful with eaby selleers! Don't forget to make a test on hidden parden before. I had bought a touch-up paint for silver grey Audi rims on ebay 6 or 7 years ago, with the so-called matching paint code and it was not the right color at all. Wasted some quids...
Carscanner profile selection help/marital help!
Hi, If, you switch off your car once EPB is in maintenance mode, it will be ok. Then just switch on, when you want to leave maintenance mode. Have a look to the ´How to’ I´ve posted. 😉
Hi, I faced similar problem with my own Kodiaq. The battery autonomy is very low compared to my ex Superb Estate Mk3. Hopefully, I have a battery booster and a battery charger which saved me 2 or 3 Times after Coding sessions… Now, I know I have to limit my coding sessions to 20-30 mn as a maximum.
Low oil level dq381 while change
Hi, On DQ381 (DSG7), there are 2 drain plugs, whereas other DSG mainly have only 1. Could the mechanic have forgotten to remove one of the two? This could explain why he drained only 3-3.5l and refilled only 4l instead of the 6l recommended in the workshop manuel… IMHO, I would consider the job hasn’t been done properly…
VIN with Sleep Package
Then just contact the website support and give them your VIN. 😉
Hi, I've found the link in emails: https://www.oemvwshop.com/565885901g-vkr-565885901g-vkr-head-restraint-skoda-kodiaq-with-sleep-package-function-satin-black-grey-565885901g-vkr-p3575471/?sti=7652911 This reference is for black interior (VKR stands for black). You can contact them and ask for double check based on your own VIN before ordering. This is what I did to be sure. The only thing is that I had to blacken the grey seams with a permanent marker to perfectly match my interior trim. But maybe yours doesn't need this... Yes I know, the price stings a bit... a lot! Hope this helps.
Hi @Benja77, I´ve bought a pair of these headrests. I can give you the P/N but the color code will be needed to match your interior color. I´ll have a look to find the P/N tonight.
Cosmetic Suggestions
I think I´ve seen covering kits on Ali… This should be the cheapest option.
The Kodiaq I picture thread
It made me think of 'Land Rover G4 Challenge', though not as dirty as it has been this winter: 🤭
Hi, I had bought an Audi Q3 Mk1 luggage flap. P/N is 8D9862565 (color code is 4PK for a black one). I know this can exist for different Audi models (just ask the dealer to change the first three characters of the P/N). It's really worth asking for a quotation on 3-4 models (A4, A6, Q5, Q7, in addition to Q3?) because prices can vary from simple to triple! I bought mine for my ex Superb Estate Mk3 roughly 7-8 years ago. I think it was around €35.
Rear wiper blade replacement. 2023 Kodiaq VRS.
Hi, Ordered 3397016895, but fortunately, I recieved A284H and drags have gone!
