SkOmk4
Everything posted by SkOmk4
  1. This weekend at a car show I was discussing with a Cupra country sales manager. Among other stuff I was asking why the PHEV's (of the VAG group in general) seem to be discontinued in Romania (e.g Octavia PHEV, Formentor PHEV, Golf GTE). He told me those were removed from the car-Configurators and orders were suspended for now, simply because there's an important components shortage for hybrids (not mild-hybrids, but the real ones). On a rather optimistic note, he was saying that they have high hopes they'll be able to accept PHEV orders before the end of this year.
  2. yes, that's right. Why would you struggle with such a modification? Isn't if easier/faster to connect directly into the available positions of the Fuse-box? There you'll find both permanent and ignition-only power supply. On most dash cam's (if not all) you need both connections in order for the camera to know when to switch to parking mode and when to run continuously.
  3. Indeed, 5 credits per day if I remember correctly, but this option was removed last summer.
  4. You can read more about this "feature" (or bug) in the topic below. It only appears for a while when you change the info to be displayed on left or right side of the dash. Otherwise Waze directions will not normally show it the place of the clock (as your picture shows). What happened to me (described in the link) seems to have been a software bug - and it never happened again in the past 3-4 months...
  5. After being used to sporadically get one or two errors (e.g. Lane Assist unavailable, Front Assist unavailable, Park Assist unavailable et al.) when starting the car in the beginning of the weekend, this weekend I noticed a new kind of behavior. The error was completely new - "Vehicle lightning" - and the warning light was on until I stopped the engine after several minutes. In all previous cases the errors that were showing up when starting the engine were vanishing in about 10-20 seconds. The error was gone when I restarted the engine, but had a new problem while exiting the parking place: I was parallel parked and had to reverse to get out - the camera image froze on the HU and the parking sensors beeping didn't change frequency as I was approaching the car behind me. So I stopped maneuvering waiting for the system to "wake up", immediately saw "Sound unavailable" on the screen for 1 second and then the HU restarted on it's own. Everything worked after that. After a ~200km trip the car was parked for ~3h. When I resumed the trip I had to reverse from the parking - same behavior: camera image frozen, HU rebooted... 😡
  6. To add to the list of drivers that put the gearbox into Neutral at longer stops - I'm also doing that, but on the manual gearbox. And if there's a slight slope I'm usually using the handbrake, not only to relax the leg, but also because I hate bothering those behind me with the brake lights (especially in rainy weather). On the other hand, I keep the DSG in D/S at red-light and most of the time I'm using the Auto-hold while driving through urban traffic. (I know the brake lights will bother some of the rear drivers - I apologize, it's the system's fault, not mine). I also had a dual-clutch without Auto-hold (the Megane 4 GT EDC) and for longer stops I used to push the gear-lever to N and apply (electric) hand-brake when the road configuration required it.
  7. Welcome back! I haven't seen you around for quite some time! I hope this means you've been enjoying your car without any serious issues. I've tested an S23 Ultra for a slightly more than a month, before returning it back to the seller - couldn't get used to the form (sharp corners) and it had a few software glitches (which I'm sure are rectified by now via updates). The AA connection was stable, both wired and wireless; I don't remember having any problems. I downgraded to an S21 Ultra (form factor again - rounded corners => pocketability...) and the AA connection is quite stable. It happens from time to time that the phone disconnects and immediately reconnects, only via wired connection. I'm suspecting the usb cable: it's not the original one, because I wanted L-shaped connectors... It could also be a software issue, since I can have few hours long trips without any problem, and also have several consecutive disconnections on short 20 minutes trips. It's really random... Wireless connection is stable as far as I can tell - I had no problem so far.
  8. Are your Online Services working? The little globe icon at the bottom of the screen - is it white or grey? I'm not sure it would have anything to do with your system rebooting endlessly, but you could try to remove fuse 19 for a couple of minutes and see if that changes the behavior of your HU. If that doesn't help, I would also try removing fuse 30 for several minutes to see if that changes anything.... https://car-fuse.blogspot.com/2021/02/2020-skoda-octavia-fuse-panel-diagram.html
  9. Thanks, I was really wondering under what circumstances the car locked with the keys inside... So basically the car behavior that you describe means that: if you unlock the car, open the door and throw the keys inside and you close the door, the car will lock by itself after a certain amount of time? If yes, can anyone clarify if this is a feature or if it's a bug on Octavia mk4?
  10. Totally agree with you, but you missed the point I was making... I'll try to clarify: - @SurreyJohn mentioned that as a security feature, many cars lock themselves if all doors are closed about minute after unlocking. That's true, but only if none of the doors was opened during that minute. At least this is how most of the cars I drove were programmed, with or without kessy. - assuming that you have you car locked in the parking lot: you come torards the car, unlock it, but suddenly realize you forgot something and you go away from the car, without opening any door. The car will automatically lock after ~1 minute. Could you please explain how does the key get inside the car??? (Assuming the owner is other than David Copperfield...) - if the key is inside the car, one door was opened by the user at some point - at least to throw the key inside - and then the user left the car... In that case the car doesn't lock itself simply because a door was open, not because some fancy antenna is detecting the key/card inside the car (if we talk about cars without kessy).
