Tell
Everything posted by Tell
  1. I'm not going back to the adhoc arrangement mobile phones drop down the dash. The FIS / VC put the next turn on the dash in front of you. Adhoc solutions don't. Admit the Google maps has advantages with the POIs better built in. Mib2 is more like a standard GPS system and can be made like it. Old Skoda tricks to do that, that I use. Yeti reckon that will be on mib1 probably not Android Auto ?. Maps no longer issued free. Horses for courses. See what mib4 is like next year. I'm waiting for mib5 🤣. Offline mapping is useful for travelling abroad and in rural areas where 4g is zero. Best to use both 😉.
  2. I'd say the issues they had on the European map Skoda fixed but haven't fixed yet on the RoW. Generally VW is resourced better but in the past the Skoda library of files has proved useful.
  3. You open the door every 15 minutes to keep the power to the unit if using the SWDL method... I think you can do it with the door open... I always open and close. That keeps the power on to the unit. I normally start if off, get back to the car after 15 minutes, get in, check, lock, get back. About 30 minutes in or so in two walk abouts... on European map it finishes in circa 40 minutes. Useful in that you can see what is going on, unlike the normal method of driving about and waiting to see whether it's done it. That part update is useful if experimenting with the files. Can take a bit of nimble finger work till you get it right. You don't click all but toggle the bits you want which would be navdb and Australia in the VW link if it didn't work. You'd go June release, then try a part update to the November release on the basis that the corruption might be somewhere else. Suspect the VW file will be fine and it's Skodas mess.
  4. One should always do that else its thrashing the SD interface.
  5. Feels to me like the RoW map still has the original issue of the European map till they sorted it out. I'd look at the VW RoW lighthouse file link at the top, if it's anything like what happened on the European side. Skoda made a pigs ear of it. It wasn't the zipping but the internal files they had messed up. Us that aren't taken by the branding twaddle just use what works 😂. The files are interchangeable. The SLA1 signature check protects the integrity of the files so it won't be the unzipping. It's passed the integrity check which is what happened on the European Skoda files but they had on their server files that didn't load in the car. They actually went live with that and pulled it. VW has yet to go live on those links as not on their website. Ah you are using my SWDL method. You have to upload a working one to get it back. Try the VW first then revert to your old file for the time being. There is other stuff going on which is where a second level of integrity checking kicks in.... My long years of playing with SWDL. You can do a part update with SWDL. If you can't get the VW one working either. Reinstall your old one then do a navdb update using just Australia on the latest. My old test when playing with European maps. I use Iceland as the test, 5 minute quick load. If that doesn't work, you reinstall just the old Australia map fragment back onto your old maps. You play about with the SWDL commands to get it to do part updates. The beauty of SWDL.
  6. We don't get auxilary heating fitted in UK cars... this is where the EV / hybrid people start their defrost early using the app. Quite happy to use built in maps.
  7. I'm planning to skip mib3 and mib4. Think about mib5 in 2029/30 🤣. Mib4 is 2024 on some models, like next year. I can see on EVs putting the heating on via connected services before you get in it has benefits. Seat side they still have problems that over the air mib3 updates that are incompatible to other software in the car, so whilst issues were fixed they get unfixed by Vag with over the air mib3 firmware updates leading to a trip to the dealer to update the offending item. Driving a dumb car seems to have many advantages till the bugs are sorted out.
  8. I note on the Seat side one person was having an issue with a firmware update for mib3 that they had bought. It wasn't seeing the drive letters come up which has also been mentioned. I referred them back to who they bought the update from and the suggestion was to use a dual usb drive (sub A) at one end opposite end usb C. The ones you reverse between PC and car. That worked. On map updates Skoda people here advised it's best to use one of them for offline mib3 updates. On another thread when I was researching Skoda experience on mib3 offline map updates. I'm wondering where this may be the cause of people's issues using adaptors / plug and socket leads, that don't connect all the pins. The other issue is the old Mac one. You must use cleanmydrive once it's copied to the USB if using a Mac. Old mib2 high Mac user chestnut.
