Everything posted by SkOmk4
Climate controls - settings saved?
Totally agree, I've been using it for exactly those purposes quite often; but I never need it on dry/sunny winter days when there's fresh air coming from outside (no re-circulation). What I meant is a bit different: on most automatic climate control cars, when you leave it on Auto, you'll be notified by an LED, symbol or pictogram when the compressor is engaged. Ok, thanks! I didn't know that - now the info & details in the Manual start to make more sense. So basically putting it to OFF in the menu will keep it at 0%, otherwise it may be continuously adjusted by the system, depending on the inside/outside conditions and user requirements.
I'm reviving an old topic (so I won't start a new one for no reason), 'cause I have a question - or rather a comment - on the "logic" of the climate control. The "A/C" button (the one hidden in the Clima Menu) has the two positions: green (ON) or white (OFF). However, as I was already assuming, the User Manual indicates that while ON, the Climate Control system will decide when to actually start or not the A/C. This is a bit intriguing for me, since I prefer to know when the A/C is on or off. On most of the cars I've driven so far, there would be some sort of notification that the compressor is actually engaged; either some light on the physical A/C button, or some Icon or pictogram on the Climate Control display. Furthermore, according to the details in the Manual, the A/C will switch on when the conditions for switching on are met. If we check the Operating conditions for the cooling system in the same Manual, this would imply that the Cooling System will be engaged even when the outside temperature is ~5 degrees C and I'm asking the system to deliver 23 C inside. That's with the Clima set to "Auto" and the A/C set to "ON". Does anyone else find this behavior as stupid? Or is there something wrong with me? Or is the system actually working as I'm hoping it does, but the details in the Manual are not that well exposed?
Winter wheels
Well, actually @stripy007 is right, the official Octavia manual is indicating 140 Nm. And concerning the dealer - it wouldn't be the first time I'm asking a question to the dealer and get the wrong answer... But indeed, 140 Nm seems excessive.
Winter wheels
K, thanks for that; I was too lazy to check the manual - thought it would be faster on the forum. BTW, those 140 Nm seem quite a lot; I wonder why would Skoda go up from 120 to 140 between MK3 and MK4. Most of the torque values I've seen so far (not only for Renault) were typically 110 +/- 10%.
Winter wheels
Since we're on a wheels topic and I'll soon put on my winter 'shoes', does anyone here know the torque for the Octavia wheel bolts? Is it 110 Nm as I knew from other brands? (this being my first VAG car)
Even more software errors
There was some light rain before noon, but by the time I left from work it was quite sunny and the road was dry. The car however was wet (being parked in the shadow and ~12 C), but really clean - no mud or traces of wed dust on it. The errors occurred about 10 km after the start, and by that time I think most of the car was dry - the water drops on the bonnet and the windows were all gone. I think I'll just have to wait and accumulate more statistics, maybe it was an isolated case caused by changing weather conditions and high humidity. I got a similar error before only for a couple of times on my Megane GT, but it was in the winter and it had some ice build-up in front of the radar in the grille - so that was quite normal.
This afternoon on my way home I received the first error messages on my dashboard: "Lane Assist temporary unavailable" followed immediately by "Front Assist temporary unavailable". I turned on the Lane Assist (turned off after I started the car) and it seemed to be working correctly - it detected the lane lines and showed the green symbol on the dash... Don't know what to say about this event. The car is about 6 weeks old and driven about 2.200 km, software version is 1896.
Latest software update
There's a setting for seats and steering-wheel heating auto-starting when the outside temperature is below a certain value; not sure, but I remember it being around 14 deg. Celsius.
Octavia iV reversing camera retrofit service!
Ok... So far, so good! The reversing camera is installed and working. Those guys moved quite fast - less than 2,5 hours in total: about 45 min. for physical installation and wiring + similar time for coding (I was starting to worry it took so long!) + some more time to calibrate the lines and put all the plastics in place. From the trunk door and through the left rubber tube, they guided the cables above the roof liner on the left of the car - just above the doors - and went down through the left A-pilar. After removing the plastics left of the footrest (that's a RHD car) they accessed the connectors where the reversing camera was plugged; and one more connector somewhere under the steering column, above the brake pedal. They said everything is coded with the factory; I guess I'll have to wait for a major update to be sure about that 😉. They didn't want to code for me VRS cockpit theme, or Lane Assist to "Last setting", even though I had the code lines. They said they only do retrofits, but do not want to change factory settings... as if coding the camera was not changing the factory settings.
