Everything posted by Blue8793841
- Manual Gearbox Oil
replacing tyres/alloys for more comfort
You could try will they fit.com it gives you the circumference and other details.
Hand Brake Cable Adjustment
You should never have to adjust the cable, if you do you have a problem. Either the cable or calipers faulty.
Skoda Fabia (2021) servicing intervals question
That's why you take it to a private garage to get a full service at half the price of an oil service 🤣
Gear change
Common on the vag group, synchros/baulk rings. You can try adjusting the cables might help a bit but I doubt it. That's assuming they used the correct oil.
Lost Communication With NOx Sensor "B"
They are very sensitive to voltage, id get the battery and alternator checked out.
MPG 1.0 vs 1,5 litre engines?
Just to note I did see around 65mpg and still rising from my 1.5 at around 60-65 mph, but I can't drive like that I'm too impatient.
Yes sorry it's seems to pick up quickly with less throttle
Error code 000258
Is maf is good you have egr stuck, or wiring ECU fault.
Id go for the 1.0, I work in a garage and it's a lot easier to get good economy. The 1.5 takes around 15-20 minutes before you start to see any decent mpg. I also own a 1.5 too. If the engine is warm the 1.5 is fine but if you don't need the extra power 1.0 is also fine 🤣 the 1.5 is also very nippy tbh, feels better than my 1.5 up to motorway speeds.
- Unscrewing the coolant tank lid
Knocking Sound Under Bonnet – Need Advice!
Usually shock absorber if your struggle to find the noise, has it ever had and springs fitted or work to the suspension? Wheels bolts tight??
P2002 / Oil Leak - Recommendations for garages (Liverpool)
What vehicle?
- 1.5 SE TSI Idle
Rust on door sill
That looks like damage, has the wife been driving or?
- Quiet 18" tyres for VRS
Coolant temperature
I would recommend with replacing the thermostat first
- Vibration on motorway
1.5 TSI misfiring when started from cold
Any update?
Noise from both LHS (? top mount area) and steering motor
I have Octavia 3 and there is noise when manoeuvring at low speed, is this the noise you are complaining of? Never really bothered me but it is there. Sure there is a bulletin about it and power steering motor.
Few questions regarding a used Superb (including 1.5 vs 2.0 TSI and mpg question)
The 2.0 has a chain, plenty of common faults if you look on the forum. Main thing I would look out for is injector and carbon build up on intake valves. Not that you can check without investigating.
