bigjohn
Everything posted by bigjohn
  1. Oh dear that puts me in the getting on a bit phase of life then! Lapped in quite a few valves in m time. A couple of notes of caution:- Is it an Aluminium head? Carefully does it! - before getting stuck in check how air tight it is - or liquid tight to test. It might not need much doing. After lapping in make sure all trace of the lapping in paste has been thoroughly cleaned away - you don't want it grinding in/wearing out other parts of the engine - esp valve guides! I ONCE made this mistake on a Morris A series head!
  2. Don't forget you have rights - especially in the first 30 days:- https://www.theaa.com/car-buying/legal-rights Saying that a failing battery on a car that's been sat around in the dealer system for a while is common- When my son got his 2016 Octavia at just over 3 years old it was bonging low battery even after a drive. We insisted on a new battery. It's been perfect since. PS if stop start it will be EFB or AGM and will need coding to the car.
  3. Multiple faults inc stop/start on a car that's been stood around at a dealer for a while - my first port of call would be a new battery. If you have just bought it I'd say it's the selling dealers problem.
  4. Fault's like this can also indicate the car battery is on the way out - errors caused by too low a voltage to run various modules etc.
  5. I totally agree the pd was not originally designed with a DPF in mind and there were also some issues with DPF's being bodged on way to far away from the exhaust manifold meaning it never really achieved passive regeneration especially in the colder UK. The problem I mentioned with re cam shaft was that in the base pd design the unit injectors were not being pressurised mechanically by the cam when extra injection would be called for relating to active regeneration during the exhaust stroke to send diesel down to the DPF - bodge no 2 required! As you say the CR engine was designed from the ground up re DPF with a close coupled DPF / EGR - the only issue being if any of these components fail due to the close coupled nature they are between the engine and the bulkhead so difficult to get at and expensive to change (transverse engines) At the end of the day that's why the late great pd engine was quickly phased out. One other slight complication - the Superb mk II was also introduced with a 2.0 pd diesel , fairly quickly phased out!
  6. I thought on a pd engine the mechanically driven Tandem pump was the primary fuel pump and also a vacuum pump for the Brake Servo and Vacuum System. I seem to remember that when diagnosing a vacuum issue with my mkI 1.9 pd Superb - wasn't that the reason it was called "Tandem" as it performed two functions?. Because of the North / South arrangement of the engine on a mkI Superb the tandem pump was wedged between the back of the engine (cam) and the bulkhead so a bit of a swine to get at. Was it different on the mkII 1.9pd Superb re pump type?
  7. Isn't there a vent hose through a charcoal cannister filter?
  8. Your 220 version of this cam chain engine is a cracker. At this age it doesn't have a particulate filter but it does have both direct and port fuel injection, meaning petrol still sometimes runs past the inlet valves. This is a good thing as it mitigates carbon build up around inlet valves that direct injection petrol engines can be prone to.
  9. The early 1.9 pd Greenline mk II had a DPF. The pd engine was never a good bed fellow with a DPF because of the camshaft lobe driven unit injectors design.
  10. Re MK II Superb:- The CR 2.0 diesel in the mkII Superb is pretty well regarded although was subject to an emissions recall after the VAG dieselgate scandal. Some people had issues with some components such as EGR valves afterwards. VW then gave a warranty (3 yerars??) for emissions components after the recall work was done. Note - in the Superb mkII the CR 2.0 was never Euro 6 so would be subject to a ULEZ charge etc. Re 1.8tsi:- Re mk I Superb:- The 1.9 pd engine was very well regarded but there were a couple of later versions that were prone to mechanical issues. The pd 2.0 diesel in the mk I Superb had major issues as it was fitted with a poor implementation of a DPF and was fitted with a "balancer module" that also compromised the main oil pump drive as things wore that then could cause engine failure.
  11. Everything else on the dash working ok? Anything changed or other work been done?
  12. Agreed after checking a circuit diagram
  13. Re 2 - I'd start with hazard switch /relay (Is it in one unit as per some other Skoda's?) . This failed in a strange way a few years ago on my mkI Octavia. Also could this be an earthing issue?
  14. Which is illegal to drive - and an MOT fail
  15. Steering right at speed rolls extra weight to the left - to me the extra noise doing this indicates left wheel bearing. When my son had a tyre hum issue on his 2016 mkIII turning left/right didn't really affect it.
  16. I doubt it - I had a 1.4 16v classic that had some extras fitted new eg rear speakers - that needed additional wiring to support. I think looms vary spec to spec
  17. Do the reverse lights work?
  18. For the original query re badges - ebay seems to have a few listed
  19. If all done then that should be ok. The 1.8tsi is a lovely engine to drive with when sorted - and it sounds like all the dodgy design "issues" have been addressed. To keep it that way make sure you have regular servicing - if it's on long life servicing get it changed to fixed miles/interval. When you get the car back keep an eye on oil consumption for a while It will take a little while to run the new rings in - don't thrash the living daylights out of it but vary your driving including a bit of giving it some jip. - Being tooooo gentle can be a mistake. Even my poverty spec 1.4tsi is sublime on a run. It's extremely refined all round but fitting Michelin Cross Climates tyres made a difference to road noise - not that it was bad beforehand!
  20. The Superb is a lovely car but I'm afraid this engine has form - you may have just bought someone else's problem. Myself I'd try and reject it and get my money back . If sorted with the revised rings/pistons/rods + new timing chain / tensioner then that'd be ok but I doubt you'd manage that as part of the purchase. https://www.theaa.com/car-buying/legal-rights
  21. I'm afraid there have been a huge number of posts about the 1.8tsi engine of that era. Two major issues:- Oil control ring of poor design and gums up causing oil burning - modified rings/piston/rods available Timing chain/tensioner failure causing severe engine damage.
  22. A brief rattle is normal on the EA111 as oil pressure builds on the chain tensioner. I have this engine in a 1.4 tsi Superb and it has always done this if left for a while. I've owned from a 14months old /14k miles - it's now 7 years old/ 96k miles and sounds just the same as when I bought it.
  23. I had a slight problem with the main lights being a bit dim but map lights fine. Squirted a bit of switch cleaner into the overhead light switch which resolved the issue.