  9. Yes they were out growing the 32GB card as the six moth updates passed. Its the level of detail on the maps now.
  10. You could read the contact pleaser label and see what is in it. The key jabbing. It will be the membrane type of switch as JR I would guess. I use to use contact cleaner on something or other, Volume knob on things in the old days. Too long ago,
  11. Well in the old days of electronics you just merrily sprayed contact cleaner into duff connections but that probably more to do with variable resistors not making contact than key press things. Wouldn't think it would damage it but probably not fix it. Probably a Google on spill Sprite on keyboards might be more useful. Might be useful https://www.howtogeek.com/674486/what-to-do-if-you-spilled-water-or-coffee-on-your-laptop/ Under 》》 Spray or drop some isopropyl alcohol on the affected keys, and then press each key repeatedly to work the alcohol into the mechanism. The more you press it, the looser the key should become. Don't use too much alcohol, though, or you might wash the gunk farther into your laptop. 《《
  12. It's not helped when Skoda gets it wrong then the mibsolution people publish a fix when the VW was one was already out. Certainly, the Audi one six weeks before. Like the blind leading the blind. Use the first one that comes out and works. Hard luck for the brand that gets deemed as the one with the download that didn't work, since they published a duff one. Skoda seems to mess up zip files fairly frequently. The golden rule, all map files are interchangeable between VW / Skoda / Seat and Audi for Mib2 high. Only exception was when Seat was left out of the parts definition / FeC on one six month release a few years back. A misunderstanding or something with the brand members, somebody didn't attend a meeting. Subsequently, corrected, but if they do it again, you just add the navigation FeC of the one that worked. Why I now have Seat and Skoda navigation FeCs on my car. Could not be bothered to delete the unwanted FeC. Audi and Seat drivers have the special need of having the life long navigation FeCs installed either via the Mib2 high toolbox as DIY, or one of the AIO firmware upgrades via DIY or paying a retrofitter to do it. Something that VW and Skoda owners need not bother themselves about sincve they have the all important navigation "life long" FeCs installed.
  13. Some people like to wait that long thinking Skoda or Seat has a better taste to the digital product not that it's byte for byte identical. I note the German Skoda board is similar with people wanting to use a download from the Skoda portal rather than the direct web link or the VW file which is the best used on server response historically. Over a month ago if you used that Audi download bless them. No sign of the Mib2 Standard release, which will be six months ahead of the Skoda one. Wonder if they have hit technical production problems with that.
  14. Yes well if it's the uncorrected 350 it won't work. The mibsolution.one had the mod on it to make the Skoda files work but given they alter the web pages, that's probably gone by now. The German Skoda board was directing people to that prior to the VW link coming out. Best to stick with the VW lighthouse server link files, they work as has been reported on MartiniB's thread.
  15. You want to use the VW lighthouse one for 350, first link in the post above, if you haven't already. The map files are ìnterchangeable between mib2 highs which is what a Columbus is, so you use the first one published by whichever VAG brand. VW are better resourced to get it right on their servers. The source material is the same between the brands generated by an outsourced operation from Here Maps material. Skoda succeed in making it a pigs ear zipping it and publishing the file with a web page. It's a bit like ONS census material, processed and goes out. Different people do different things with it. All the same data, all the same end hardware and core software it's mounted on in this case unlike the census data... you'd have to be a census data user to get that 😂. Just the IT people mess it up. There is still no sign of the VW / Seat mib2 standard release for November 2023. Skoda have published "theirs" but since they run six months behind on the release it's the reheated June 2023 release. Old bread. Still waiting for new VWs loaves. They haven't appeared yet. It's a bit of a carry on.
  16. You do. Everything on the zipped file is dragged and dropped onto the SD / USB. Attached is the VW pdf guidance. Although the directory is labelled mib1 it takes files from there as well for mib2. Its a question that comes up from time to time. Just the way files are stored but you need the whole lot over. Discover_Pro_November_2020_EN.pdf
  17. First post, our Arona got us at Aldi on Friday. Wouldn't lock, start or do anything. Now carry a spare CR2032 for such occasions, as apparently quite a few people do. Unclipped the remote and new batter inserted. Worked. The wonders of Kessy. Evident the battery had enough charge coming out of the warm house but sitting on the back seat for 15 minutes in the freezing temperatures was enough to render it useless.