  11. Sure, many cars have that option - as a protection to accidental unlocking of the car (e.g. buttons touched while the key is in your pocket). But how do you get the key inside the car after unlock? A door needs to be opened to get the key inside... hence the car shouldn't automatically lock in 1 minute.
  12. Indeed, I had a longer drive over the weekend and had the chance to monitor the temps - they all start shoving numbers at 50 deg Celsius (coolant, engine and DSG oil), nothing below this value. Correction to one of my previous posts: the set of three temperatures (coolant, oil, oil) only shows all three on the "classic" dashboard theme. All the other layouts only show two values. As discussed above, I was able to clear the B184C00 fault code once the SFD was locked. However, I was surprised to find 15 new fault codes after I cleared the existing ones several days ago. Saving the Log, I noticed that some of those faults occurred while the car was parked and unused for 1-2 days... ☹️
  13. Great, thanks for that tip! Indeed, I was doing the scan after I completed the coding. Did that after ignition-off and ignition back-on, but with the hood still open. I was too lazy to get out of the car and close it. (actually I had no idea that it would be the root of that error )
  14. Quick status update on my side: I tried to do the manual coding for the stuff that didn't work with OCAs. Both the g-meter and the Fan-level display were showing as "Active". Nevertheless, I set both to Inactive and then back to Active again, with no luck - neither works. @djmartzian: I also have Bolero - so that might explain the g-meter not showing... I also activated the Turbo-pressure and the set of 3-parameters DSG-temp.&&oil-temp.&&water-temp. Both are shown, but the 2nd only shows 2 parameters instead of 3 - DGS and oil temperature (1st picture). As you can see that's a bit redundant - having the oil temp in two places on the same dashboard layout. 2nd picture is related to a question I have: after I activated the VRS layout, I noticed that when the sound volume is adjusted from the steering-wheel, the level-bar sits on top of the rev-meter as if it was not supposed to be there. So the question is: does it look the same for those with native VRS cockpit view? And finally, after the suggestion of @djmartzian I decided to rescan for errors (I only scanned before unlocking the SFD). I could't find any of the nasty B17D7F0 code he mentioned, and I was able to erase all fault codes, except 1: I have the B184C00 fault code showing as "static" on "Dashboard" and on "Central Electrics" units -see 3rd picture. Should I worry about that? A quick search online showed that it might be normal as long as the SFD is unlocked...
  15. In my case torque reading is ok, live changing with the accelerator, as the power does too (however, the kW units annoy me). BTW, I was surprised to see that the Oil temp. indicator was showing nothing (just "--") until the temperature reached 50 or 60 Celsius. After that threshold, it works like a charm! I'll try to manually code the stuff that didn't work via OCA, as @djmartzian suggested, when I'll find a bit of time. However, I couldn't find the coding for the "Fan level on Auto" - and it's one of the tricks I'd find quite useful...
  16. Funny story... Now that you mention those issues and I read the topics from your links, I remembered that the car threw some errors after the OCAs. I when I finished I switched the ignition Off and then back On to see the results, and 3 errors were shown on the dashboard - I only remember two of those: Emergency Assist Error and Auto Hold Error. That happened Saturday evening, and I didn't scan for new errors. On Sunday I had a trip of ~180 kms and had no errors occurring - probably that's why I completely forgot/ignored those errors.
  17. Finally got the time and guts to play with the recently arrived obd-dongle on my car. After a short headache with the 2-factor authentication (that I didn't see detailed around here) I did a full backup and a full scan - only to find about 40 errors. The SFD unlock returned an error message for a couple of times. I had to wait for 10-15 minutes and try again - it worked; I unlocked all modules that were locked. (forgot to mention: hood opened, ignition ON, engine OFF) I then tried several 1-click apps: - VRS cluster - worked; - engine power - worked; - engine torque - worked; - lane assist to last-setting - worked; - fan level on Auto - app said "done", but it didn't work; - G-meter - app said "done", but it didn't work; - central lock with IGN - app said "done", but I didn't test it. I'll try to manually code transmission temperature when I have the time. Besides that, anyone has any idea if it's possible to change the engine power display from kW to HP? There's a short thread for that on the obd11 forum, but there's no answer yet.
  18. Could it be that your switch is always lit up because you have the rear lights ON? I don't know, I'm just asking. IIRC in bright daylight with lights OFF in "Auto" mode only the "Auto" will be green-lit on the switch.