After receiving three negative answers from different Skoda dealerships following my requests for reversing camera installation offers, I searched for an alternate solution. I found a small company specialized in VAG retrofits and I have an appointment with them at noon tomorrow for the installation (price ~550 Euro). They claim it's an original VAG camera; how can I make sure it really is? The price is significantly higher than yours, but you are a bit too far from me @East_Yorkshire_Retrofits 😉 Any tips for what should I keep my eyes on, or what to check during/after the installation? You can imagine I'm quite stressed - the car being 1 month old...
Delivery times?
AFAIK the VIN is generated when they plan the production of the car, not when they actually start building it. So probably the system "evaluated" that the car could be built about >1 month before it actually entered into production. What I know from the dealer is that mine didn't wait for parts
Winter wheels
Yep, I followed the progress you presented on the dedicated topic - impressive work! I would have guessed you've practically eliminated most of the noise coming from the front and floor areas (not to mention the doors).
Delivery times?
No, not really; but you'll know when the car is completed - that's about the moment when it will be shown in the App with the correct image. This was the timeline in my case:
Winter wheels
That is really pushing all my buttons... I'm probably paying too much attention to that, but I fail to understand how a 2022 new car generates more rolling-noise inside the car, compared to a 2008 much cheaper car. It'd definitely coming from the tire-asphalt contact, because I can clearly hear the noise difference when the asphalt structure changes (e.g. patches of new asphalt along the road). I wonder if it is some sort of acoustic resonance generated into the plastic arches surrounding the wheels; I've noticed those are made of other materials (with better sound properties) in some cars. I'm surprised Skoda is still using plastic.
Permanently disabling Engine Sound Generator
In fact, there are several cars with factory rear-DRL, without tweaking/playing with the car settings. One example is my last Megane GT - it had permanent rear lights ON - similar to the front DRL. However, from time to time I occasionally notice some Megane 4 with rear lights off - so I guess sometimes the factory decides to configure the car differently. Another example I know about is the Kia CEED - it also had rear DRL from factory. I doubt the rear DRLs partially obscure the brake lights; if this would be true, it would also be a safety risk in dim light, when the car (or the driver) decides to start the front&rear lighting.
MkIV Octavia VRS Audio upgrade - disappointing
My question is not really about the "VRS Audio upgrade", but I hate opening new topics for very similar issues... I have a Style trim with stock audio (not Canton) and I noticed a HUGE discrepancy in the sound quality between different levels of volume. At low volume the sound is extremely crappy - sounds like a cheap empty tin-can; the higher the volume, the better the sound quality... Is this the general perception? Or is-there something wrong with my ears? Comparing to my previous cars, I can say without any doubt that the standard audio of my 2008 Megane sounds much, much better than the Octavia, only at low volume; they become comparable at higher volume and at some point the Octavia sound quality goes above the Megane one. There's no comparison between the 2018 Megane GT that had a factory fitted Bose system and the Octavia...
Winter wheels
Thanks for that, I though I was paranoid... This noise is one of the biggest issue I have with my new car (I have several other small complains, but this one proudly sits in top 3). The ride is overall quite silent, since I also added the soundproof front-side windows, but the main noise comes from the front wheels - at least that's how I perceive it. I checked the tire pressures - they are not that high (about 2.5 if I remember correctly) and then I searched for the certification of the Goodyear EfficientGrip tires - it's supposed to be 70dB. The noise is really annoying, I'd say it's above the one I can hear in my ~15 years old Megane. Looking forward to compare the noise level with the winter tire set - I already purchased Bridgestone Blizzak LM005 16" and it's supposed to generate 71dB. Anyone else bothered by the Goodyear EfficientGrip being too loud?
Wheel nut lockers
I was joking with some friends years ago about those wheel safety bolts: "If someone is interested in steeling your wheels, be sure that he'll have the necessary keys to remove the anti-theft bolts". So why bother?
