Everything posted by Bap33
Installing memory seat module on front passager seat, possible?
Wow , thanks a lot for all your search. I'm going to read this russian website carefully.
@SashaGrace I would have bet, you would be one of the first to answer! The Queen of VCDS mods!... I've just been looking on an online ETKA and it seems, I should only need to add the memory buttons. No harness, no dedicated module! P/N is then 3V0959769A. It costs ~32โฌ If anyone with RHD L&K could share the coding of its driver seat, it would be much appreciated. Does anyone also know how to declare this new feature to overall system (Module 19-Gateway ?) ? Thanks.
Hi all, I have a MY2017 L&k Superb, thus it has 2 electric front seats. It's a LHD version. Since few days, one of my kids is old enough to sit on the front passenger seat. But she's too small to see the road, when the seat has the settings that my wife likes. She needs to raise it a bit. But I now imagine my wife may be quickly fed up with adjusting 'her' seat position each time my older kid has been sitting on the front passenger seat. Since a memory seat module is available on driver seat for both LHD and RHD version, I was wondering if it could be feasible to install the memory seat module from a RHD version on my front passenger seat to solve this 'problem' and make everyone happy. I assume I would need the memory module, the button, a small harness to connect the system, and then a bit of VCDS coding. Do I miss something? Note: I did not pair the settings to any of the 3 key fobs, so this would not be an issue that it could make a mess with front passenger memories. Any advice on this mod? Thanks for your feedbacks.
- Superb vs 5 series
Wheel Colour change?
Mine is a L&K and Iโve got glossy black 19โยด as an option. They suit perfectly to my estate version (in moon white).
Estate Bumper Protector
You can find several options on Kopacek.com ๐
Superb headlight with SLA adjustment
Glad for you! ๐
Debadge - rear options
Not a big fan, may be THE step too far. IMHO there's something missing... I would put a Skoda logo back. But if this suits you, this is fine!
Superb: Reversing Camera Wide angle
The rear view camera is automatically washed when rear gear is engaged and you wash your rear window at the same time.
Blind spot assist and rear traffic warning issue
Sorry I was meaning the towing hitch indeed. I made a bad translation.
Superb 2.0 Tdi
Did you have a look to the coolant tank? There's a silikat bag, supposed to preserve water pump lifetime. But it seems this bag may burst and then generates some water pump issue. FYI:
@miloshst May be you can find some information here: https://cardiagn.com/2015-2018-skoda-superb-iii-3v-worshop-manual-owners-manual-wiring/ IMHO, there are 3 possible chapters to look at: - Maintenance - Electric system - Body repair - exterior
Cambelt change interval ?
Very strange, since VAG only recommend a cambelt change based on mileage (something like 180 or 210000 km depending on the engine type) but without any time mention. I know many garages still use the old recommendation to change it after five years, to save their turnover. Of course, if one doesn't drive that much, it sounds reasonable to replace the cambelt after 7-10 years if recommended mileage is still not reached. Very late to answer this, but a good tip to check what has been done is to ask for replaced used parts. Additionally, if they're parts you can easily access, just put a mark (with onyx marker or paint) on the part to be replaced.
Fortunately for you it seems it still works when you tick boxes. What you describe, correspond to the standard behavior when towing (blind spot and rear traffic are deactivated). Therefore I would suggest to check the electric plug of your trailer (if you have one).
Wheels help please
+ glossy black 'eye lid' on front fog lights
What Tyres?
This is unfortunately not systematically true. Here is my humble experience: Several years ago, I had Michelin PS2, whom I was very satisfied with. Time for change had come and PS3 version appeared on the market. I choose them, but I felt disappointed since there were less grippy. I kept them until it was time to change again. I then choose PS4 version, which reminded me how PS2 were good and PS4are even better. Several years later I read that PS2 was derived from a 'sporty rubber' version, whereas PS3 were derived form Michelin Pilot Exalto, instead of PS2. But... PE were more comfort oriented than PS2. This is why I felt disappointed, they were less efficient than PS2. Currently PS4 are derived from a 'sporty rubber' version again!
The Superb III Picture thread
Just ask a moderator, or 'report' your own message to explain, may be...
- How to remove A-pillar trim panel / How to replace retainer for park tickets on Superb Mk3
Wheels help please
Hi Default setting of suspensions is quite soft. I do have 19" (with DCC indeed), but I don't feel it too hard. Have a try if you can. If you're looking for wheel dimensions: 18" --> 8Jx18 ET44 - Tyres are 235/45/18 98V XL 19" --> 8Jx19 ET44 - Tyres are 235/40/19 96V XL
Is 1.5TSI coasting on D mode while Normal mode selected?
Bad engineering idea to lower CO2 emissions . I'll really take my time to have a test drive on my next car to check it doesn't have this stupid default setting! I don't feel in a safe car, when coasting is activated! Additionally, I don't see how it can really save fuel and CO2 emissions since coasting sets the engine ~at idle, whereas normal mode fully shuts fuel injection and hence makes no CO2 emission at all. A quick look at instant consumption display on the dashboard simply confirms this.
Need someone with A5 camera coding for 2017 model
Hi, Lucky you! I own a 2017 L&K Estate with A5 front camera, Lane Assist, TJA and TSR. Here's the coding I have: Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3QD 980 654 HW: 3Q0 980 654 A Component: MQB_B_MFK H08 1272 Serial number: 21081741P10043 Coding: 0204080200000401002623558150A90098000E100040 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_MFKBoschMQBB 001001 ROD: EV_MFKBoschMQBB_001_VW36.rod VCID: 08317829B32018C44A-805C Note: it also has SLA, which may introduce differences, if you don't. Enjoy!
Strange that VAG/Skoda have changed the DSG control laws. I don't have this on my DSG6 DQ250. If I really enjoy it, I doubt I would be satisfied with coasting as a 'standard' mode on my car.
Front discs noisy
Oh, OK, I had forgotten the piston rod on the caliper. I was only thinking to the disc itself. Good point !
Front discs noisy
Are we really talking about brake discs? or did I miss something?
May be, I miss something in your comments guys, but IMHO, there are 2 things to be considered. - Driving profil selected from the button close to the gear lever ('Comfort' / 'Normal' / 'Sport' / 'Eco' / 'Individual') - Gear lever mode either D (said to be 'Normal') or S (for 'Sport'), selected by pulling the gear lever backwards. AFAIK, coasting is only possible in 'Eco' mode and gear lever in 'D' mode.