  19. Most countries don't have mandatory rear-daylights; Scandinavian ones do - hence the name of the App in OBD-eleven that turns on the back lights also during daylight. The risk of driving in darker areas (with Octavia) with no back-lights is practically zero, unless the owner does some coding with VCDS of OBD11. The car will automatically switch lights to "Auto" above a certain speed (10-20 km/h, not sure) which means it will turn ON front and rear lights when in gets a bit darker or when you enter a tunnel. I actually noticed it turns ON the lights quite early for my taste, when there's still plenty od daylight outside. Indeed, most of the cars of any brand don't have rear daytime running lights activated by the factory. My Megane 4 had rear-DRL activated from factory, but there are plenty of Megane 4 phase 2 that don't have it. Not sure what's the reason behind these changes. For sure rear-DRLs can be activated via can-clip. Finally, as @SteveTheElder mentioned, since there's no indication on the dashboard, you need to check the button under the steering wheel (left in my case, right side in yours) - you'll see an extra light coming ON next to "Auto" once the headlights start... (see the User Manual for details on each symbol)
  20. For sure (as usual) the dealer won't care much about whatever a Forum thread is saying... 'cause they know better... 🙄 But in case it matters: my 2022 Octavia is still coasting in Normal mode; I have to admit I never used Eco mode so far. Great, simply flick-back the DSG joystick to go into "S" instead of "D". I also hate it and I'm always driving in S, never in D; sometimes I forget about that but I'm reminded at the first deceleration of the car.
  21. Octavia currently has the worst delivery estimations in the entire VAG-group: (that's if we don't count some e-tron models with >18 months delivery time) https://www.marnet-mobility.de/aktuelle-lieferzeiten.html
  22. I don't think that what you are calling "tick sign" is positioned there for warning purposes - it is simply there to let you know what that set of horizontal lines are showing... In this case the fuel level. That fuel-pump pictogram could have been placed very well in a different position, above or below the lines. When your fuel level reaches that pictogram position it doesn't mean you need to go to refuel ASAP. Youur picture shows that you still have fuel for about 3 lines out of 8, which roughly means about 1/3 of your fuel tank, which for a tank of 50 liters means that you still have about 16 liters left. You can easily let the petrol fall down to the last line marked with "R" - which is short for "reserve" if I'm not mistaking... At that point, that last line will turn from white to red as @SteveTheElder mentioned above. When you reach that point you still have about 100 km worth of fuel left in your car. Unless you live in the middle of nowhere, you would have enough range to arrive at a gas-station.
  23. Enjoy it!!! You can now change the car in the signature 🙃 How come you had to wait for almost 2 years? It is not a PHEV as far as I can tell from the rev-meter...
  24. You need to use the "wheel" on the right side of the steering-wheel. One click on that wheel will open the "menu" of the right side (where we now have the audio source). You'll notice two green arrows above and below inside the speedometer circle - if you scroll using the same wheel, you can change the content of the speedo-circle. One more click on the same right-wheel on the steering-wheel, will open the "menu" on the revs-circle. You'll notice two similar green arrows up and down. It means you can now scroll (using the same wheel) through the items to be displayed in the rev-circle. Have fun with the menu! BTW - each side (left and right) has a "Settings" section when you scroll through the right or the left menu. If you click "Settings", that will allow you to activate or deactivate stuff to potentially display on each side of the dashboard. Long-story-short, the video below is better than a thousand words... (L.E. Really sorry for the off-topic, but since it's a learning topic I thought the initiator of this topic might also benefit from it...)
  25. Yep, that's my dashboard; picture is a bit fuzzy because I was taking it while driving, so not really carefully focused. You're right, it's not easy to get a range higher than 900 kms, but during that particular trip it happened that for a brief while I had a range of 1010 kms, without any effort! But don't worry - it is really strongly dependent on the situation. I find the range algorithm on Octavia quite "unstable" (or jumpy) compared to those of other cars I drive/drove. On that trip I was going for a weekend drive through the mountains, so I was driving simply to relax, not to get a good mileage or range. After exiting the highway, I filled up the tank just before entering mountain roads; the range after filling up was ~840 kms. The secondary mountain roads I took were slightly covered with snow and had plenty of sharp curves, therefore I had a small average speed and slow acceleration + some engine braking. That was going up the mountains for about 30 kms, and the range went also up with the altitude! 😉 (to about 860 if I remember correctly). Later I drove down the mountain with plenty of engine braking (partially because of the snow), and after about 50 km I met normal weekend traffic on national roads (within legal speed limits) towards the capital, for another >100 km. I was entering Bucharest with 1010 kms range 🙃. That's why I took several pictures of the dashboard - to explain my friends how my new car is able to ADD diesel into the tank while driving 😂 (you can see yourself the mileage of the car in the previous picture and the picture below... the range went up by 20km, while the car was driven for 74 km)
