Everything posted by bigjohn
Very intermittent sticky clutch pedal
I had a similar problem with my Superb mkII a while ago. Get your brake fluid changed including bleeding through the clutch slave cylinder. There is a dump valve within the clutch hydraulics to protect the clutch but if the fluid in the clutch has not been replaced at the same time as the brakes in the past it can rust etc causing sticking. Sometimes replacing the fluid helps, well it did on my mkII 1.4tsi Superb - the fluid came out a grotty colour! It was ok afterwards but later when the clutch wore out I had the slave cylinder changed as well. PS yes it's a common fluid reservoir between brake & clutch. Does yours have an external or internal/concentric clutch slave cylinder?
ULEZ coming, petrol Superb options
The small cc petrol tsi engines tug a Superb along really well and economy is generally great. I've just sadly sold my 2014 1.4tsi Superb mkII which has been fabulous over the last near decade of ownership (I bought nearly new in 2015). It generally averaged late 40's mpg although 50+ mpg was possible on a gentle run. If just driving around town then mpg was late 30's / early 40's . My overall average mpg was about 46 mpg. I think the sweet spot re Superb small cc engines is the 1.4tsi EA211 in the Superb mkIII. PS I'm 6ft 4" tall and also have problems fitting comfortably into various cars especially re B pillar position being too far forward and my elbows and knees are in the wrong position re arm rests/ banging into door furniture.
Waze not google
Have you installed Waze on your phone - surely with Android Auto or Apple carplay if you have it installed you should be able to select Waze,
Goodbye Skoda Superb mkII 2014 1.4tsi
Fuel economy seems to be consistently good - trip around Norwich and back up to Yorkshire. Boot a good size and shape- it's more or less the same as the Corolla Touring Sport.
Yup, I've been eyeing up the Toyota hybrid gubbins for a while but I didn't fit in many Toyotas. I found the driving comfort / position fabulous and boot space is the same size as the mkII Superb, albeit different. So for us Swace seems great - time will tell.
I had a 2003 mik I Superb for 10 years before that, oh and a mkI Octavia. We've been a Skoda family since 2001 - so this is a big change!
It's with a heavy heart I have to say I'm no longer a Skoda owner. After 9.5 fabulous years my 2014 Skoda Superb 1.4tsi mkII is under new ownership. Now I'm retired we've been trying to downsize to one car and even though Mrs BJ loved being a passenger she found the Superb too big to drive. The recent Octavia was ruled out as basic functions such as heating etc were on the touch screen. The Scala was considered but I was worried about the long list of comments re issues with the infotainment/screen/SOS and even though it's reasonable the boot isn't quite big enough for going camping etc which strangely we've got back into in our old age now retired. I ended up buying a very nearly new Suzuki Swace (26 miles on the clock - Toyota Corolla hybrid in drag) for a stonking deal as in 2025 Suzuki are reducing the range of cars to SUV's (no thanks) and electric only cars (not yet?) due to the manufacturer fines being introduced re % of electric cars. I've had the Swace a few days now and am still getting used to it - just had my first long trip away. Economy - wow!! although petrol tank is smallish. Boot is fabulous, the compromise is rear passenger space compared to the Superb but these days it's mainly just two of us. However the Superb will be missed.
Boot won’t open with fob or boot button.
- Any magical cures for a 1.8 TSi 4x4 using oil and coolant?
I've never tried this on the 1.8tsi but back in the day one trick I used on old oil burners was removing spark plugs and squirting a good slug of Plusgas into every bore and leaving overnight. Followed by squirting a bit of oil into each bore the nextday, turning over a few times & not starting and then changing the oil. Certainly worked on Ford pre crossflow engines that were prone to oil scraper ring gumming/oil burning.- My first car was..
I had two of these in the 80's as company cars but my goodness did they drink petrol - I rarely got over 30mpg. A later 1.3 89 Astra was way better in many ways. Blimey suddenly feel old!- My first car was..
