Everything posted by Danoid
UK - Passenger side wiper arm location
I’ve not had mine off but my old Passat was a spine so thought it would be of similar design. Does it just sit around something and get tightened by the nut alone? If so I guess I should be able to undo the nut and move down and retighten without having to take the arm off
That’s it but mine was never that visible before
What I meant by the ready position is it parks up higher than where it does when the cars off Kind of like when the cars off it sits in position A, when it’s raining and then stops the wiper arm sits in position B, turn the car off and it goes from position B to A I think it’s out a few splines but as it’s usually a pain to remove it would be good to only do it the once
Hello, not too long ago I had my windscreen replaced and it’s evident my passenger wiper arm isn’t in exactly the same position as it was. When I’m driving and got auto wipers on and it returns to the ready position (but not full seated like it’s turned off) I can see the blade against the windscreen and is annoying I I looked at Elsawin and it’s really not clear on where it should be 😞 Can someone pleasure measure the distance between their wiper blade and the top of the plastic scuttle please? Here’s a picture of mine, Elsawin said something about +-4mm and might be talking about the bit I’ve circled in red but not sure thanks
Shuddering and vibration from 50 mph
Hmm if they’ve refused repair means they are an honest garage because you won’t be paying them as no incentive for them to lie
MySkoda App Honk & Flash
I don’t believe this app has ever worked for anyone, I believe you also need a subscription for some of these things
L&K Options
look for the section which lists the versions of the Škoda superb brochures and it’ll start with the lowest and say what’s standard, then keep scrolling down until you get to l&k
1.8 TSI noise?
Not too sure but I’d recommend getting one of these https://www.amazon.co.uk/NEILSEN-TOOLS-Mechanics-Stethoscope-Traditional/dp/B005S0E23S/ref=asc_df_B005S0E23S/?tag=googshopuk-21&linkCode=df0&hvadid=310705025920&hvpos=&hvnetw=g&hvrand=15132353277939880943&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9045795&hvtargid=pla-465466276547&psc=1&mcid=3f5b5543a001319da17a3435a7505107 buy one in your own country though, then remove the engine cover and panel under the engine and get someone to gentle rev in whilst you’re prodding around with that and see if you can pinpoint the area Have a look for something like “Škoda fuel line rattle” and “vw fuel line rattle” although it’s mostly at the rear I believe the sound travels down to the front of the car
Have a look at the vega wheels on the accessory brochure, usually much cheaper if you rang your local Škoda dealership and asked them for the price
Superb MK3 Rear Brakes
Watch this, by far the best video I’ve seen and is explaining things nice and clearly even though it is for an Audi it’s essentially same process
Very high oil temperatures
Usual I’m sure, put the maxidot to something else and forget about it. I’m guessing sure you’ve seen no symptoms of anything whatsoever?
Battery cold climates
I have a routine in my car, start it then say “turn that fu&@“?! off” and press the stop/start button. Then if I’m in properly standstill traffic I say something expletive and turn it back on
Quick question - Brand new Superb SE L
I’m sure I heard they’ve been scrimping on things and probably an optional extra these days. They’re not expensive if you want them, but as they’ve not expensive why don’t they just include them
I believe 68ah is standard, just noticed where you live and quite surprised it’s the same
White noise from rear passenger side tweeter
It’s not that silly microphone boost for rear passengers is it? I think normally you can hear an echo but worth disabling it, but don’t know what it’s called as mine doesn’t have it
Caliper upgrades
I can tell you something that’s cheaper, slow down 😂 Brembo discs are good but I’ve not long put ATE ceramic pads on my wives fiat 500, wow what a difference, I was hesitant at first after reading brake feel isn’t the same and you don’t get so much initial bite but had the complete opposite. I’ll be using them on my superb when the fronts are due along with brembo discs as I like the painted hubs, I’ve got them on my rears but with Škoda pads as I got them to fit it.
I forgot about webasto etc, deffo need it there! I think you’re right about me being surprised, think I’m too use to my own battery
Superb SE L vs Sportline Plus
Oh I always thought it was lower, I’ve seen some unbutchered ones and sit lower then my SEL with 19”s
That’s what I’ll be replacing mine with and is pretty much the biggest and most powerful, but I still can’t see that starting a car at almost -30. I wonder if cars sold elsewhere have a bigger battery tray to fit bigger batteries
No links but sportline is more sporty then SEL It’s lower, probably snazzier wheels, no leather seats as it’s alcantara, not much else is different between the specs One thing I will say is be cautious of dealerships offering “a deal not to be missed” it’ll benefit them more than you! Unless you’ve been actively looking for a replacement do more homework, like is the tax higher as I’m sure it changed in the last few years, is insurance higher because it’s now a “sport” model
Does the Superb have a more powerful battery in cold climates like Finland? I’ve been watching this https://www.youtube.com/live/LwihxyJ4V20?si=1ja_gdQev90V9ydm recently and saw a few cheeky Skodas parked in the Audi only bays all day and temperatures are silly cold, yesterday at 4pm ish it was almost -30 They got in their car and off they went, my car struggles when it’s nearly minus numbers (it is old and original from 2016) but just wondering if they have more powerful batteries and would be a good choice even though temps never get that low here in England at least
Superb 3 heater matrix replace Ireland
I’m tired but surely you’d find the source of the contamination first? Do you actually have any issues? This just reads as paying their Christmas bonus 😁
Fog light removal Super facelift
They’re all LED so expected and normal behaviour I would have thought? Just like the DRLs
DSG AutoHold at Traffic Lights without brake pedal held down
Yes, but be careful when dropping it off at a garage for MOT/service as they never remember to turn it back on 🤦 been a few times I’ve left and almost crashed coming out
Columbus Map Update 2024 (MIB1/2 HIGH)
Hello, Sorry just to confirm the latest link is https://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P350_EU_202345.zip ? At the top theres 3 red exclamation marks and unsure the reason on this, the skoda portal still has the commencing week 22 which is ages ago. Thanks
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