  18. Might have been a case of the long press on the on/off switch to cause a reboot would have fixed it. Leaving it off for that long would have dropped power so it gave you a reboot itself. There is a 20 minute power count down after you close the door when the system is still live. Getting a reboot in, in that period is your reboot. Over 20 minutes it naturally does it. The infotainment systems programming isnt that brilliant so they wander into areas of memory in the unit they aren't suppose to be in so misbehave. The reboot is the restart like a long press on your Windows power button when all else fails. I've had the case of the navigation image moving 1/2" to one side after loading POIs, a reboot fixed that. Swapping map cards a reboot is handy on a mib2 standard. Often fixes the issue after swapping map cards. The one I mainly do to get it to re read the card else it doesnt know if you are swapping between cards in that 20 minute window. Map updates plus the TMC fix. Only once has it crashed / done weird things like yours.
  19. For the online download where you get the updates over the paid system what people do to force the update is to put a route in across countries, that then forces the system to force an update. That's different to the cost saving update with no subscription. June and November via USB. That's wrong about it not retaining the maps it does. The fragment files you see in the update files are the geographical zones. The concept is if you put a route into Germany it then starts bringing down those segments. Offline it eventually does the update off the USB if the file is correctly placed on the drive. It's the criteria to nudge it into action which isn't totally clear. Mib2 high has a roll back position where if the upload if interrupted it will roll back a bit and restarts next time the unit is powered on. Mib3 will be the same with USB. This is where it's been said about ignition and stationary. Probably apes the over the air one. In the end if you don't mess up the presentation of the files on the USB and it's a valid released file without errors on their side, then it will do it, eventually. The release date changes and that's for the whole of Europe both online and offline update.
  20. It's the VW link VW portal: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P350_N60S5MIBH3_EU.7z That's proven to be fine for November 2023 (ECE 2024) aka the "lighthouse link". The Skoda one has had issues and was withdrawn from the webpage wrapper to it’s link to 350 back to 330. German Skoda community hacking that Skoda 350 file around to make good but the VW link above is fine. Map files are interchangeable between VAG brands so you use the first one that works.... why I've got my Seat mib2 high running on the Audi release from 6 weeks ago 🤣.
  21. & thanks to MartiniB's hard work. He doesn't have a mib2 high now (don't reckon) whilst I was sticking with the Audi release of 350 not wanting to mess up what I had. It was tricky with the German Skoda board to work out who was using what. Sorted now. 👌
  22. Not familiar with POI.DB3 but suspect it's a commercial program or user developed or knock off. How POI import works is that VAG has a specification and each unit has to be specified within the parameter file that it uses to import the file into the unit. VW often didn't populate the file parameters as new units came out. Often with the VW website when it was up. there were moans about it not seeing the car. After VW pulled the plug on their website import for POIs, Seat mib2 standard units with wifi it didn't see the import. Both the commercial suppliers and developed apps were not working with this unit. POInspector was the one I was using. https://poinspect0r.blogspot.com/ With these package solution you have to load up your own POIs. I did provide documentation that the author of the program used: https://www.seatcupra.net/forums/threads/uploading-speed-camera-safety-camera-user-pois.444799/#post-4780168 https://www.seatcupra.net/forums/resources/uploading-speed-camera-safety-camera-user-pois.12/ This package is backwards compatible but you have to put the work in yourself. Back to story. Spanish Seat forum uses published Spanish speed cameras that were imported into the VAG format and distributed by the forum. The guy that did the work was one of the mods. The missing infotainment identifiers were found by a German