1973 White/rust Vauxhall Viva 1256 bought for £50 in 1982 with only 60k miles on it - but Inner wings had almost vanished even at 9 years old and sills weren't far behind re rust, so I learn't how to weld. Ignoring the rust munching going on I actually ran it for a couple of years passing two more MOTs and it mechanically it was surprisingly reliable doing 12k miles/year - slow as hell though couldn't go up hill especially in a head wind(hated the A66!). Finally gave in when rust advanced much further weakening structure near front and rear suspension attachment points. Rust In Peace! Bizarrely I still have a bit of a soft spot for a Viva HC whenever I see one, saw an immaculate one the other week in Bridlington.- multiple warnings lights
Usually another symptom of a failing battery which is why I asked- multiple warnings lights
Sometimes it's not the resting voltage of the battery but what happens under electrical load - especially if a failing cell with internal resistance. I changed the original battery on my Superb when strange things started happening during lockdown(always started ok though), probably due to lack of use or the fact it was a Moll, it was 6ish years old at the time - all good since. Out of interest does stop / start still work? PS it's not just Skoda that has strange errors re battery - Mrs BJ's Fiat 2006 Panda starts flashing up "Power Steering Fault" every now and again when the battery is failing, new battery fixes it for another 6 years or so. Car always starts just fine. Family owned from new.- multiple warnings lights
Hmm, I'd normally suggest this indicates a battery failing issue - I know you said you've checked, but how? Electric power steering has a high current demand so is an early casualty if all is not well. You can also get spurious errors elsewhere. Another known strange fail can be an abs sensors - especially rear.- Is it normal for the 1.5 to sound rattly ?
You're probably overthinking this:- Re Rattly - these later direct injection engines are "rattly" at tickover especially with the bonnet up (which I think you had with checking oil etc). This is to do with the injectors and high pressure fuel pump. Any rattles from inside with bonnet down? Re Cambelt - if it's been changed you normally get a replacement kit inc tensioners etc. In any case the replacement interval has been revised to 15 years / 180k miles.- 1.5 Tsi Power Cutting Out
Does this mean all new Skoda 1.5tsi will be affected and is it related to the recent introduction to evo2? Any 1.0s affected. I've not seen any mention on the Kamiq/Scala/Fabia parts of Briskoda - yet? I ask as I'm currently considering a Scala 1.5tsi.- Skoda superb burning oil.
I don't know but your current big issue is probably DPF - might have been an ongoing issue.- Cold air coming in when Ac/ CC off
Is it ok if climate control is on ?- Skoda superb burning oil.
How long has it been like this? Clearly a DPF issue and as well as the DPF and/or sensors being in trouble your oil will be a terrible way as with endless aborted regens(100rpm/ fans etc...) diesel will be running down the bores (used for active regens) and if like this long term it's not a good lubricant so could ultimately cause problems with things like bores & turbo. This is potentially serious so get it to a VAG specialist asap. I'd suggest not driving much until diagnosed properly.- Cold air coming in when Ac/ CC off
I suspect there isn't a problem - when climate control sensors etc won't be in use.- Cold air coming in when Ac/ CC off
There is a fresh air input into all car climate control systems from the outside which will take in more air at speed. If you really want you could seal yourself in by pressing the recirculation button - You might start steaming up though and air will get stale.- Aftermarket catalytic converter
Or anything else damaged / disturbed when the original cat was stolen & replaced? Eg sensor wiring, exhaust/gasket leaks etc...- Aftermarket catalytic converter
High HC is unburnt fuel so possibly something amiss re engine gubbins (valves, bores, injectors, air filter etc) You possibly passed an MOT with a new catalyst disguising an underlying issue. Have you tried a compression test?- Are the higher spec seats more comfortable?
Trouble is seat comfort is an individual thing. Years( er decades) ago I had a top of the range Renault Savanna 2.0 company car that "initially" felt as though it had really comfy seats but a 100 mile into a long drive my back started twinging and after about 300 miles I could hardly walk - can't blame age then as I was only in my late 20's! After that I had a Saab 9000cs and wow those seats were fab - Once I drove all the way through Europe to Munich in one go, not a twinge. I find I like most VAG seats (currently Superb mkII) as the firmness suits me but I have a friend who really hates them. I you start swapping seats - beware airbags.- Trouble starting on cold mornings: ASR Error
I'd suspect the battery, especially as a failing battery is worse on a cold morning. - Any magical cures for a 1.8 TSi 4x4 using oil and coolant?