Soft/Light Pedals Mk4 vRS
I had the same feeling of "soft" brake pedal in my new Octavia, but not for a moment did it feel unsafe; the braking is excellent - it only requires a longer travel of the pedal. Compared to my Renault daily-drive, it's a huge difference: the travel is a lot shorter in the Renault and the pedal is harder. That doesn't mean any of the two creates any discomfort, it's just the need two slightly "re-calibrate" my right foot when switching cars. It's most obvious when I park one and directly jump into the other one; otherwise I don't feel such a dramatic difference. With the accelerator pedal I also have the feeling it's really artificial and "disconnected" from the car... That's why I keep the DSG in S, not in D; that changes not only the behavior of the gearbox, but also the feeling & response of the accelerator pedal. Indeed, when in D there are situations when you really press for 1-2-3 cm on the accelerator and there's no feedback from the engine. You really need to floor-it to get an instantaneous response. That never happens when DSG is in S. (to clarify: I'm referring to the S-mode of the gearbox, not to the Sport driving mode that also affects the engine and steering behavior)
Delivery times?
This is the sequence in my case (I wrote down everything in the .xls of my Octavia 😉 ) - 13/07 - VIN received; - 23/08 - VIN accepted in SkodaConnect App; - 31/08 - car correctly identified in SkodaConnect App; The very same day (31.08) the dealer wrote to me saying the car was completed. - 27/09 - car was with the dealer; - 01/10 - picked up the car. p.s. Happy Anniversary to my car!!! It's 2 months old, and 1 month with me! How time flies...
Winter tire sizes
Existing topic:
Wireless android auto
On the way back home this afternoon I tried exactly what you described. First, I activated "navigation directions" in the list of items to be displayed on the right side of the dashboard. Then I scrolled until I had the Waze directions shown; exactly as you pointed out, each time I was playing with that right side of the display to replace the navi-directions with something else, that information would be displayed for 1-2 seconds on the position of the clock. This behavior is reproduced every time. What I described above was completely different. I had those Waze directions on the top-center position (replacing the clock) for about 30 minutes/50 km drive, until I stopped the car. And it was surely not the outcome of me pressing some magic button on the steering wheel or MIB. I don't play at all with the dashboard display while I'm driving; at least not after I decided what info to keep showing, after my first weekend with the car. The only buttons I use after each start are: "Car" then "Start/Stop Off" and then "Assist" (on the steering wheel) -> "Lane assist Off".
That's the strange story... Each time it happened (only last weekend) I never touched the "content" of the gauges. I decided a while ago on what I keep in there as info, and I rarely scroll through those info. As a matter of fact, I don't even have "navi directions" activated in any of the left or right gauges. On one occasion last weekend, I was trying to force the central display to show me waze-directions, because I was already almost convinced it was randomly working. I was on cable connection (wireless charging giving me less power than the consumption of wireless AA), I had those directions shown for more than 30 minutes and I stopped at a gas station. When I restarted I had the clock on display, so I tried to restart the AA connection. I tried from the car's MIB, but it didn't help. So I went on the Phone into Settings -> Apps -> AndroidAuto -> ForceStop. After that disconnected and reconnected the cable on the phone, AA started with Waze still keeping the old destination I previously set. The instant it restarted I had the waze directions on the dashboard (replacing the HH:MM) for a couple of seconds - not more that 5 - and then it came back to clock display...
That's the nice thing about it: you don't loose any of the Info inside the two gauges (or the left&right sides - for those using the other virtual dashboards). The driving directions are displayed on the center-top side of the dash, where you normally have the clock showing. I don't have a problem to loose the click against those detailed Waze-directions. I'll upload a picture when I get the opportunity; this weekend I wasn't lucky enough to have it displayed - I was stuck with the clock HH:MM. The one attached is found online - only to show what's the region I'm referring to - the clock display; Waze directions use an impressively large area, much more than the clock size!
Delivery times?
Well, on the previous diesel engines I had, I knew that low revs aren't great for the cat-converter and for the EGR. I'm not sure if the newer technologies included in this last version of the 2.0 TDI solved those potential issues. Indeed, the fuel consumption is great; mine is in the 4.4 - 4.6 interval for most of my drives.