user. The system IDs appear in the firmware uploads so by studying those you can identify what is missing. There were / are two import files for the mib2 standard and high. I suspect that's the issue. it's a missing variant ID. I suspect you haven't got it. If you happen to have the firmware file for your system and visually check your POI import meta file I suspect you won't have the unit listed. Worth a check. Then go back to whoever supports POI.DB3 and say you need it added. Alternatively you could have the wrong upload. The latest meta file looks like this: ################################################################################# # # This is the description file for the Software Update of Volkswagen components # ################################################################################# [common] Vendor = "Volkswagen" Variant = "FM?-H-*-*-*" Variant2 = "17206" Variant3 = "17207" Variant4 = "37206" Variant5 = "37207" Variant6 = "47203" Variant7 = "47204" Variant8 = "17216" Variant9 = "17217" Variant10 = "37212" Variant11 = "37213" Variant12 = "47208" Variant13 = "47209" Variant14 = "17212" Variant15 = "37208" Variant16 = "47205" Variant17 = "17222" Variant18 = "47210" Variant19 = "17224" Variant20 = "37214" Variant21 = "17210" Variant22 = "17220" Variant23 = "17245" Variant24 = "17246" Variant25 = "17250" Variant26 = "17251" Variant27 = "17247" Variant28 = "17252" Variant29 = "17254" Variant30 = "17255" Variant31 = "17268" Variant32 = "17269" Variant33 = "17270" Variant34 = "17271" Variant35 = "47213" Variant36 = "47214" Variant37 = "47215" Variant38 = "47216" Region = "Europe" Region2 = "RoW" Region3 = "USA" MetafileChecksum = "d3f9e1f47675003e96331df6202b162c7c407a88" [common_Release_1] Name = "MIB 2 High Personal POI" Path = "./PersonalPOI/MIB2HIGH" Variant = "FM?-H-*-*-*" Region = "Europe" Region2 = "RoW" Region3 = "USA" [common_Release_2] Name = "MIB 2 Standard Delphi Personal POI" Path = "./PersonalPOI/MIB2DE" Variant = "17245" Variant2 = "17246" Variant3 = "17250" Variant4 = "17251" Variant5 = "17247" Variant6 = "17252" Variant7 = "17254" Variant8 = "17255" Variant9 = "17268" Variant10 = "17269" Variant11 = "17270" Variant12 = "17271" Region = "Europe" Region2 = "RoW" Region3 = "USA" [common_Release_3] Name = "MIB 2 Standard TechniSat Personal POI" Path = "./PersonalPOI/MIB2TSD" Variant = "17206" Variant2 = "17207" Variant3 = "37206" Variant4 = "37207" Variant5 = "47203" Variant6 = "47204" Variant7 = "17216" Variant8 = "17217" Variant9 = "37212" Variant10 = "37213" Variant11 = "47208" Variant12 = "47209" Variant13 = "17212" Variant14 = "37208" Variant15 = "47205" Variant16 = "17222" Variant17 = "47210" Variant18 = "17224" Variant19 = "37214" Variant20 = "17210" Variant21 = "17220" Variant22 = "47213" Variant23 = "47214" Variant24 = "47215" Variant25 = "47216" Region = "Europe" Region2 = "RoW" Region3 = "USA" [Signature] signature1 = "9880af1b5d5456de15affd708b3b74b2" signature2 = "3cf0dbe1d0baf902e43229a07cfb9281" signature3 = "3c76dea04775d174ac4f937445ae538b" signature4 = "84d056d12279144f13341a7ccec3a7a2" signature5 = "39120b41cbf137351aa6a08c732b3521" signature6 = "5a224666234d8700e6c46bf2a943452c" signature7 = "b06daa662fc8d9a1aee981c0a5df7c1a" signature8 = "4bcd566ead66604069d58ab0a9f77d14" ----- It was two of those variants missing. The variants cover every mib unit to mib2. Either way if you have a copy of the firmware with the variants and check your import meta file and you are missing variants that's the issue. That's the problem with knock off files doing the rounds they aren't kept up to date as well as breaking copyright of the POIs they are using.
  23. Interesting the mibsolution.one board I noted yesterday had a code fragment to fix the Columbus download. Didn't mention it just not to cause confusion. So someone has the fix which they copy back into the Columbus download. Best to use the first VW link on the top. Waiting for the first puff of smoke to say the VW link works. I'm sticking with the Audi 350 copy not re-running the import. Motto get in early with updates where the knowledge of what works is known. Those that delay find the knowledge gone later 🤣.
  24. Think those are the ones that MartiniB posted up this morning. Post #1. He's editting them in as they come up but a few false turns with problematic Skoda releases 🤔🙄. They are. The second link wasn't working. The first one was this morning.
